Completely ignored arguments: [--nativeLauncherVersion, 301]
[18:03:21] [Client thread/INFO]: Setting user: Blubblord
[18:03:23] [Client thread/INFO]: LWJGL Version: 2.9.4
[18:03:23] [Client thread/INFO]: Reloading ResourceManager: Default
[18:03:24] [Sound Library Loader/INFO]: Starting up SoundSystem...
[18:03:24] [Thread-4/INFO]: Initializing LWJGL OpenAL
[18:03:24] [Thread-4/INFO]: (The LWJGL binding of OpenAL. For more information, see
http://www.lwjgl.org)
[18:03:24] [Thread-4/INFO]: OpenAL initialized.
[18:03:25] [Sound Library Loader/INFO]: Sound engine started
[18:03:26] [Client thread/INFO]: Created: 1024x512 textures-atlas
[18:04:08] [Client thread/INFO]: Reloading ResourceManager: Default
[18:04:09] [Client thread/INFO]: SoundSystem shutting down...
[18:04:10] [Client thread/WARN]: Author: Paul Lamb,
www.paulscode.com
[18:04:10] [Sound Library Loader/INFO]: Starting up SoundSystem...
[18:04:10] [Thread-7/INFO]: Initializing LWJGL OpenAL
[18:04:10] [Thread-7/INFO]: (The LWJGL binding of OpenAL. For more information, see
[18:04:10] [Thread-7/INFO]: OpenAL initialized.
[18:04:10] [Sound Library Loader/INFO]: Sound engine started
[18:04:11] [Client thread/INFO]: Created: 1024x512 textures-atlas
[18:04:42] [Server thread/INFO]: Starting integrated minecraft server version 1.9.4
[18:04:42] [Server thread/INFO]: Generating keypair
[18:04:45] [Server thread/INFO]: Preparing start region for level 0
[18:04:46] [Server thread/INFO]: Preparing spawn area: 9%
[18:04:47] [Server thread/INFO]: Preparing spawn area: 19%
[18:04:48] [Server thread/INFO]: Preparing spawn area: 28%
[18:04:49] [Server thread/INFO]: Preparing spawn area: 39%
[18:04:50] [Server thread/INFO]: Preparing spawn area: 48%
[18:04:51] [Server thread/INFO]: Preparing spawn area: 56%
[18:04:52] [Server thread/INFO]: Preparing spawn area: 66%
[18:04:53] [Server thread/INFO]: Preparing spawn area: 75%
[18:04:54] [Server thread/INFO]: Preparing spawn area: 84%
[18:04:55] [Server thread/INFO]: Preparing spawn area: 93%
[18:04:56] [Server thread/INFO]: Changing view distance to 12, from 10
[18:04:57] [Server thread/INFO]: Blubblord[local:E:9adf17c3] logged in with entity id 616 at (-173.5, 64.0, -52.5)
[18:04:57] [Server thread/INFO]: Blubblord hat das Spiel betreten
[18:04:59] [Server thread/INFO]: Saving and pausing game...
[18:04:59] [Server thread/INFO]: Saving chunks for level 'Neue Welt'/Overworld
[18:05:00] [Server thread/INFO]: Saving chunks for level 'Neue Welt'/Nether
[18:05:00] [Server thread/INFO]: Saving chunks for level 'Neue Welt'/The End
[18:05:00] [Server thread/WARN]: Can't keep up! Did the system time change, or is the server overloaded? Running 3278ms behind, skipping 65 tick(s)
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffe9add4fdc, pid=6644, tid=5328
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig75icd64.dll+0x524fdc]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Erwin\AppData\Roaming\.minecraft\hs_err_pid6644.log
# If you would like to submit a bug report, please visit:
Java Crash Reporting Page
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
