10:21:59 T:4484 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:21:59 T:4484 NOTICE: -----------------------------------------------------------------------
10:21:59 T:4484 NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: x86 Win32 32-bit
10:21:59 T:4484 NOTICE: Using Release XBMC x32 build, compiled Aug 17 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
10:21:59 T:4484 NOTICE: Running on Windows 8.1 64-bit, build 9600
10:21:59 T:4484 NOTICE: Host CPU: Intel(R) Core(TM) i3-4330 CPU @ 3.50GHz, 4 cores available
10:21:59 T:4484 NOTICE: Desktop Resolution: 1920x1080 32Bit at 32Hz
10:21:59 T:4484 NOTICE: Running with restricted rights
10:21:59 T:4484 NOTICE: Aero is enabled
10:21:59 T:4484 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
10:21:59 T:4484 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
10:21:59 T:4484 NOTICE: special://masterprofile/ is mapped to: C:\Users\Dennis\AppData\Roaming\XBMC\userdata
10:21:59 T:4484 NOTICE: special://home/ is mapped to: C:\Users\Dennis\AppData\Roaming\XBMC\
10:21:59 T:4484 NOTICE: special://temp/ is mapped to: C:\Users\Dennis\AppData\Roaming\XBMC\cache
10:21:59 T:4484 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
10:21:59 T:4484 NOTICE: Local hostname: HTPC
10:21:59 T:4484 NOTICE: Log File is located: C:\Users\Dennis\AppData\Roaming\XBMC\xbmc.log
10:21:59 T:4484 NOTICE: load settings...
10:21:59 T:4484 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:21:59 T:4484 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
10:21:59 T:4484 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.178.58</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_video</name>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_music</name>
</musicdatabase>
<pathsubstitution>
<substitute>
<from>special://masterprofile/Thumbnails/</from>
<to>smb://192.168.178.58/d/Programme/xbmcthumbs</to>
</substitute>
</pathsubstitution>
</advancedsettings>
10:21:59 T:4484 WARNING: VIDEO database configuration is experimental.
10:21:59 T:4484 NOTICE: Default DVD Player: dvdplayer
10:21:59 T:4484 NOTICE: Default Video Player: dvdplayer
10:21:59 T:4484 NOTICE: Default Audio Player: paplayer
10:21:59 T:4484 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:21:59 T:4484 NOTICE: Log level changed to 0
10:21:59 T:4484 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:21:59 T:4484 NOTICE: Loaded playercorefactory configuration
10:21:59 T:4484 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:21:59 T:4484 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:22:00 T:4560 NOTICE: Thread ActiveAE start, auto delete: false
10:22:00 T:4572 NOTICE: Thread AESink start, auto delete: false
10:22:00 T:4560 NOTICE: Found 2 Lists of Devices
10:22:00 T:4560 NOTICE: Enumerated DIRECTSOUND devices:
10:22:00 T:4560 NOTICE: Device 1
10:22:00 T:4560 NOTICE: m_deviceName : {6C26BA7D-F0B2-4225-B422-8168C5261E45}
10:22:00 T:4560 NOTICE: m_displayName : Network Device - Remoteaudio
10:22:00 T:4560 NOTICE: m_displayNameExtra: DIRECTSOUND: Remoteaudio
10:22:00 T:4560 NOTICE: m_deviceType : AE_DEVTYPE_PCM
10:22:00 T:4560 NOTICE: m_channels : FL,FR
10:22:00 T:4560 NOTICE: m_sampleRates : 44100
10:22:00 T:4560 NOTICE: m_dataFormats : AE_FMT_FLOAT
10:22:00 T:4560 NOTICE: Device 2
10:22:00 T:4560 NOTICE: m_deviceName : default
10:22:00 T:4560 NOTICE: m_displayName : default
10:22:00 T:4560 NOTICE: Enumerated WASAPI devices:
10:22:00 T:4560 NOTICE: m_displayNameExtra: WASAPI: Remoteaudio
10:22:00 T:4484 NOTICE: Running database version Addons16
10:22:00 T:4484 NOTICE: ADDONS: Using repository repository.xbmc.org
10:22:00 T:4484 NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
10:22:00 T:2244 NOTICE: Thread RemoteControl start, auto delete: false
10:22:00 T:920 NOTICE: Thread PeripBusCEC start, auto delete: false
10:22:00 T:4128 NOTICE: Thread PeripBusUSB start, auto delete: false
10:22:00 T:4484 NOTICE: Found screen: Dummy Monitor on RDPUDD Chained DD, adapter 0.
10:22:00 T:4484 NOTICE: Primary mode: 1920x1080@ 32.00 - Full Screen
10:22:00 T:4484 NOTICE: Additional mode: 1920x1080@ 32.00 - Full Screen
10:22:00 T:4484 NOTICE: Checking resolution 16
10:22:00 T:4484 NOTICE: No Joystick name specified, loading default map
10:22:00 T:4484 NOTICE: Previous line repeats 35 times.
10:22:00 T:4484 NOTICE: Running database version ViewModes6
10:22:00 T:4484 NOTICE: Running database version Textures13
10:22:00 T:4484 NOTICE: Running database version xbmc_music46
10:22:00 T:4484 NOTICE: Running database version xbmc_video78
10:22:00 T:4484 NOTICE: Running database version TV22
10:22:00 T:4484 NOTICE: Running database version Epg7
10:22:00 T:4484 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
10:22:00 T:4484 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:22:00 T:2040 NOTICE: Thread LanguageInvoker start, auto delete: false
10:22:00 T:4484 NOTICE: Previous line repeats 4 times.
10:22:00 T:4484 NOTICE: initialize done
10:22:00 T:2748 NOTICE: Thread LanguageInvoker start, auto delete: false
10:22:00 T:4484 NOTICE: Running the application...
10:22:00 T:2948 NOTICE: -->Python Interpreter Initialized<--
10:22:00 T:3092 NOTICE: Thread JobWorker start, auto delete: true
10:22:00 T:4484 NOTICE: ES: Starting event server
10:22:00 T:3760 NOTICE: Thread EventServer start, auto delete: false
10:22:00 T:3760 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
10:22:00 T:1396 NOTICE: Thread TCPServer start, auto delete: false
10:22:00 T:3760 NOTICE: UDP: Listening on port 9777
10:22:00 T:3820 NOTICE: -->Python Interpreter Initialized<--
10:22:00 T:2040 NOTICE: -->Python Interpreter Initialized<--
10:22:00 T:2256 NOTICE: -->Python Interpreter Initialized<--
10:22:00 T:2920 NOTICE: -->Python Interpreter Initialized<--
10:22:00 T:2748 NOTICE: -->Python Interpreter Initialized<--
10:22:01 T:2256 NOTICE: RCB Service: Start
10:22:01 T:2256 NOTICE: RCB Service: launch RCB on startup =
10:22:01 T:2256 NOTICE: RCB Service: scrape games on startup = false
10:22:01 T:2256 NOTICE: RCB Service: Done
10:22:01 T:2656 NOTICE: Thread AlarmClock start, auto delete: false
10:22:01 T:2948 NOTICE: ### [AmbiBox] - Connected to AmbiBox
10:22:01 T:2748 NOTICE: StorageServer Module loaded RUN
10:22:01 T:2748 NOTICE: StorageClient-2.5.4 Starting server
10:22:01 T:3828 NOTICE: Thread JobWorker start, auto delete: true
10:22:09 T:672 NOTICE: Previous line repeats 1 times.
10:22:09 T:672 NOTICE: Thread BackgroundLoader start, auto delete: false
10:22:20 T:1460 NOTICE: Previous line repeats 1 times.
10:22:20 T:1460 NOTICE: Thread FileCache start, auto delete: false
10:22:31 T:4664 NOTICE: Thread LanguageInvoker start, auto delete: false
10:22:31 T:4664 NOTICE: -->Python Interpreter Initialized<--
10:22:38 T:3092 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
10:22:38 T:3092 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
10:22:38 T:3092 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
10:22:38 T:3092 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/script.tv.show.next.aired/script.tv.show.next.aired-6.0.11.zip.md5>
10:22:39 T:3092 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
10:22:39 T:3092 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
10:22:39 T:3936 NOTICE: Thread BackgroundLoader start, auto delete: false
10:22:46 T:996 NOTICE: Thread FileCache start, auto delete: false
10:23:33 T:3948 NOTICE: Thread JobWorker start, auto delete: true
10:31:41 T:4484 NOTICE: Previous line repeats 8 times.
10:31:41 T:4484 NOTICE: Storing total System Uptime
10:31:41 T:4484 NOTICE: Saving settings
10:31:41 T:4484 NOTICE: stop all
