Necrofridge
Semiprofi
Das Problem ist, das wird entweder massiv auf die Fresse fallen, oder es wird dermaßen übermächtig sein, dass es sofort verboten wird.
I'm told that the flywheel KERS on the Nissan is actually in the front of the chassis, with a prop shaft running to the rear to drive the rear wheels. Furthermore, said sources have confirmed, without a doubt, that the combustion engine does indeed power the fronts tires, KERS the rears. My best guess about placement of radiators seems correct, mostly ahead of front wheel CL. And all of this, radiators/intercoolers, KERS, is purely for weight distribution. While the GT-R LM has nothing like the extreme weight distribution of the Delta Wing (30/70), like I mentioned last month, I do believe it is closer to 55-58% (or even slightly more) on the front, which ultimately means it has similar weight distribution numbers to a mid-engined car, but back to front.
Racingblog @Racingblog 55 Sek.Vor 55 Sekunden
Update: Karl Maurer (VLN Geschäftsführer) spricht von mehreren Personenschäden im Zuschauerbereich. #VLN
