Du hast eh mächtig Schwein, also wirst schon einen finden
Info :
So, habe nun diverse Shops durch.
807 = NOGO
808 = Überrall erhältlich.
Hat nun schon jemand einen 808er der
annähernd so gut wie ein 807er geht ?
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1791 Time: 15
CPU: 3807MHz FSB: 423MHz [423MHz x 9.0 est.]
18.04.2008 05:50
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
1:Press Stop to end this test.
2:Beginning a continuous self-test to check your computer.
2:Press Stop to end this test.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:FATAL ERROR: Rounding was 0.5, expected less than 0.4
1:Hardware failure detected, consult stress.txt file.
1:Torture Test ran 2 minutes 20 seconds - 1 errors, 0 warnings.
1:Execution halted.
2:Torture Test ran 2 minutes 20 seconds - 0 errors, 0 warnings.
2:Execution halted.
dolcemann: in schwieriger Fall![]()
