[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
Ich bin größtenteils vom UEFI enttäuscht:
-APS funktioniert nicht mehr, wenn man irgendwelche Werte ändert.
-kein Offset für die Vcore
-z.T. freezt das UEFI einfach
-Mausbedienung ist auch teilweise buggy
-manchmal bleibt das System im post hängen
-Lanes kann man nicht manuell einstellen (bei mir ist die Soundkarte im untersten Slot => Grafikkarte bekommt nur 8 Lanes, weil das Board in den Multi-GPU Modus schaltet)
seit dem UEFI Update:
-ein paar OC Profile sind überhaupt nicht mehr beschreibbar
Für das was das Board gekostet hat, hätte ich echt mehr erwartet.
Kann ich verstehen, dass man dann ein wenig genervt ist, wird aber wohl bei den anderen Board Herstellern nicht besser sein.
UEFI hab ich bis jetzt noch nie live gesehen, nur von Videos bzw. Screenshots.
Wie wichtig ist es den Offset beim vcore einzustellen?
Offset ist eigentlich dafür wichtig, dass das Board im idle sparsam ist.
Unter Last: Vcore(load) + Offset
idle: Vcore(idle) + Offset
Bei MSI ist Vcore(idle) = Vcore(load) wenn Vcore nicht auf Auto gestellt ist.
ABER!!! MSI ist trotzdem übertaktet im idle sparsamer als andere Boards mit Offset. Es gibt da ein paar Vergleiche am Anfang dieses Threads.
Und, man kann, wenn Vcore = Auto ist und das fürs persönliche OC reicht (also z.B. 4,2GHz) ca. 5W im idle sparen. Das hatte ich mal vermessen und hier gepostet.
@mibo
Danke für deine Erklärung.
Hmpf.... mein Board geht wieder zurück, der Netzwerkanschluss fällt immer noch sporadisch aus und das Mainboard hat angefangen zu fiepen.
Ich habe ein GD65 und eine XFX 6870.
Ich nutze den Onboard Sound.
Wenn ich im Browser scrolle, höre ich das ganz leicht in den boxen.
Richtig schlimm wird es aber, wenn die graka unter Last ist. Beim zocken brummt es in verschiedenen Tonlagen, je nachdem, was gerade passiert.
nutzt hier noch jemand den onboard Sound?
Gesendet mit der Hardwareluxx App
Bei meinem GD55 haben die Boxen gebrummt wenn ein Youtube Video geöffnet war und ich die Maus bewegt habe, egal ob im Browser selbst oder auf dem Desktop. Wenn ich den Cursor auf dem Video selbst bewegt habe, war das Geräusch wirklich sehr laut. Ich dachte erst es wären die Boxen, aber ich habe dann ein anderes Soundsystem getestet und konnte dies ausschließen.
Naja ich bin eher froh dass ich das Brett jetzt wieder los bin, hoffentlich macht das neue Gigabyte Z77X-UD3H keine Probleme.
Hatte bei meinem G43 auch leichtes Brummen und Skrollgeräusche als ich Onboard Sound getestet habe.
Hab dann wieder die X-Fi eingebaut und werde auch in Zukunft wohl auf dedizierte Soundlösungen setzen.
Auf meinem GD80 läuft APS auch mit OC wie ich seit dieser Woche zufällig festgestellt habe. Ob MSI hier was gefixt hat oder ob ich die letzten Monate auch zur unten beschriebene Gruppe der 99% dazu gezählt habe kann ich aber nicht sagen, ein Bios Downgrade werde ich jedenfalls nicht mehr machen um das fest zu stellen.
APS funktioniert nicht weil 99% der Leute falsch OCen dank MSIs tausend Möglichkeiten die sich gegenseitig dann wieder deaktivieren obwohl es sich um die gleiche Einstellung handelt! Dokumentation vom Bios gibt es ja leider heute nicht mehr und auch der Support ist planlos hoch 2.
Stattdessen schaut man dann als MSI Nischenkunde mal zur Konkurrenz ins Forum und übernimmt dort planlos Einstellungen die eben bei MSI anders gelöst wurden.
VCore CPU und GPU muss auf "Auto" sein, normaler Multiplikator auch auf "Auto" stattdessen macht man das OC einzig über die Turbo Multiplikatoren! Hierzu muss zusätzlich jedoch der erweiterte Turbo deaktiviert sein, stattdessen einfach 4x die gleichen Werte eintragen (nichts anderes bewirkt der erweiterte Turbo).
Mit 3 verschiedenen Multis je nach Auslastung wie von Intel vorgesehen bekommt der Laden aber bis heute nicht hin wenn man selbst die Multis ändert. Ansonsten kannst du an allen Spannungen und Takten drehen wie du willst, APS läuft trotzdem!
APS spart bei mir noch mal ~7Watt zusätzlich ein. Daher kann ich die 2-5 Watt Mehrverbrauch wie man hier liest mit fester Vcore auch nicht nachvollziehen. Die 1-2 Watt von Leuten die sich ihr Board dadurch schön reden müssen schon gar nicht.
Mit fester VCore und damit automatische deaktiviertem APS habe ich min. 15Watt mehr bei meinem System im Leerlauf!
Macht also rein auf die CPU bezogen immer noch seine 7-8Watt mehr bei mir aus.
Mein i7-3770K taktet jedenfalls aktuell von 1600-4600 hoch/runter und das sogar in Zwischenschritten, senkt die Spannung von ~1,231V auf ~0,951V inkl. funktionsfähiger Phasenabschaltung wie mir die blinkenden LEDs und auch mein Verbrauchsmesser zeigen!
"Vdroop" Einstellung missbrauchen.
+100% bringen bei mir unter Last gut gerundete +0,1Volt, nicht viel aber besser wie nichts.
Edit: brummen im Sound habe und hatte ich auch noch nie, bei keinem einzigen meiner Bretter!
Ich bin glücklich mit dem Onboardsound, meiner ex Creative Karte trauere ich nicht nach.
meistens kommt bei verbauten MSI-Boards das Brummen/Pfeifen beim Scrollen etc ja nicht aus den Lautsprechern, sondern vom Netzteil ...
Das kommt tausendprozentig aus den Lautsprechern!
Kann ich richtig schön laut drehen...
Mein BeQuiet ist oben auf dem Schreibtisch nicht zu hören.
Ich habe mir Gestern das gd55 geholt und als ich gucken wollte ob alle Pins gerade sind ist mir aufgefallen, dass in der Mitte des Sockels, wo die Silbernen Blöcke sind, irgendwie einer Fehlt. Ist das bei euch auch so/ ist das normal?
Edit: Mein Profilbild ist das Foto davon.
Auf dem "Mini-Wischiwaschi"-Bild kann man nicht viel erkennen und schon garnicht einen einzelnen Pin.
:xmas:
Meinst du jetzt tatsächlich einen Pin (also einen Kontakt) oder einen der SMD-Kondensatoren?
:asthanos:
Für mich sieht es nach einem SMD Bauteil aus.
Es gibt Boards, wo von den Dingern mehr als einer fehlt (bzw. sind sie auf der Rückseite des Sockels angeordnet o. ä.) und ist kein Anlass zur Beunruhigung. ;)
Ja ich meinte die SMD-Kondensatoren, wusste nicht wie die heißen :/ und danke jetzt bin ich beruhigt, dachte schon da wäre einer abgefallen oder so...
Sent from my iPod touch using Hardwareluxx app
ich habe hier ein Z77A-GD65 auf dem tisch liegen, sobald ich den cpu-multi verändere senkt der sich in idle nicht mehr ab. spannung geht runter auf 0,9xxv, takt bleibt bei 4ghz. alle energie-spar-optionen sind an.
normal???
Wie ich gerade feststelle, senkt sich bei mir nicht mal die Spannung. Also scheinbar das gleiche Problem.
Welches BIOS hast Du denn?
das neuste bios ist drauf, ging aber mit der version davor auch schon nicht. schau mal bei den "eco" einstellungen. da muß alles enabled sein.
Adjust CPU Ratio in OS muss disabled sein^^ hatte ein ähnliches Problem
Unter ECO habe ich EuP 2013 aus, Rest an/Auto
Hallo ich habe ein frage zum MSI Military Class 3.Ich habe im Bios stat denn d Mode habe ich denn i Mode angemacht.
Ich weis nicht mer was ich tun soll er geht nicht mer in das Bios 1 rein trotz cmos reset.Ich habe auch schon die Bios
Batterie rausgenommen hatt nichtz genüzt,kann mann vileicht Beide Biose irgendwie flashen das er dann vileicht die
Standart Settings ladet.
Cmos Reset ohne Strom dran? Andere Tasta? Also USb Ps2 gewechselt?
Am cmos Rest hatte ich nur mit Strom also System aus aber Strom dran.
Also USb Ps2 gewechselt?/Das verstehe ich ned wie meinst du das ?
Andere Tastatur mit PS/2 oder Usb Anschluss manchmal geht es damit.
Achso ne das hatt alles nichtz gebracht.Dann soll ich jetz ma ein cmos reset durch führen ohne strom.
Schrit (1) Strom Cable ziehen.
Schrit (2) Batterie Raus nehmen.
Schrit (3) Halbestunde warten.
Schrit (4) Einschalten wenns geht supper wenns ned geht scheise.
Past so oder.
---------- Post added at 14:07 ---------- Previous post was at 13:57 ----------
Alles danke nochma für die schnelle antworten und tipps.:bigok:
Past so oder.
Hast du es schon mal mit Fast Boot probiert?
(Einfach auf "Go2BIOS" klicken. Nach dem Neustart geht der automatisch ins BIOS rein.)
O ne das hab ich noch ned Probiert wird gleich getestet .
---------- Post added at 15:49 ---------- Previous post was at 15:44 ----------
Das Problem ist das derzeit nur Bios 2 leuft.Wenn Ich auf Bios 1 umschalte dann kommt nur ein Schwazes Bild.Das Bios 2 leuft ohne Probleme.
Hm, das ist echt seltsam.
Also z.B. für das GD65 gibt's grad ein Beta BIOS, das beide Chips flasht. Vielleicht kannst du das so "überbügeln"?
Mehr Infos gibt's im MSI-Forum: BIOS und Firmware für Z77A-GD65 - EFI-Sektion - MSI Forum
Dort wird dir vielleicht eher Jemand, bei konkreten BIOS Problemen, helfen können.
(Zur Not kannst du "Notnagel" direkt anschreiben.)
Das bringt mir ja auch nichtz ich muss in das Bios 1.Der bringt mir kein Bild.Wenn ich Bios 2 starte dann geht alles.
