Folding@Home - Hardwareluxx Team
Ich hab Treiber 177.35 und die richtige .inf! (Vom DL!)
So sieht mein Log aus:
Stutzig macht mich die Zeitangabe!
[14:45:18] - Ask before connecting: No
[14:45:18] - User name: [HWLuxx]MainEvent (Team 70911)
[14:45:18] - User ID: 57A62DC87A9F53C0
[14:45:18] - Machine ID: 2
[14:45:18]
[14:45:18] Loaded queue successfully.
[14:45:18] Initialization complete
[14:45:18] + Benchmarking ...
[14:45:18]
[14:45:18] + Processing work unit
[14:45:18] Core required: FahCore_11.exe
[14:45:18] Core found.
[14:45:18] Working on queue slot 02 [June 29 14:45:18]
[14:45:18] + Working ...
[14:45:18]
[14:45:18] *------------------------------*
[14:45:18] Folding@Home GPU Core - Beta
[14:45:18] Version 1.06 (Mon Jun 23 10:53:13 PDT 2008)
[14:45:18]
[14:45:18] Compiler :
[14:45:18] Build host: amoeba
[14:45:18] Preparing to commence simulation
[14:45:18] - Looking at optimizations...
[14:45:18] - Files status OK
[14:45:18] - Expanded 43439 -> 246249 (decompressed 566.8 percent)
[14:45:18] Called DecompressByteArray: compressed_data_size=43439 data_size=246249, decompressed_data_size=246249 diff=0
[14:45:18] - Digital signature verified
[14:45:18]
[14:45:18] Project: 5004 (Run 8, Clone 110, Gen 18)
[14:45:18]
[14:45:18] Assembly optimizations on if available.
[14:45:18] Entering M.D.
[14:45:24] Will resume from checkpoint file
[14:45:25] Working on p5002_supervillin_e1
[14:45:25] Client config found, loading data.
[14:45:25] Resuming from checkpoint
[14:45:25] Verified work/wudata_02.log
[14:45:25] Verified work/wudata_02.edr
[14:45:25] Verified work/wudata_02.trr
[14:45:25] Verified work/wudata_02.xtc
[14:45:25] Completed 14%
[14:45:25] Starting GUI Server
Im Tray steht F@H: Working (3500/25000), nur im Display steht das mit dem Core etc.
Du brauchst den richtigen Treiber und die gemoddete inf ;)
steht ein par seiten vorher alles erklärt
Nee, brauche ich nicht. Funktionierte schon die ganze Nacht lang ohne irgendwelche gemoddeten Treiber.
Und jetzt gehts auch wieder! Einfach FaH-GPU neustarten. ;)
Hmm, ist das normal dass, wenn ich über dieses Teil mit dem QIP Chatfenster gehe und das ein bisschen darüber hin und her ziehe plötzlich ganz oft diese "Moleküle" oder was das sind plötzlich immer wechseln, und alles plötzlich ganz schnell abläuft?:d
€: Funktioniert auch mit anderen Fenstern^^
Ich hab jetzt den Treiber neu installiert und somit auch F@H-GPU neu gestartet.
Die Display-Anzeige ist unverändert bis auf das die Berechnung von neuem beginnt. :(
Wahrscheinlich ist mein Viewer nur irgendwie bekloppt..oder?
Ein CPU-Kern ist 100% ausgelastet, aber der andere fast garnicht!
WIESO?
EDIT:
Die Schrift beim normalen CPU-Clienten ist auch super schwach zu lesen!
Da, aber komischerweise mit 2 ausgelasteten Kernen!
Ach, ihr mit euren G80 GPUs... total lahm sind die. :fresse:
G92-400@800/2000/1040 3.300 iter/sec ~ 6050PPD :fresse: :d
Also ich habe die den nVidia Treiber 175.16 laufen, und alles funtz prima!
Ganz ohne irgendwelche Treiber mods etc.
@reik: kriegst du gleich, mom
@bLaCk_vIpEr: Jo, das ist bei mir auchso! Mit den ICQ Chatfernstern.
Zeitweilig werden mir die Moleküle aber auch garnicht mehr angezeigt...
@MainEvent: Du kannst die Prozessorkernzugehörigkeit im Taskmanager einstellen. FaH stellt sich selbst manchmal so ein das es nur auf einem Kern läuft.
@MainEvent Bei deinem gpu-clienten rechnet die cpu. das kannst du 1. an 60 iter/sek sehen und 2. müsste unten rechts statt "core is not running" dein name und dein team stehen.
Du hast also den 177.35 treiber für gtx200 karten installiert?
Wenn ja, komisch. hab keine ahnung wodran es liegt.
Wenn nein, 177.35er treiber für gtx200 auf der betaseite von nvidia laden. gemodette inf von den gurus ziehn. dann den treiber mit winrar oder so entpacken, die inf drüberkopieren und dann den entpackten treiber installiern.
der 177.41 mit modded .inf funzt auch prima (bei mir)
Nur eben nicht mitm Viewer --> BSOD :motz:
@harzer_knaller hast du durch den neuen treiber mehr ppd? ich mein, auf den viewer kann ich gerne verzichten^^
Ohne irgendwelche Treibermods...
(nicht wundern, grade neu gestartet)
@reik: da ich den FahMon erst seit heute habe, kann ich leider keinen Vergleich geben zwischen vorher und nachher PPD...
Zumindest läuft es nicht schlechter, abgesehen vom Viewer, den man nicht nutzen kann.
Aber das gleiche Phänomen hatte ich mitm 175.xx und dem Beta 6 des GPU Clients.
Was ist ppd?
Tatraten sind orgi, also GPU: 600 | Shader: 1500 | 900Mhz bzw. 1800Mhz.
Treiberversion ist: 175.16
Ich komme damit auf maximal 1685 iter / sec.
mit fahmon kann man dann sehn, wieviel Points Per Day du erreichst
edit: ich lade den treiber auch grad
PPD sind Points per Day, oder?
Puh keine Ahnung, aber ich habe letzte Nacht durchlaufen lassen (ca. 8 Stunden) , und da waren es etwa 1500 Punkte.
Mal ne ganz dumme Frage^^
Was bringt einem das Folding@Home, dass man es die ganze Nacht laufen lässt?^^
Naja eine 8800GT ist stärker als ein E6600. Wer Tags über spielen will, muss halt nachts laufen lassen!
FÜR DIE WISSENSCHAFT!
WIESO?
EDIT:
was ist das denn für ein cpu client weil bei dem den ich habe ist kein viewer dabei.
Habe den 6.10 beta 3
ok, mit dem aktuellen treiber für ne G80 geht der gpu client nicht!!
werde wieder den für die gtx200 drauf machen müssen
der 6.12 beta 8 ist doch der gpu client ich meinte allerdings den cpu client weil ich nur die version finden kann die ich bereits habe
@oban wenn du einen viewer willst, darfst du keinen beta clienten nehmen.
einfach mal bei google "folding" eingeben. der erste hit is die page, da auf download ;)
der cpu-client-viewer is aber übelst hässlich im vergleich zum gpu client ;)
Hab den CPU-Client 5.04, also die Bash version.
Aber die gefällt mir sowieso viel besser.
Die Proteine muss sich eh keiner angucken,
ausserdem sieht man dann gleich den Inhalt des Logs.
wer mir sagt, wie ich das hier einrichten muss, damit es funktioniert, auf dessen name lasse ich meine clienten 24h laufen:
Sidebar gadgets für folding
EDIT: Habs rausgefunden, Angebot gilt nicht mehr ;)
So, nochmal, ich habe beide Clients laufen.
CPU-Client 5.03 & GPU-Client 6.12 Beta 8
Ich höre die Spawas auf der Graka sirren.
Fahmon zeigt mir ein gelbes Kästchen vorm GPU-Client, aber das Log sieht gut aus.
Wenn ich den Viewer vom GPU-CLient aufmache steht "Core not found", kein Name und er fängt an ein Test-Protein zu crunchen, das Sirren ist weg!
Wenn ich den Viewer ausmache, dann fängt nach kurzer Zeit das Sirren wieder an. (Rechnet die GPU wieder korrekt?)
Im Taskmanager ist der 1 Kern 100% ausgelastet, der andere so ca. 50%.
Warum?
Muss ich die Affinität ändern? Wenn ja, wie?
FaH ein paar mal neu starten, evtl. den Rechner neu starten, dann gehts auf jeden fall wieder.
Warum?
FaH stellt sich selbst so ein das es nur auf einem Kern läuft.
Man kann im Taskmanager genau bestimmen auf welchem Kern welches Prog läuft.
Rechte Maustaste auf den Task und auf "Zugehörigkeit festlegen..." klicken!
Diese Einstellungen bleiben bis zum nächsten Rechnerneustart.
