Stumpjumper FSR Comp
RAHMEN FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
FEDERBEIN Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
GABEL Fox Float 120 RL, 120mm, rebound/compression adj, lock out, alloy steerer
STEUERSATZ 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
VORBAU Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
LENKER Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
LENKERBAND/GRIFFE Specialized MTB, dual density
VORDERRADBREMSE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
HINTERRADBREMSE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL 185mm rotor
BREMSHEBEL Avid Juicy 5
UMWERFER Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
SCHALTWERK SRAM X-9, 9-speed, long cage
SCHALTHEBEL SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t
KETTE SRAM PC-951 w /Power Link
KURBELSATZ Truvativ Stylo, 2pc crank/BB
KETTENBLÄTTER 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET Truvativ GXP, sealed outboard cartridge bearing
PEDALEN Shimano M-520 SPD
FELGEN DT custom for Specialized X430, 24mm w/eyelets, 32h
VORDERRADNABE Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
HINTERRADNABE Shimano M-525 disc, 32h, alloy QR
SPEICHEN DT Swiss 1.8mm stainless, black, alloy nipples
VORDERREIFEN Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
HINTERREIFEN Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
SCHLÄUCHE Specialized Ultralight 26x2.0", presta
SATTEL Specialized BG Rival, hollow Cro-Mo rails
SATTELSTÜTZE 2014 butted alloy, black, 30.9 x 350/400mm
SATTELSTÜTZKLEMME 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
zu den reflektoren. ich hatte auch solche weiß reflektierenden sticks. dann kam die polizei und ich durfte katzenaugen anbauen und eine "feste" beleuchtung, weil doch kein rennrad und da über 11 kg. am besten sind dann wohl die mäntel mit reflex-streifen. nur hab i noch keinen faltreifen gesehen der das hat
napshot was haste für die schuhe gezahlt?
Heute die neuen 2008er Bikes von Univega montiert![]()
