Da noch kein entsprechender Thread vorhanden ist zu den P45 Boards von MSI starte ich hiermit einen selbigen allerdings mit Schwerpunkt auf das P45 Platinum.
Kritik ist selbstverständlich erwünscht aber bitte seid gnädig mit mir, dies ist mein erster erstellter Sammelthread.
Bilder der weiteren MSI P45 Ableger werde ich noch einfügen.
MSI P45 Platinum - Technische Austattung:
CPU
• Supports Intel® Core 2 Extreme/Core 2 Quad/Core 2 Duo based processors in LGA775 package.
• Supports Intel® Yorkfield, Wolfdale in the LGA775 package.
• Supports FSB 1600* (OC)/1333/1066/800 MHz.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® P45 Chipset
- Supports FSB 800/1066/1333/1600* (OC) MHz.
• Intel® ICH10R Chipset
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 12 ports.
- 6 SATAII ports with transfer rate up to 3Gb/s.
- PCI Master v2.3, I/O APIC.
- ACPI 2.0 compliant.
- Serial ATA RAID 0/1/5/10.
- Integrated AHCI controller.
Main Memory
• Supports four unbuffered DIMM of 1.8 Volt DDR2 800/1066/1200* (OC) SDRAM, 16GB Max (To support 16GB max, please check the criteria at Intel website)
Slots
• Two PCI Express x16 slots (PCI Express Bus SPEC V2.0 compliant; supports CrossFire Technology)
- When using two PCIE x16 slots, the PCIE x16 lanes will auto arrange from x16/ x0 to x8 x8.
• Two PCI Express x1 slots. (support PCI Express Bus specification v1.0a compliant)
• Two 32-bit v2.3 master PCI bus slots.
- Support 3.3v/5v PCI bus interface.
On-Board IDE/SATA
• One Ultra DMA 66/100/133 IDE controller integrated in JMicron® 363.
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
• SATAII controller integrated in ICH10R/JMicron® 363 chipest
- Up to 3Gb/s transfer speed.
- Supports six SATAII ports by ICH10R
- Supports two SATAII ports by JMicron 363.
- Supports one eSATA port by JMicron 362.
- Supports AHCI controller with SATA RAID 0/1/5/10 by ICH10R.
MSI Reminds You...
• The RAID setup floppy disk is optional depending on the districts. You can download the files from the website to make the setup disk.
Audio
• Chipset integrated by Realtek® ALC888/888T
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
- Meet Microsoft Vista Premium spce
- Supports VoIP Card (for ALC888T only)
LAN
• Supports PCI Express LAN 10/100/1000 Fast Ethernet by Realtek 8111C.
IEEE1394
• JMicron® 381 chipset
- Supports up to two 1394 ports. (Rear panel x1, pinheader x1)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- ATX 24-Pin power connector
- 8-pin ATX 12V power connector
- 4-pin ATX 12V VGA connector
- CPU / System x 5 FAN connectors
- CD-in connector
- Front panel audio connector
- Front panel connector
- 1 x chasis intrusion connector
- 1 x serial port pinheader
- 3 x USB 2.0 connectors
- 1 x Floppy disk drive connector
- 8 x Serial ATAII connectors
- 1 x ATA133 connector
- SPDIF-Out connector
- Clear CMOS Jumper
- 1 x IEEE1394 connector support additional 1 port (optional)
- 2 x H/W OC connector
- 1 x GreenPower Genie connector (optional)
- 1 x Reset Button
- 1 x Power Button
- 1 x TPM module connector (optional)
Preis:
http://geizhals.at/deutschland/a338081.html
Direktlink MSI Deutschland:
http://www.msi-technology.de/index.php?func=proddesc&prod_no=1479&maincat_no=1&cat2_no=170#
Bios:
http://www.msi-technology.de/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1479
Treiber:
http://www.msi-technology.de/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1479
Handbuch:
http://www.msi-technology.de/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=1479
Direktlink MSI Global:
http://global.msi.com.tw/index.php?func=proddesc&prod_no=1479&maincat_no=1&cat2_no=170
CPU-Support Liste
http://www.msi-technology.de/index.php?func=prodcpusupport&prod_no=1479&maincat_no=1
Reviews/Previews Englisch:
HardOCP
PC Pro
CPU 3D.com
Tweaktown
Reviews/Previews Deutsch
PC Games Hardware
MSI P45 Platinum
Backpanel
- 1 x Clear CMOS button
- 1 x PS/2 Keyboard
- 1 x PS/2 Mouse
- 1 x eSATA port
- 1 x IEEE1394 port (optional)
- 6 x USB 2.0 ports
- 1 x RJ45 LAN Jack
- 1 x 6 in 1 audio jack
- 1 x Optical SPDIF-out
Weitere MSI P45 Platinen:
P45 Neo-F------P45 Neo2--------P45 Neo3--------P45 Platinum-----P45 Diamond-----P45D3 Platinum
Backpanel
- 1 x PS/2 Keyboard
- 1 x PS/2 Mouse
- 1 x eSATA port
- 6 x USB 2.0 ports
- 1 x RJ45 LAN Jack
CPU
Chipset
Main Memory
Slots
On-Board IDE/SATA
MSI Reminds You...
Audio
LAN
IEEE1394
- CD-in connector
- Clear CMOS Jumper
- 1 x Reset Button
- 1 x Power Button
Preis:
Bios:
Treiber:
Handbuch:
CPU-Support Liste
HardOCP
PC Pro
CPU 3D.com
Tweaktown
PC Games Hardware
