emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
G.SKILL Trident Z RGB Series
Source: http://gskill.com/en/press/view/g-s...y-rgb-lighting-ddr4-with-trident-z-rgb-series
G.SKILL schrieb:Taipei, Taiwan (20 December 2016) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is thrilled to announce the Trident Z RGB Series - the world’s most revolutionary RGB lighting DDR4 memory kit. Requiring no additional power connections, this incredible feat of engineering bares pure RGB lighting across an uncovered full-length light bar on the award-winning Trident Z series heatspreader design. To take a look at what’s to come, check out the following link for the Trident Z RGB trailer: https://www.youtube.com/watch?v=fPx0LNzgQm4
Full Range RGB Illumination; Software Control
By default, the Trident Z RGB will display a rainbow of colors in a wave-style lighting effect, illuminating any system with a myriad of hues. Further lighting effects and color customizations can be controlled and chosen through software, scheduled for a February 2017 release.
Uncompromised Performance
A culmination of over 25 years of experience in DRAM manufacturing, G.SKILL sought to combine full-range RGB lighting with minimal impact on DDR4 performance. Designed with a custom 10-layer PCB and hand-picked IC chips to enhance overclocking performance, the Trident Z RGB series is capable of reaching speeds of DDR4-4266MHz.
Trident Z RGB series memory kits are rigorously tested under proprietary G.SKILL test methods for reliability and compatibility to ensure the highest possible quality. And like all other G.SKILL memory, the Trident Z RGB is covered under a limited lifetime warranty, as well as full support for XMP 2.0 for easy overclocking and simple BIOS setup.
Availability
Trident Z RGB series DDR4 memory kits are scheduled for a worldwide release via G.SKILL authorized distribution partners in mid-January 2017, with software to be available for download the following month.
