[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
Danke. Werd's mal probieren.
Edit: Du meinst wahrscheinlich "internal PLL overvoltage", stimmt's?
(Das mit dem Überschreiben war irreführend. ^^)
Für das Z77A-GD65 gibt es bereits das BIOS 1.7. Es wurde u.a. die Fastbootoption für Windows 8 eingepflegt. Notnagel hat ein komplettes Changelog der Beta gepostet, keine Ahnung, ob das auch alles in der Final drin ist.
Mich würde noch interessieren was Ihr unter den folgenden Einstellungen fürs OverCocking ändert. :wink:
Vor Allem würde ich gern mehr über diese Funktionen wissen:
- "Limit CPUID Maximum". Was ist das genau?
- "OverSpeed Protection". Wird hier eine bestimmte Frequenz limitiert?!
- "Long/Short Duration Power Limit(...)". Sollten die Werte fürs OC-en erhöht werden, wenn ja, wie hoch?
- Kann wer auch die einzelnen "1...4-Core Ration Limits" genauer erläutern?
Ich bedanke mich schon im Voraus. :)
Execute Disable Bit kannst du deaktivieren, ebenso Intel Virtualization.
Power Technology würde ich dann auf Custom machen.
Overspeed Protection greift glaube ich erst ab einem bestimmten Takt. Wenn der Takt läuft, den du eingestellt hast, kannst du das also aktiv lassen.
Die anderen Einstellungen unten beziehen sich glaube ich nur auf den Turbo Modus.
Und warum sollte man deiner Meinung nach eine Sicherheitsfunktion (die sogar zwingend für Win8 benötigt wird!) und ein Performance-Funktion deaktivieren? :popcorn:
Was soll er denn dann deiner Meinung nach bei bei den Custom Energieeinstellungen einstellen wenn er es schon per Hand einstellen soll?
Und die Overspeed Protection greift nicht bei zu hohem Takt sondern bei den Watt und Ampere Werten die man dann wieder unten bei den Punkten einstellen kann!
Der Wert sollte sich eigentlich automatisch auf die utopisch hohen Werte von 200W bei "Long" und 250W bei "Short" einstellen wenn man im im vorherigen Menü "CPU Core OCP Expander" auf "Enhanced" stellt. Alle anderen Werte bleiben dabei unangetastet.
Wenigstens das mit den Turbo Werten stimmt, damit soll man angeblich manuell den Turbo je nach Last der Kerne beeinflussen können so wie Intel es auch eigentlich vorgesehen hat.
Bei meinem GD80 funktioniert es aber bis heute auch nach dem dritten Final Bios und etlichen Betas absolut überhaupt nicht übers Bios, da takten trotzdem alle Kerne immer gleich hoch egal was man einstellt sobald man über die eigentlichen Intel Werte geht :mad: Per Software klappt`s teilweise wie hier jemand dargestellt hat (-> x)
Warum sollte man das machen? Ein wichtiges Sicherheitsfeature und den Support für hardwarebeschleunigte Virtualisierung herausnehmen?
Wenn es einem nur ums OCen geht, ist es immer am besten alle "unnötigen" Funktionen zu deaktivieren. Das Execute Bit sollte jedenfalls wieder aktiviert werden, wenn man erst einmal einen stabilen Takt erreicht hat. Vm braucht man ja wohl nur zu aktivieren, wenn man das auch nutzt.
Kann ja jemand mal versuchen nach zu stellen per manueller Erhöhung des eigentlich Last abhängigen Turbos
Hier mal zwei Beispiele wie es nicht sein soll. (Mit Last auf den HT Kernen kommt´s gleiche raus habe ich daher hier weg gelassen)
Last per LinX oder besser Prime95 mit der entsprechenden Anzahl an Threads starten und dann zusätzlich per Taskmanager fest den jeweiligen Kernen zuweisen! Andernfalls wandert die Last teilweise von Kern zu Kern.
Bsp1:
Bsp2:
Das Beste kommt noch:
4Core/3Core/2Core/1Core Einstellung:
Turbo 45/45/46/47 -----------------------------------------------------> immer 45er egal bei welcher Last :wall:
Turbo 45/45/46/47 + Adjust CPU Ratio in OS -----------------------------> immer 42er egal bei welcher Last :wall: und weil zu 100% keine Software im Hintergrund läuft die den Multi verstellen könnte gibts gleich noch mal drei hinterher für diesen Bockmist :wall::wall::wall:
Turbo 45/45/46/47 + Enhanced Turbo -----------------------------------> immer 47er egal bei welcher Last, passt so da man den max. Multi damit ja erzwingt auch wenn Last auf allen Kernen liegt :angel:
Turbo 45/45/46/47 + Enhanced Turbo + Adjust CPU Ratio in OS -----------> immer 45er egal bei welcher Last :wall: ... wie war das noch mal mit dem erzwungenen max. Multi :hmm:
Turbo 37/37/38/39 (Intel Standard) -------------------------------------> Last 1 Kern = Multi x39, Last auf 2 Kernen = Mult x38, Last auf 3+4 Kernen = Multi x37 :angel:
Turbo 37/37/38/39 (Intel Standard) + Adjust CPU Ratio in OS -------------> Last 1 Kern = Multi x39, Last auf 2 Kernen = Mult x38, ... alles OK, warum hier wohl kein 42er Multi gesetzt wird wie oben :banana:
Absolut keine Logik dahinter was hier beim GD80 passiert. Einziger Trost ist das es trotzdem im Leerlauf brav bei allen obigen Einstellungen auf x16 runter taktet und auch die Spannung reduziert!
PS: Jean-Luc Picard wollte doch schon vor länger Zeit das GD80 hier im Sammelthread einpflegen :coffee:
Edit:
Meine neuste Erkenntnis:
Wenn man bei Kern 1+2 identische Werte setzt und bei Kern 3+4 auch noch mal dann kann man tatsächlich 2 verschiedene Turbo Stufen je nach Last fahren.
Also z.b.:
1-Core:46
2-Core:46
3-Core:45
4-Core:45
vier bzw. drei verschiedene Turbostufen über den Intel Werten funktionieren aber immer noch nicht, selbst mit den neusten 1.3er Betas nicht :wall:
ich habe ein G45 (UEFI Version 2.6) gekauft, und heute bemerkt, dass sich die integrierte Grafik nicht aktivieren lässt. Wenn ich im UEFI auf IGP umstelle, ist es nach einem reboot wieder auf PEG. Ich habe sogar mal ein CMOS Clear durchgeführt und ohne Grafikkarte im Slot gestartet, was aber auch nichts gebracht hat.
Hat jemand einen Tipp, oder ist es ein bekanntes Problem?
Welche Cpu hast du den?
Ist das nicht nur die Reihenfolge in welcher die Eingänge aktiviert werden?
Ich weiß es nicht, ist ja nicht gerade gut dokumentiert... Fakt ist, es funktioniert mit dem Board nicht. Habe sogar ein Gigabyte Z77X-D3H getestet, mit dem es einwandfrei funktioniert.
Hallo!
Ich poste nur ungern relativ "unvorbereitet" in diesen Thread, aber ich entdeckte gerade, dass es ihn gibt und hoffte hier auf Informationen.. ich hab seit gut einem halben Jahr das Z77-G43 mit einem i2500k, habe es aber jedes Mal, wenn ich mich damit beschäftigt habe (hauptsächlich zu Beginn) es nicht geschafft, die CPU meinen Wünschen entsprechend zu übertakten. Mein Problem war, dass ich entweder auf ~4ghz (oder so ähnlich kam), dann aber der Takt fest war und die Stromsparfunktionen nicht funktionierten oder aber letztere funktionierten, allerdings mit 3,7ghz als Maximaltakt.
Toll wäre natürlich, wenn mir jemand sagen könnte, exakt was für Einstellungen ich vornehmen sollte/könnte. Aber eine gute Anleitung/Erklärung zu den Einstellungen mit allgemeinen Tipps wären auch schonmal toll, aus den Biosmenüs werde ich mangels Fachkenntnissen nur bedingt schlau :/
hat hier jemand den direkten Vergleich zwischen den aktuellen Mainboards von GIGABYTE und MSI und kann etwas bezüglich der Qualität sagen?
Sowohl GIGABYTE als auch MSI werben ja mit besonders hochwertigen Komponenten, wobei GIGABYTE auch hinsichtlich der Platine wirbt (doppelte Kupferschicht o. ä.) - wie seht bzw. empfindet ihr das? Kann ein MSI Z77A-GD55 mit einem entsprechend teuren GIGABYTE-Modell mithalten oder dieses gar übertrumpfen?
Als ehemaliger Gigabyte und aktueller MSI Nutzer kann ich dir nur sagen das beide viel Geld in Kundenverarsche äh Marketing stecken, mehr aber auch nicht!
Kaufen werde ich mir aber beim nächsten mal trotzdem nichts mehr von denen!
Btw
Wie kann man die Spannung der internen GPU (HD4000) auslesen? Angeblich soll die ja auch eine variable VID wie die CPU haben.
Bios als auch diese wunderbaren schon fast nutzlosen MSI Tools zeigen auch nur 0,0V an.
Einstellbar ist 1V-1,5V, das Intel Maximum sollen 1,52V sein. Grillen kann man die interne GPU dann schon mal nicht, hat wohl jemand die OC Option dafür vergessen :haha:
Huhu,
kurze Frage, weiß jemand ob der Mugen 2 ohne Probleme auf ein Z77A-GD55 passt?
Der passt bestimmt. Habe selbst einen Silver Arrow SB-E drauf (gehabt).
Vom Layout sind GD55 und GD65 ja identisch.
Der Mugen 2 passte ohne Probleme :)
Noch ne kleine Frage, im BIOS habe ich nach der Lüftersteuerung für den CPU-Lüfter gesucht, weil der irgendwie andauernd auf Maximum lief. Ich habe dann den Punkt "CPU Smart Fan Target" gefunden und dort 60° eingetragen, danach ist darunter ein weiteres Feld aufgeplopt mit der min. Drehzahl des Lüfters, dort habe ich 12% eingestellt. Eine Sache wundert mich jetzt aber, der Lüfter dreht nie höher als 12% auch bei 57° in Prime. Heißt das nun dass die Drehzahl die man einstellen kann (in %) dann immer gilt bis zum Schwellenwert den man bei "CPU Smart Fan Target" gesetzt hat?
Solange der unter 60° bleibt, dreht er dann wohl auch nicht auf. Das mit dem Schwellenwert scheint mir plausibel wie du es beschreibst.
Mich wundert nur dass dort mindest Drehzahl steht, der Rest ist logisch ja, aber ich ging davon aus dass der Lüfter mit ansteigender Temperatur schneller wird und bei 60° dann auf 100% läuft.
Schneller sollte der auf jeden Fall werden!
Hast du mal ins Gehäuse rein geschaut, ob sich der Lüfter überhaupt dreht?!
Denn nicht jeder Lüfter kann "so langsam" drehen!!! Weil manche mehr Spannung zum Anlaufenbrauchen...
Wenn der Lüfter dauernd steht, wird sich die Anzeige auch nicht ändern. Bei mir ist z.B. ist ein ShadowWings PWM nicht bei 12% angelaufen, der E-Loop aber schon.
Die Idee ist, dass der Lüfter immer nur so schnell läuft, wie es nötig ist, um unter der eingestellten Zieltemperatur zu bleiben, dabei aber nie die Mindestdrehzahl unterschreitet. Die tatsächliche Drehzahl des Lüfters bei Erreichen der Zieltemperatur hängt dann von der Leistung ab, also wieviel Abwärme anfällt. Im Idealfall wird die eingestellte Zieltemperatur nie überschritten.
Das macht Sinn, mich stört das auch weniger, ich wollte es einfach nur verstehen.
@Andrejews: Ja der Lüfter dreht sich, ich habe ein Fenster im Seitenteil und kann ihn beobachten.
________________________________________________________________________________________
Na toll jetzt kam auch bei mir wie aus dem Nichts der Fehler mit dem Netzwerkadapter Code 10 und der Netzwerkadapter wird als 82579LM anstatt 82579V erkannt :(
Ich habe schon ein wenig gegoogelt und einiges versucht.
Vorab, mein Board hat das Bios V 1.5 ab Werk.
Der Fehler trat gestern nach einem Neustart des Rechners auf. Ich habe dann den Intel Lan Treiber Version 17.2 installiert, den ich zum Glück schon vorher von der MSI Seite heruntergeladen hatte. Nachdem der Treiber installiert war, ging sogar ohne Neustart direkt wieder alles.
Beim nächsten Neustart aber wieder das gleiche Problem Code 10 und es wird ein 82579LM erkannt, dann habe ich den Treiber über den Hardware Manager deinstalliert und die Version 17.4 installiert. Bis jetzt läuft noch alles, ich hoffe das bleibt jetzt auch so.
Ich habe auch nachgeschaut ob im Gehäuse unnötige "Mainboardpins" installiert sind die evtl. zu einem Kurzschluss führen könnten, aber dem ist nicht so.
Im Hardware Manager wurden mir bei dem Netzwerkadapter aber seltsamer weise 2 Geräte aufgeführt, einmal "Intel 82579V Gigabit Network Connection" so wie es sein sollte und zusätzlich aber ein "Microsoft Kerneldebugger Netzwerkadapter. Diesen habe ich ebenfalls deinstalliert und er wurde nach aufspielen des Treibers aber nicht mehr installiert.
Falls das Problem wieder auftreten sollte, soll ich es dann noch mit einem Bios Update versuchen oder das Board direkt umtauschen lassen?
Vielleicht könnt ihr mir weiterhelfen, ich bin gerade am Zusammenstellen eines neuen PCs und bin mir total unschlüssig bzgl. des Boards.
Zur Auswahl stehen entweder das Z77A-G43 oder Z77A-G45, da diese nur 10 Euro unterschied haben.
Als Prozessor wird ein i-5 3570k dienen. Grafikkarte bin ich mir noch nicht sicher, aber es wird auf jeden Fall nur eine werden.
Mir würde zwar eher das G45 zusagen, bin mir aber nicht sicher bzgl. der SATA Anschlüsse, da diese seitlich rausgehen. Das Gehäuse wird ein Lancool K62 werden.
Was würdet ihr mir raten?
Was soll denn an den seitlichen Sata Anschlüssen verkehrt sein? Das kann man bei dem Board nicht anders lösen, weil die Sata Anschlüsse genau auf der Höhe der Grafikkarte sind und eine längere Karte genau darüber sitzt, da kann man die Anschlüsse eben nur seitlich machen.
Mit dem Lancool K62 gibts da keine Probleme, ich habe das gleiche Gehäuse.
An deiner Stelle würde ich aber das GD55 nehmen, aus eigener Erfahrung kann ich nur davon abraten am Mainboard zu sparen.
Dann hab ich wohl noch zu viel gespart, wenn nicht einmal das GD65 einwandfrei läuft.
@Hibble
Was läuft nicht richtig an deinem GD65.
Momentan bin ich mir überhaupt nicht sicher, ob ich das MSI G45 oder ein Asrock Pro4 kaufen soll.
