Ich hab mir das Plugin "foo_audioscrobbler.dll" installiert. Wann wird die Musik geuploadet und ich brauch nur dieses plugin sonst nix oder?
Plugins needed
- foo_ui_columns.dll - [link]
- foo_ui_panels.dll - [link]
- foo_cwb_hooks.dll - [link]
- foo_playcount_mod.dll - [link]
- foo_uie_powerpanels.dll - [link]
- foo_uie_quicksearch.dll - [link]
- Plus one extra that is included in the rar.
How to use
- Install the fonts.
- Extract the rar contents to: /foobar2000/PanelsUI/
Go to preferences > PanelsUI and select the foobear.pui file in the Layout dropdown box.
- I recommend that you turn on ClearType if you use Windows XP.
- Add and scan your Media Library in Preferences > Media Library.
- If the album title in the playlist is called "Single Tracks" you must tag your album's Total Tracks tag. The easiest way to do this is to select all your songs in the playlist > rightclick > rightclick again on the Total Tracks field and choose Auto track number.
- To display the album art:
The front cover must be named folder.jpg and be located in the album's folder where the music files are.
Same with artists. Name those images artist.jpg.
foobar2000 Beta Changelog:
New Default User Interface
New Album List component
- Allows embedding of Album List and other components in the main window
- Quick setup dialog on first startup allowing easy UI customization
- Theme import/export support for transferring appearance-related settings easily
- Built-in playlist view supports columns and grouping
- New Playlist Search dialog
- Embedded album art support
- New built-in spectrum visualisation
Properties dialog improvements
- Updates automatically with Media Library content changes (“Refresh” command no longer needed)
- Embeddable in the main window
- Supports direct creation of autoplaylists from Album List tree branches
Converter component improvements
- New commands: “Format from Other Fields”, “Capitalize”, “Clean Up”
- Improved “Automatically Fill Values” functionality
- Improved Windows Clipboard interaction - now you can use copy/paste to transfer values between fields or between different sets of tracks
Audio format decoding updates
- Replaced “show output directory when done” functionality with a new dialog showing a list of created tracks
- Built-in support for writing AU/SND and AIFF files
- Updated FLAC support - FLAC encoding now requires FLAC encoder 1.2.0 or newer
- Improved handling of hung command-line encoder processes
- Updated libFLAC to 1.2.0
- Rewritten support for AU/SND and AIFF audio formats
- New “File Operations” component, for moving, copying and deleting audio files
- Old Masstagger component no longer included with the installer (available for download separately)
- Windows XP or newer is now required
hi,
ich haette da mal ne frage:
ich verstehe ueberhaupt nicht wie es funktioniert, die albumlist in foobar zu integrieren, dass ich angenehm die lieder per drag & drop in die playlist ziehen kann.
ich habe mal die columnsUI.dll und die albumlist.dll in den components ordner kopiert und jetzt weiss ich nicht weiter...
waere nett, wenn ihr mir helfen koenntet
im gesamten soll es letztendlich so aussehen:
http://666kb.com/i/at1h1csrg03uiigk4.png
oder noch besser:
http://666kb.com/i/at1h37kcnjgyn6udw.jpg
(also, dass ich quasi per klick immer genauer aufschliessen kann, z.B. Rock -> AC/DC -> Let There Be Rock -> Whole Lotta Rosie)
