@zidane
vorschlag zur güte....
eine mischung aus i-ram und ssd.
eine (bezahlbare,aber wahrscheinlich nicht mehr zu bekommende)hardware ramdisk angebunden per pci. vllt. kommt da bald mal was in die richtung,
dann hoffentlich mit PCI-E und mehr speicher. bei den heutigen preisen ....
das würde mir als systempartition auch gefallen.
http://www.cenatek.com/downloads/C-0186RevK_installation_manual.pdf
übrigens kann man auch mit deser karte einen raidf aufbauen, so lange man genug pci slots hat.
"Rocket Drive Standard:
RAM-based PCI solid state disk
Fastest access time of any storage device
Secondary external DC power for data retention when the host is powered down.
The Rocket Drive does not cannibalize existing system memory nor is it a memory expansion card. It is a drive.
Rocket Drive looks and acts just like another drive to the host system.
Multiple Rocket Drives can be used simultaneously, as long as there are available PCI slots, by
spanning the drives or striping the drives. "
ZUM ABSCHLUSS DES THEMAS RAMDISK HIER EIN PAAR LINKS FÜR INTERESSIERTE
qsoft ramdisk (bis 64gb)
http://users.compaqnet.be/cn021945/RAMDisk/ramdriv.htm
genau wie ich es gesagt habe, lädt dieses tool ein image auf die ramdisk und macht die daten/programme dort verfügbar:
"(1) The software may be installed directly to the ramdisk , or an existing installation may be remapped using a "junction" ( with means of i.e. linkd.exe ) to a copy on the ramdisk. In both cases , the content of the ramdisk must reload automatically at boot time from an image file , or by means of a backup program.
These are only a few examples. There will certainly be many more tasks for which a ramdisk can be used, depending on people's "inventivity"
The "Enterprise (full)" allows to create a RAMDisk , depending on the RAM memory size that the OS supports , to up to 64 GB.
This RAMDisk has the capability to automatically reload an image file at boot time ( and before other services / programs are started ) and to save the ramdisk content at shutdown and/or at regular intervals. Home users, small and large business users, may experience this RAMDisk as a state-of-the-art solution. "
@ ZIDANE und dein einwand.... (daten)sicherheit .....
also mein rechner läuft so stabil, dass im ram nichts abkackt.(auch nicht wenn der rechner wochen lang läuft.)
sollte dies bei dir der fall sein, spricht man von einem instabilen system. stürzt das ram ab, welches für die ramdisk benutzt wird,
ist dies der gleiche speicher den dein betriebsystem nutzt, dann würde der rechner so oder
so abstürzen und es gäbe einen DATENGAU. windows könnte dann auch nichts gescheid im speicher lassen. windows macht nichts anderes, wenn der kernel code pages paged. ein instabiles system ist aber keine grundlage. ein rechner hat nicht abzustürzen.
und eine usv tut ihren teil dazu. (strom bereitstellen, spannung glätten und vor überspannung schützen.)
und wenn du schon sicherheit ansprichst, dann spreche ich nochmals die auslagerungsdatei an.
welche sehr unsicher ist, da sie dateifragmente, passworthashes etc enthalten kann.
da ist man eher auf der sicheren seite, wenn sie auf einer ramdisk liegt.
und zum thema daten dauerhaft storen,.... warum nicht einfach die sachen aufm perc im raid5 sichern? ist schnell und sicher.
ssd`s in mobilen geräten, da brauchen wir nicht drüber zu sprechen. das macht sinn.
jede sd karte macht nichts anderes. ich denke da philosophiert keiner drüber.
um aber nochmal auf deine sicherheit zu kommen, wie sicher sind denn sd karten? also auch ein ssd?
nicht wirklich sicher! wir verkaufen diese dinger bei uns im shop, von allen herstellern.
ich will garnicht sagen, wieviele karten kaputt gehen... viel mehr als festplatten!
Superspeed Ramdisk
http://www.superspeed.com/download/trialversions.php
"Eine aktuelle, ständig weiter entwickelte und auch für die 64-Bit Systeme Windows x64, sowie für Dual-Core und SMP-Systeme geeignete Software bietet der Hersteller Superspeed. Hier gibt's von Lösungen für Server-Betriebssysteme mit Verschlüsselung und vielem mehr alles, was man von einer RAMDisk erwarten kann. Nachteil: die Software kostet richtig Geld. Zwischen $175 und $750 je nach Ausführung, Betriebssystem und Rechner müssen einkalkuliert werden. Allerdings gibt es auch eine Trialversion, die kostenlos herunter geladen und 30 Tage lang ohne Einschränkungen getestet werden kann."
noch ne ramdisk
http://download.chip.eu/de/RAMDisk-1.9_67134.html
(Mit diesem Tool wird ein weiteres Festplatten-Laufwerk bestehend aus Arbeitsspeicher mit einem Umfang von bis zu vier Gigabyte angelegt. Einzigartig ist die Bootfähigkeit des Laufwerks.)
einen interessanten artikel mit vielen infos und vergleichen:
http://www.planet3dnow.de/artikel/diverses/ramdisk/index.shtml
www.planet3dnow.de/artikel/diverses/ramdisk/4.shtml
und damit es nicht heißt ich hätte keine ahnung und würde ramdisks loben, obwohl sie käse sind...
hier ein kleines zitat aus einem artikel der seite planet3dnow:
"Die Vorteile einer RAMDisk
Doch die Vorteile der RAMDisk sind auch heute noch unbestritten. Im Gegensatz zu einer Festplatte hat RAM keinerlei mechanisch bewegte Teile. Das bedeutet, RAM ist schnell, sehr schnell. Hier sehen wir einen Bandbreitenvergleich zwischen einer typischen RAMDisk in einem Dual-Channel Athlon 64 System und diversen schnellen Festplatten-Systemen. Wie man sieht ist selbst ein 4-fach Raid-System bestehend aus flotten SATA-Festplatten als Stripeset gegen eine RAMDisk völlig chancenlos.
Noch viel deutlicher als bei der Bandbreite fällt der Unterschied bei der Zugriffszeit aus. Während bei einer Festplatte Zugriffszeiten im Millisekunden-Bereich typisch sind, beträgt die physikalische Zugriffszeit bei einer RAMDisk nicht Millisekunden, auch nicht Mikrosekunden, sondern Nanosekunden. Die Hardware einer RAMDisk ist in Sachen Latenzzeit also um den Faktor Eine-Million schneller, als die schnellste Festplatte. Warum sich diese Performance nicht zu Nutze machen dort wo es Sinn macht? Doch wo macht es Sinn? "
