CPU-Z TXT Report
Binaries
CPU-Z version 1.66.1.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.416 MHz
Sys timer 1.000 KHz
BCLK timer 99.94 MHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 4770K
Codename Haswell
Specification Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84 Watts
Core Speed 799.5 MHz
Multiplier x Bus Speed 8.0 x 99.9 MHz
Stock frequency 3500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 35x
Max turbo ratio 39x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 39x
Ratio 2 cores 39x
Ratio 3 cores 38x
Ratio 4 cores 37x
TSC 3498.0 MHz
APERF 1998.9 MHz
MPERF 3497.9 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020201h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x00100800 0x7FDAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x000027AB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3737342D 0x43204B30 0x40205550
0x80000004 0x352E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012300
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x25262727
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88460800
MSR 0x000001FC 0x00000000 0x0004005F
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00101414 0x000002F8
MSR 0x00000610 0x00428348 0x001A82A0
MSR 0x00000611 0x00000000 0x041C6072
MSR 0x00000639 0x00000000 0x0175DC7C
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x01A3942A
MSR 0x00000614 0x00000000 0x000002A0
MSR 0x0000019C 0x00000000 0x88480000
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x00001798 0x00000A00
MSR 0x00000199 0x00000000 0x00000A00
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x01100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x041C70A4
MSR 0x00000639 0x00000000 0x0175E37B
MSR 0x00000619 0x00000000 0x01A3980F
MSR 0x0000019C 0x00000000 0x88460000
MSR 0x00000198 0x00001836 0x00000C00
MSR 0x00000199 0x00000000 0x00000C00
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020201h
CPUID
0x00000001 0x000306C3 0x02100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0x041C8B54
MSR 0x00000639 0x00000000 0x0175F16F
MSR 0x00000619 0x00000000 0x01A39C67
MSR 0x0000019C 0x00000000 0x88490000
MSR 0x00000198 0x000016D2 0x00000800
MSR 0x00000199 0x00000000 0x00000800
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x03100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0x041CA939
MSR 0x00000639 0x00000000 0x01760274
MSR 0x00000619 0x00000000 0x01A3A0F3
MSR 0x00000198 0x00001770 0x00000A00
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020201h
CPUID
0x00000001 0x000306C3 0x04100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x041CC649
MSR 0x00000639 0x00000000 0x017612BE
MSR 0x00000619 0x00000000 0x01A3A58B
MSR 0x00000198 0x0000178E 0x00000A00
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x05100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x041CE6CB
MSR 0x00000639 0x00000000 0x017625A8
MSR 0x00000619 0x00000000 0x01A3AA5C
MSR 0x00000198 0x000016CA 0x00000800
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020201h
CPUID
0x00000001 0x000306C3 0x06100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x000001B1 0x00000000 0x88450800
MSR 0x00000611 0x00000000 0x041D0855
MSR 0x00000639 0x00000000 0x017639B2
MSR 0x00000619 0x00000000 0x01A3AF2A
MSR 0x00000198 0x00001799 0x00000A00
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x07100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x041D2AD1
MSR 0x00000639 0x00000000 0x01764E9D
MSR 0x00000619 0x00000000 0x01A3B406
Chipset
Northbridge Intel Haswell rev. 06
Southbridge Intel Z87 rev. C2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16 GBytes
Channels Dual
Memory Frequency 799.5 MHz (1:6)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 240
Command Rate (CR) 1T
Uncore Frequency 799.6 MHz
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000)
Size 8192 MBytes
Max bandwidth PC3-12800H (800 MHz)
Part number BLS8G3D1609DS1S00.
Serial number A60B2732
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.3
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-22 @ 444 MHz
JEDEC #2 6.0-6-6-16-26 @ 533 MHz
JEDEC #3 7.0-7-7-19-31 @ 622 MHz
JEDEC #4 8.0-8-8-22-35 @ 711 MHz
JEDEC #5 9.0-9-9-24-39 @ 800 MHz
JEDEC #6 10.0-10-10-27-44 @ 888 MHz
JEDEC #7 11.0-11-11-30-48 @ 977 MHz
XMP profile XMP-1600
Specification PC3-12800H
Voltage level 1.500 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 46.25 ns
Min tRFC 300.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 5.0-5-5-14-21-2T @ 444 MHz (1.500 Volts)
XMP #2 6.0-6-6-16-25-2T @ 533 MHz (1.500 Volts)
XMP #3 7.0-7-7-19-29-2T @ 622 MHz (1.500 Volts)
XMP #4 8.0-8-8-22-33-2T @ 711 MHz (1.500 Volts)
XMP #5 9.0-9-9-24-37-2T @ 800 MHz (1.500 Volts)
XMP #6 10.0-10-10-27-42-2T @ 888 MHz (1.500 Volts)
XMP #7 11.0-11-11-30-46-2T @ 977 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Serial number A60B2753
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 46.25 ns
Min tRFC 300.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 93 11 0B 02 04 21 00 09 03 52 01 08 0A 00 FE 00
10 5A 78 5A 28 5A 10 F0 86 60 09 3C 3C 00 F0 82 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 85 9B 00 00 00 A6 0B 27 32 C5 80
80 42 4C 53 38 47 33 44 31 36 30 39 44 53 31 53 30
90 30 2E 01 00 80 2C 4E 33 31 34 50 46 57 FF 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0C 4A 01 13 01 08 00 00 11 2A 0A 5A FE 00 5A 5A
C0 5A 78 10 F0 72 3F 00 60 09 3C 30 00 F0 3C 00 00
D0 10 00 26 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
70 00 00 00 00 00 85 9B 00 00 00 A6 0B 27 53 C5 80
Monitoring
Mainboard Model Z87-C (0x00000139 - 0x0002D0B0)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6791
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC8
LPCIO Revision ID 0x3
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 08 66 10 00 FF FF
20 C8 03 FF 00 00 00 00 00 10 FF 40 00 00 02 00 03
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 0A 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Register space class = 0x8, base address = 0x0A00
Hardware Monitors
Hardware monitor Nuvoton NCT6791D
Voltage 0 5.04 Volts [0x7E] (+5V)
Voltage 1 3.36 Volts [0xD2] (+3.3V)
Voltage 2 12.19 Volts [0x7F] (+12V)
Voltage 3 0.86 Volts [0x6C] (VIN3)
Voltage 4 0.08 Volts [0x5] (VIN4)
Voltage 5 1.78 Volts [0x6F] (VCORE)
Temperature 0 26°C (78°F) [0x1A] (Mainboard)
Temperature 1 30°C (86°F) [0x1E] (CPU)
Fan 1 925 RPM [0x39D] (Chassis #2)
Fan 2 1607 RPM [0x647] (Chassis #3)
Fan 3 1318 RPM [0x526] (CPU)
00 6F 7E D2 D2 7F F8 00 D9 D3 7F 00 6C 06 00 00 00
10 1A 1E 80 80 21 7F 00 2A 80 1E 1E 1E 1E 80 80 0F
20 1A 00 99 4F 99 99 00 00 00 00 00 00 00 00 FF 1F
30 1E 1F 2D 1F 1A 1F FF 1F 1F 1F 00 00 05 7C 03 9F
40 06 43 00 00 05 34 00 00 00 00 00 00 99 4E 99 99
50 FF FF 1E 80 00 00 00 00 00 00 00 00 00 00 00 00
70 00 1E 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0C00
Revision ID 0x06
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 00 0C 06 00 90 20 06 00 00 06 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 34 85
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
50 03 00 00 00 09 00 00 00 04 00 00 00 01 00 00 DF
60 05 00 00 F8 00 00 00 00 01 80 D1 FE 00 00 00 00
70 00 00 00 FF 03 00 00 00 00 0C 00 FF 7F 00 00 00
80 10 11 11 00 00 00 11 00 1A 00 00 00 00 00 00 00
90 01 00 00 FF 03 00 00 00 01 00 F0 1E 04 00 00 00
A0 01 00 00 00 04 00 00 00 01 00 00 1F 04 00 00 00
B0 01 00 00 E0 01 00 00 E0 01 00 00 DF 01 00 00 E0
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 09 00 0C 01 6D 80 80 62 D0 00 44 36 00 00 00 00
F0 00 00 00 00 C8 0F 03 00 00 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0C01
Revision ID 0x06
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps class Subsystem Vendor
Caps offset 0x88
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps class Power Management
Caps offset 0x80
Caps version 1.2
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class PCI Express
Caps offset 0xA0
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
PCI registers
00 86 80 01 0C 07 00 10 00 06 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 20
20 00 F6 00 F7 01 E8 F1 F1 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 18 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
80 01 90 03 C8 08 00 00 00 0D 80 00 00 43 10 34 85
90 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 42 01 01 80 00 00 20 00 00 00 03 AD 61 02
B0 40 00 01 D1 80 25 0C 00 00 00 40 00 00 00 00 00
C0 00 00 00 00 80 0B 08 00 00 64 00 00 0E 00 00 00
D0 43 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 60 01 D0 4E 01 01 40 00 00 00 00 00 00 10 00
Description USB Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C31
Revision ID 0x05
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF7200000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x70
Caps version 1.1
PCI capability
Caps offset 0x80
PCI registers
00 86 80 31 8C 06 04 90 02 05 30 03 0C 00 00 00 00
10 04 00 20 F7 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 70 00 00 00 00 00 00 00 00 01 00 00
40 FD 00 00 80 01 C4 0F 80 00 00 00 00 00 00 00 00
50 9F 6E 88 07 00 00 00 00 00 00 00 00 00 00 00 00
60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 01 80 C2 C1 08 00 00 00 00 00 00 00 00 00 00 00
80 05 00 B7 00 0C F0 EF FE 00 00 00 00 A8 49 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 01 00 00 00 20 00 00 00 00 00 00 00 00 00 00
B0 0F 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 03 0C 30 C0 03 0C 30 00 03 0C 30 00 00 00 00 00
D0 FF 3F 00 00 FF 3F 00 00 3F 00 00 00 3F 00 00 00
E0 A0 00 00 00 00 00 00 00 00 00 00 00 D8 D8 D8 08
F0 00 00 00 00 00 00 00 00 B1 0F 06 08 00 00 00 00
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C3A
Revision ID 0x04
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF721A000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x8C
PCI registers
00 86 80 3A 8C 06 00 10 00 04 00 80 07 00 00 80 00
10 04 A0 21 F7 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 45 02 00 1E 10 00 01 80 06 23 00 66 F0 3F 00 10
50 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
60 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 05 00 80 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
C0 55 D9 46 C0 38 60 05 52 76 F6 63 4E 79 FF 87 8E
D0 07 10 99 F0 1C 95 6D 24 31 94 AE E6 67 B7 F5 B6
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C2D
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF7218000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 2D 8C 06 00 90 02 05 20 03 0C 00 00 00 00
10 00 80 21 F7 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 14 01 00 00
40 00 00 00 00 DB 05 7C 2B 00 00 00 00 00 00 00 00
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 81 07 00 00 00 00 01 00 00 01 00 20 00 00
70 00 00 DF 3F 03 0C 30 00 4F 01 00 00 8C 40 00 00
80 00 00 80 00 11 88 0C 93 70 0D 00 24 01 04 02 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 7A DF 27 00 00 00
E0 00 00 00 00 FF FF FF FF FF FF FF FF A4 FF 7E B7
F0 00 00 00 00 88 85 80 00 B1 0F 06 08 08 17 1A 20
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C20
Revision ID 0x05
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF7210000
Subvendor ID 0x1043
Subsystem ID 0x85B0
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
PCI registers
00 86 80 20 8C 06 00 10 00 05 00 03 04 10 00 00 00
10 04 00 21 F7 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 B0 85
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 03 00 00 17 00 00 00 00 00 00 00 00 00 80 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 04 02 01 00 60 00 00 00 0C 85 82 10 00 33 02
D0 00 0C 85 02 10 00 33 02 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C10
Revision ID 0xD5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 1
Version 2.0
Physical slot Integrated device
Link width 0x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0xA0
Caps version 1.2
PCI registers
00 86 80 10 8C 04 00 10 00 D5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 20
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 00 00
40 10 80 42 00 00 80 00 00 00 00 10 00 12 4C 31 01
50 00 00 01 18 60 00 04 00 00 00 40 00 00 00 00 00
60 00 00 00 00 17 08 08 00 00 04 00 00 00 00 00 00
70 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 43 10 34 85 00 00 00 00 00 00 00 00
A0 01 00 03 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 01 00 08 00 00 02 00 11 09 00 00 00 00
F0 50 00 00 00 80 F5 00 00 B1 0F 06 08 01 28 02 41
Location bus 0 (0x00), device 28 (0x1C), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x8C14
Revision ID 0xD5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps offset 0x40
Port 3
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0xA0
Caps version 1.2
PCI registers
00 86 80 14 8C 07 00 10 00 D5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 03 03 00 D0 D0 00 00
20 10 F7 10 F7 11 F2 11 F2 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 12 03 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 32 03
50 40 00 11 70 00 B2 14 00 00 00 40 00 00 00 00 00
60 00 00 00 00 17 08 00 00 00 04 00 00 00 00 00 00
D0 00 00 00 01 42 18 00 00 08 80 11 8B 00 00 00 00
E0 00 00 00 00 03 90 03 90 10 00 00 00 00 00 00 00
F0 50 00 00 00 40 00 00 0C B1 0F 06 08 00 28 00 03
Location bus 0 (0x00), device 28 (0x1C), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xD5
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x13
Int. Pin 0x04
PCI capability
Caps offset 0x40
Port 4
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0xA0
Caps version 1.2
PCI registers
00 86 80 4E 24 07 00 10 00 D5 01 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 04 05 00 F0 00 00 20
30 00 00 00 00 40 00 00 00 00 00 00 00 13 04 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 32 04
50 00 00 11 30 00 B2 1C 00 00 00 40 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00
F0 50 00 00 00 40 00 00 0C B1 0F 06 08 00 28 00 04
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C26
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF7217000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 26 8C 06 00 90 02 05 20 03 0C 00 00 00 00
10 00 70 21 F7 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
40 00 00 00 00 DB 05 92 09 00 00 00 00 00 00 00 00
60 20 20 01 06 00 00 00 00 01 00 00 01 00 20 00 00
70 00 00 DF 3F 03 0C 30 C0 4F 01 00 00 8C 40 00 00
D0 00 00 00 00 00 AA FF 00 00 00 FD 66 27 00 00 00
E0 00 00 00 00 FF FF FF FF FF FF FF FF C0 D0 EC E9
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C44
Revision ID 0x05
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 44 8C 07 00 10 02 05 00 01 06 00 00 80 00
40 01 18 00 00 80 00 00 00 01 1C 00 00 10 00 00 00
50 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 8B 8A 86 85 90 00 00 00 83 8F 8E 87 F8 F0 00 00
70 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0
80 10 00 0E 3C 91 02 0C 00 01 0A 7C 00 00 00 00 00
90 29 FF 0C 00 00 0F 00 00 00 00 00 00 00 00 00 00
A0 10 06 A0 18 09 38 06 00 00 46 00 00 00 00 01 80
D0 33 22 11 00 67 45 00 00 CF FF 00 00 2A 00 00 00
E0 09 00 0C 10 00 00 00 00 01 E8 00 91 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 B1 0F 06 08 00 00 00 00
Description Serial ATA Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x8C02
Revision ID 0x05
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F070
Address 1 (port) 0x0000F060
Address 2 (port) 0x0000F050
Address 3 (port) 0x0000F040
Address 4 (port) 0x0000F020
Address 5 (memory) 0xF7216000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x02
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x12
Caps offset 0xA8
PCI registers
00 86 80 02 8C 07 04 B0 02 05 01 06 01 00 00 00 00
10 71 F0 00 00 61 F0 00 00 51 F0 00 00 41 F0 00 00
20 21 F0 00 00 00 60 21 F7 00 00 00 00 43 10 34 85
30 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
70 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 01 00 0C F0 EF FE B0 49 00 00 00 00 00 00
90 60 3C 03 83 83 01 00 3C 20 02 5C 20 20 00 00 80
A0 A8 00 00 00 00 00 00 00 12 00 10 00 48 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x8C22
Revision ID 0x05
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF7215000
Address 4 (port) 0x0000F000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x06
Int. Pin 0x03
PCI registers
00 86 80 22 8C 03 00 80 02 05 00 05 0C 00 00 00 00
10 04 50 21 F7 00 00 00 00 00 00 00 00 00 00 00 00
20 01 F0 00 00 00 00 00 00 00 00 00 00 43 10 34 85
30 00 00 00 00 00 00 00 00 00 00 00 00 06 03 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x1184
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF6000000
Address 1 (memory) 0xE8000000
Address 3 (memory) 0xF0000000
Address 5 (port) 0x0000E000
Subvendor ID 0x1462
Subsystem ID 0x2825
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type PCI-E Endpoint Device
Port 0
Version 2.0
PCI capability
Caps offset 0xB4
PCI registers
00 DE 10 84 11 07 00 10 00 A1 00 00 03 10 00 80 00
10 00 00 00 F6 0C 00 00 E8 00 00 00 00 0C 00 00 F0
20 00 00 00 00 01 E0 00 00 00 00 00 00 62 14 25 28
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
40 62 14 25 28 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 B4 02 00 E1 8D 2C 01
80 30 29 00 00 03 3D 45 00 40 01 01 11 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
A0 00 00 00 00 0E 00 00 00 03 00 3F 00 00 00 00 00
B0 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0E0A
Revision ID 0xA1
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF7080000
Subvendor ID 0x1462
Subsystem ID 0x2825
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Port 0
Version 2.0
PCI registers
00 DE 10 0A 0E 06 00 10 00 A1 00 03 04 10 00 80 00
10 00 00 08 F7 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 25 28
30 00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
50 00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 02 00 E1 8D 2C 01
80 20 29 00 00 03 3D 45 00 40 01 01 11 00 00 00 00
A0 00 00 00 00 0E 00 00 00 00 00 3F 00 00 00 00 00
Description Ethernet Controller
Location bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x11
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000D000
Address 2 (memory) 0xF7100000
Address 4 (memory) 0xF2100000
Subvendor ID 0x1043
Subsystem ID 0x859E
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
PCI registers
00 EC 10 68 81 07 04 10 00 11 00 00 02 10 00 00 00
10 01 D0 00 00 00 00 00 00 04 00 10 F7 00 00 00 00
20 0C 00 10 F2 00 00 00 00 00 00 00 00 43 10 9E 85
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 02 02 C0 8C 90 05 00 50 10 00 11 7C 47 00
80 40 01 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 1F 08 0C 00 10 04 00 00 02 00 00 00
B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1080
Revision ID 0x03
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x04
Secondary bus 0x05
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0xC0
SubVendor ID 0x1043
SubSystem ID 0x8489
PCI registers
00 21 1B 80 10 07 00 10 00 03 01 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 04 05 05 20 F1 01 20 20
30 00 00 00 00 C0 00 00 00 00 00 00 00 13 01 00 00
40 60 60 00 00 00 07 00 00 00 00 00 00 A7 27 00 00
C0 0D 00 00 00 43 10 89 84 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 1205
date 06/26/2013
ROM size 8192 KB
DMI System Information
manufacturer ASUS
product All Series
version System Version
serial System Serial Number
UUID {309F7740-D7DA-11DD-8F43-AC220B81C773}
SKU All
family ASUS MB
DMI Baseboard
vendor ASUSTeK COMPUTER INC.
model Z87-C
revision Rev 1.xx
serial 130713610301974
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Port Connector
designation PS/2 Keyboard (internal)
designation PS/2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB7_8 (internal)
designation USB7_8 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation SPDIF_O_HDMI_DP (internal)
designation SPDIF_O_HDMI_DP (external)
port type Video Port
DMI Port Connector
designation DVI (internal)
designation DVI port (external)
DMI Port Connector
designation USB3_56 (internal)
designation USB3_E12 (external)
port type USB
DMI Port Connector
designation USB3_34 (internal)
port type USB
DMI Port Connector
designation Realtek LAN (internal)
designation Realtek LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation AUDIO (internal)
designation AUDIO (external)
port type Audio Port
DMI Port Connector
designation SATA6G_1 (internal)
DMI Port Connector
designation SATA6G_2 (internal)
DMI Port Connector
designation SATA6G_3 (internal)
DMI Port Connector
designation SATA6G_4 (internal)
DMI Port Connector
designation SATA6G_5 (internal)
DMI Port Connector
designation SATA6G_6 (internal)
DMI Port Connector
designation USB3_12 (internal)
port type USB
DMI Port Connector
designation USB9_10 (internal)
port type USB
DMI Port Connector
designation USB11_12 (internal)
port type USB
DMI Port Connector
designation USB13_14 (internal)
port type USB
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation SPDIF_OUT (internal)
DMI Port Connector
designation AAFP (internal)
connector Mini Jack (headphones)
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation CPU_OPT_FAN (internal)
DMI Port Connector
designation CHA_FAN1 (internal)
DMI Port Connector
designation CHA_FAN2 (internal)
DMI Port Connector
designation CHA_FAN3 (internal)
DMI Extension Slot
designation PCIEX1_1
type A5
populated no
DMI Extension Slot
designation PCIEX16_1
type A5
populated yes
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIEX16_2
type A5
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIEX1_2
type A5
populated no
DMI OEM Strings
string[0] To Be Filled By O.E.M.
string[1] To Be Filled By O.E.M.
string[2] Audi
string[3] To Be Filled By O.E.M.
DMI Memory Device
designation ChannelA-DIMM0
format DIMM
type unknown
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32768 MBytes
max# of devices 4
DMI Memory Device
designation ChannelA-DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation ChannelB-DIMM0
format DIMM
type unknown
DMI Memory Device
designation ChannelB-DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
clock speed 3500.0 MHz
FSB speed 100.0 MHz
multiplier 35.0x
Storage
Drive 0
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_840_evo_250g#4&e937c7&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name Samsung SSD 840 EVO 250G
Capacity 232.9 GB
SMART Support Yes
USB Devices
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8008
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8000
USB Device USB-Verbundgerät, class=0x00, subclass=0x00, vendor=0x1E7D, product=0x319C
USB Device USB 2.0-Hub, class=0x09, subclass=0x00, vendor=0x1A40, product=0x0101
USB Device USB-Verbundgerät, class=0x00, subclass=0x00, vendor=0x04E8, product=0x341B
USB Device USB-Verbundgerät, class=0xEF, subclass=0x02, vendor=0x0C45, product=0x6300
USB Device USB 2.0-MTT-Hub, class=0x09, subclass=0x00, vendor=0x1A40, product=0x0201
USB Device USB-Verbundgerät, class=0x00, subclass=0x00, vendor=0x1E7D, product=0x2E22
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 770
Revision A2
Codename GK104
Technology 28 nm
Memory size 2 GB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1462)
Model ID 0x1184 (0x2825)
Performance Level 0
Win32_VideoController AdapterRAM = 0x80000000 (2147483648)
Win32_VideoController DriverVersion = 9.18.13.2063
Win32_VideoController DriverDate = 07/10/2013
Software
Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
ACPI
ACPI Tree
_GPE
_L08
_L1F
_L1D
_L0B
_L09
_L0D
_L01
_L02
_L06
_L07
_L00
_PR_
CPU0
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
HI0_
HC0_
_PDC
_OSC
CPDC
COSC
GCAP
C1TM
C3TM
C6TM
C7TM
CDTM
MWES
AC2V
AC3V
C3ST
C2ST
C1ST
CSTF
GEAR
_CST
CPU1
HI1_
HC1_
_PDC
_OSC
GCAP
APCT
APPT
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
CPU2
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
CPU3
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
CPU4
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
CPU5
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
CPU6
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
CPU7
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
PSDF
_PSD
HPSD
SPSD
_CST
PPMT
PGRV
CFGD
ACRT
APSV
AAC0
CPID
CPPC
CCTP
CLVL
CBMI
PL10
PL20
PLW0
CTC0
TAR0
PPC0
PL11
PL21
PLW1
CTC1
TAR1
PPC1
PL12
PL22
PLW2
CTC2
TAR2
PPC2
C3MW
C6MW
C7MW
CDMW
C3LT
C6LT
C7LT
CDLT
CDLV
CDPW
MPMF
_SB_
PR00
AR00
PR04
AR04
PR05
AR05
PR06
AR06
PR07
AR07
PR08
AR08
PR09
AR09
PR0E
AR0E
PR0F
AR0F
PR02
AR02
PR0A
AR0A
PR0B
AR0B
PR10
AR10
PRSA
PRSB
PRSC
PRSD
PRSE
PRSF
PRSG
PRSH
PCI0
_HID
_CID
_ADR
_BBN
_UID
_PRT
HBUS
EPEN
EPBR
MHEN
MHBR
GCLK
D0EN
D1F2
D1F1
D1F0
PXEN
PXSZ
PXBR
DIEN
DIBR
MEBR
PM0H
PM1L
PM1H
PM2L
PM2H
PM3L
PM3H
PM4L
PM4H
PM5L
PM5H
PM6L
PM6H
TUUD
TLUD
HTSE
MCHT
BUF0
_CRS
GUID
SUPP
CTRL
XCNT
_OSC
AR00
PR00
AR02
PR02
AR04
PR04
AR05
PR05
AR06
PR06
AR07
PR07
AR08
PR08
AR09
PR09
AR0E
PR0E
AR0F
PR0F
AR0A
PR0A
AR0B
PR0B
TPMX
_HID
_UID
CRS_
_CRS
_STA
LPCB
_ADR
LPC1
LPC0
IOD0
IOD1
GR03
GR08
GR09
GR0A
GR0B
GR19
RAEN
RCBA
DMAC
_HID
_CRS
FWHD
_HID
_CRS
HPET
_HID
_UID
BUF0
_STA
_CRS
IPIC
_HID
_CRS
MATH
_HID
_CRS
_STA
LDRC
_HID
_UID
BUF0
_CRS
RTC_
_HID
_CRS
TIMR
_HID
_CRS
CWDT
_HID
_CID
BUF0
_STA
_CRS
SIO1
_HID
_UID
CRS_
_CRS
DCAT
MUT0
ENFG
EXFG
LPTM
UHID
IOID
INDX
DATA
LDN_
SCF1
SCF2
SCF3
SCF4
SCF5
SCF6
CKCF
ACTR
IOAH
IOAL
IOH2
IOL2
INTR
INTT
DMCH
RGE0
RGE1
RGE2
RGE3
RGE4
RGE5
RGE6
RGE7
RGE8
RGE9
OPT0
OPT1
OPT2
OPT3
OPT4
OPT5
OPT6
OPT7
OPT8
OPT9
CGLD
DSTA
DCNT
CRS1
IRQM
DMAM
IO11
IO12
LEN1
CRS2
IRQE
DMAE
IO21
IO22
LEN2
IO31
IO32
LEN3
DCRS
DCR2
DSRS
DSR2
PMFG
SIOS
SIOW
OACS
OACG
SIOH
RMSC
_HID
_UID
CRS1
CRS2
_CRS
UAR1
_UID
_HID
_STA
_DIS
_CRS
_SRS
_PRS
_PRW
PS2K
_HID
_CID
_STA
_CRS
_PRS
_PSW
_PRW
PS2M
_HID
_CID
_STA
CRS1
CRS2
_CRS
_PRS
_PSW
_PRW
CPSB
RTCX
SBB0
SBB1
SBB2
SBB3
SBB4
SBB5
SBB6
SBB7
SBB8
SBB9
SBBA
SBBB
SBBC
SBBD
SBBE
SBBF
SPTS
SWAK
SMIE
RTCS
PEXS
WAKS
PWBT
SLPR
SLPE
SLPX
LPCR
H_EC
_HID
_UID
_STA
B1CC
B1ST
B2CC
B2ST
CFAN
CMDR
DOCK
EJET
MCAP
PLMX
PECH
PECL
PENV
PINV
PPSH
PPSL
PSTP
RPWR
LIDS
LSTE
SLPC
VPWR
WTMS
AWT2
AWT1
AWT0
DLED
IBT1
ECAV
SPT2
ECMD
BAT0
_HID
_UID
_STA
BAT1
_HID
_UID
_STA
BAT2
_HID
_UID
_STA
SLIC
WMI1
_HID
_UID
_WDG
WMMX
RP01
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
RP02
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
RP03
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
RP05
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
RP06
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
RP07
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
RP08
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
PXSX
_ADR
_PRW
_RMV
_REG
HPME
_PRT
_PRW
P0P2
_ADR
_PRT
P0PA
_ADR
_PRT
P0PB
_ADR
_PRT
B0D4
_ADR
RP04
_ADR
PXCS
VDID
L0SE
LDIS
LASX
HPCE
ABPX
PDCX
PDSX
PSPX
PMEP
D3HT
HPEX
PMEX
L23E
L23R
LEDM
HPSX
PMSX
_STA
LTRV
OPTS
RPAV
_DSM
_REG
HPME
CPME
_PRT
PXSX
_ADR
_PRW
_PRT
_PRW
LTRE
OBFF
GLAN
_ADR
_PRW
EHC1
_ADR
PWKE
PMEE
PMES
PWUC
_PSW
_S3D
_S4D
HUBN
_ADR
PR01
_ADR
_UPC
_PLD
PR11
_ADR
_UPC
_PLD
PR12
_ADR
_UPC
_PLD
PR13
_ADR
_UPC
_PLD
PR14
_ADR
_UPC
_PLD
SDGV
_DSM
PR15
_ADR
_UPC
_PLD
SDGV
_DSM
PR16
_ADR
_UPC
_PLD
SDGV
_DSM
PR17
_ADR
_UPC
_PLD
SDGV
_DSM
PR18
_ADR
_UPC
_PLD
_PRW
EHC2
_ADR
PWKE
PMEE
PMES
PWUC
_PSW
_S3D
_S4D
HUBN
_ADR
PR01
_ADR
_UPC
_PLD
PR11
_ADR
_UPC
_PLD
PR12
_ADR
_UPC
_PLD
SDGV
_DSM
PR13
_ADR
_UPC
_PLD
SDGV
_DSM
PR14
_ADR
_UPC
_PLD
PR15
_ADR
_UPC
_PLD
PR16
_ADR
_UPC
_PLD
_PRW
XHC_
_ADR
_DEP
XPRT
MEMB
PMEE
PMES
PR2_
PR2M
PR3_
PR3M
XRST
CUID
POSC
XSEL
ESEL
XWAK
_S3D
_S4D
RHUB
_ADR
HS01
_ADR
_STA
_UPC
_PLD
HS02
_ADR
_STA
_UPC
_PLD
HS03
_ADR
_STA
_UPC
_PLD
HS04
_ADR
_STA
_UPC
_PLD
HS05
_ADR
_STA
_UPC
_PLD
HS06
_ADR
_STA
_UPC
_PLD
HS07
_ADR
_STA
_UPC
_PLD
HS08
_ADR
_STA
_UPC
_PLD
HS09
_ADR
_STA
_UPC
_PLD
HS10
_ADR
_STA
_UPC
_PLD
HS11
_ADR
_STA
_UPC
_PLD
HS12
_ADR
_STA
_UPC
_PLD
HS13
_ADR
_STA
_UPC
_PLD
HS14
_ADR
_STA
_UPC
_PLD
HS15
_ADR
_STA
_UPC
_PLD
SSP1
_ADR
_STA
_UPC
_PLD
SSP2
_ADR
_STA
_UPC
_PLD
SSP3
_ADR
_STA
_UPC
_PLD
SSP4
_ADR
_STA
_UPC
_PLD
SSP5
_ADR
_STA
_UPC
_PLD
SSP6
_ADR
_STA
_UPC
_PLD
_PRW
HDEF
_ADR
HDAR
DCKA
DCKM
DCKS
PMEE
PMES
_PRW
SAT0
_ADR
FDEV
FDRP
PRT0
_ADR
_SDD
_GTF
PRT1
_ADR
FDEV
FDRP
_DEP
_SDD
_GTF
PRT3
_ADR
FDEV
FDRP
_SDD
_GTF
REGF
_REG
TMD0
PIO0
DMA0
PIO1
DMA1
CHNF
_GTM
_STM
SPT0
_ADR
_GTF
SPT1
_ADR
_GTF
SPT2
_ADR
_GTF
SPT3
_ADR
_GTF
SPT4
_ADR
_GTF
SPT5
_ADR
_GTF
SAT1
_ADR
SBUS
_ADR
SMBP
I2CE
SMPB
SBAR
SMBI
HSTS
HCON
HCOM
TXSA
DAT0
DAT1
HBDR
PECR
RXSA
SDAT
SSXB
SRXB
SWRB
SRDB
SWRW
SRDW
SBLW
SBLR
STRT
COMP
KILL
PA0H
PA1H
PA2H
PA3H
PA4H
PA5H
PA6H
NPTS
NWAK
PTMA
PTMS
PTIA
_INI
NHPG
NPME
PDRC
_HID
_UID
BUF0
_CRS
DOCK
_HID
_CID
_UID
_STA
LTRS
OBFS
PEG0
_ADR
PEGR
PSTS
GENG
PMEG
_PRW
_PSW
HPME
_PRT
_INI
LTRV
OPTS
_DSM
PEGP
_ADR
_PRW
PEG1
_ADR
PEGR
PSTS
GENG
PMEG
_PRW
_PSW
HPME
_PRT
_INI
LTRV
OPTS
_DSM
PEG2
_ADR
PEGR
PSTS
GENG
PMEG
_PRW
_PSW
HPME
_PRT
_INI
LTRV
OPTS
_DSM
B0D3
_ADR
_STA
_INI
RPCZ
AUVD
ABAR
ASTR
VSTR
CXDC
AINI
GFX0
_ADR
_DEP
_DOS
_DOD
DD01
_ADR
_DCS
_DGS
_DSS
DD02
_ADR
_DCS
_DGS
_DSS
DD03
_ADR
_DCS
_DGS
_DSS
DD04
_ADR
_DCS
_DGS
_DSS
DD05
_ADR
_DCS
_DGS
_DSS
DD06
_ADR
_DCS
_DGS
_DSS
DD07
_ADR
_DCS
_DGS
_DSS
DD08
_ADR
_DCS
_DGS
_DSS
DD09
_ADR
_DCS
_DGS
_DSS
DD0A
_ADR
_DCS
_DGS
_DSS
DD0B
_ADR
_DCS
_DGS
_DSS
DD0C
_ADR
_DCS
_DGS
_DSS
DD0D
_ADR
_DCS
_DGS
_DSS
DD0E
_ADR
_DCS
_DGS
_DSS
DD0F
_ADR
_DCS
_DGS
_DSS
DD1F
_ADR
_DCS
_DGS
_DSS
_BCL
_BCM
_BQC
SDDL
CDDS
NDDS
IGDP
GIVD
GUMA
GMFN
ASLE
GSSE
GSSB
GSES
CDVL
LBPC
ASLS
IGDM
SIGN
SIZE
OVER
SVER
VVER
GVER
MBOX
DMOD
PCON
DVER
DRDY
CSTS
CEVT
DIDL
DDL2
DDL3
DDL4
DDL5
DDL6
DDL7
DDL8
CPDL
CPL2
CPL3
CPL4
CPL5
CPL6
CPL7
CPL8
CADL
CAL2
CAL3
CAL4
CAL5
CAL6
CAL7
CAL8
NADL
NDL2
NDL3
NDL4
NDL5
NDL6
NDL7
NDL8
ASLP
TIDX
CHPD
CLID
CDCK
SXSW
EVTS
CNOT
NRDY
DDL9
DD10
DD11
DD12
DD13
DD14
DD15
CPL9
CP10
CP11
CP12
CP13
CP14
CP15
SCIE
GEFC
GXFC
GESF
PARM
DSLP
ARDY
ASLC
TCHE
ALSI
BCLP
PFIT
CBLV
BCLM
CPFM
EPFM
PLUT
PFMB
CCDV
PCFT
SROT
IUER
FDSP
FDSS
STAT
GVD1
PHED
BDDC
DBTB
CDCT
SUCC
NVLD
CRIT
NCRT
GSCI
PDRD
PSTS
GNOT
GHDS
GLID
GDCK
PARD
IUEH
AINT
SCIP
MCHP
AUDE
TASM
BN00
CDID
CRID
PARC
PBRC
PCRC
PDRC
PERC
PFRC
PGRC
PHRC
XUSB
LNKA
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKB
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKC
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKD
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKE
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKF
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKG
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKH
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
PWRB
_HID
_UID
_STA
RDGI
RDGP
WTGP
WTIN
WPGP
GP2N
GP2A
GP2B
BIND
_HID
_CID
_STA
CIND
_HID
_CID
_STA
DIND
_HID
_CID
_STA
OSCI
OSCO
_OSC
PEPD
_HID
_CID
_UID
PEPP
DEVS
DEVX
_STA
_DSM
BTKL
_HID
_STA
_PS0
_PS3
PSTS
RAMB
DSAF
PAR0
PAR1
PAR2
PINX
PADD
MPAR
ARBF
REAX
REBX
RECX
REDX
IOB2
SMIC
SMIS
ISMI
GMSR
SMSR
PRID
GPRE
GNVS
SNVS
SIRS
SRAD
SARM
GAMM
SAMM
TPM_
_HID
_CID
_STR
_UID
_CRS
TMMB
ACCS
TSTA
TBCA
TVID
TDID
_STA
ASMI
INQ_
BSMI
DAT_
_DSM
LID0
_HID
_STA
MEM2
_HID
_UID
CRS2
_STA
_CRS
_SI_
_TZ_
ETMD
THLD
YBT4
YBT3
YBT2
YBT1
YBT0
FN00
_STA
_ON_
_OFF
FAN0
_HID
_UID
_PR0
FN01
_STA
_ON_
_OFF
FAN1
_HID
_UID
_PR0
FN02
_STA
_ON_
_OFF
FAN2
_HID
_UID
_PR0
FN03
_STA
_ON_
_OFF
FAN3
_HID
_UID
_PR0
FN04
_STA
_ON_
_OFF
FAN4
_HID
_UID
_PR0
TZ00
PTMP
_SCP
_CRT
_AC0
_AC1
_AC2
_AC3
_AC4
_AL0
_AL1
_AL2
_AL3
_AL4
_TMP
TZ01
PTMP
_SCP
_CRT
_TMP
_PSL
_PSV
_TC1
_TC2
_TSP
_REV
_OS_
_OSI
_GL_
SP1O
ENT1
EXT1
IO1B
IO1L
IO2B
IO2L
IO3B
IO3L
SPIO
IOHW
IOSB
IOSL
IOHB
IOHL
SMBS
SMBL
PMBS
GPBS
SMIP
APCB
APCL
SMCR
HPTB
HPTC
FLSZ
SRCB
RCLN
PEBS
PELN
LAPB
EGPB
MCHB
VTBS
VTLN
ACPH
ASSB
AOTB
AAXB
HIDK
HIDM
CIDK
CIDM
PEHP
SHPC
PEPM
PEER
PECS
ITKE
MBEC
SRSI
CSMI
AMWV
SMIM
FMBL
FDTP
FUPS
FUWS
BGR_
BFR_
BBR_
BWC_
BWT1
BFHC
TRTP
WDTE
TRTD
TRTI
PFTI
GCDD
DSTA
DSLO
DSLC
PITS
SBCS
SALS
LSSS
SOOT
PDBR
BW1P
BW2C
BW2P
BSPC
BSPP
BICO
BICC
BHB_
BFS2
BFS3
BFS4
BRH_
SMIA
SMIB
OFST
TPMF
TCMF
TMF1
TMF2
TMF3
TRST
PMLN
GPLN
SS1_
SS2_
SS3_
SS4_
IOST
TOPM
ROMS
VGAF
GNVS
OSYS
SMIF
PRM0
PRM1
SCIF
PRM2
PRM3
LCKF
PRM4
PRM5
P80D
PWRS
DBGS
THOF
ACT1
ACTT
PSVT
TC1V
TC2V
TSPV
CRTT
DTSE
DTS1
DTS2
DTSF
REVN
APIC
TCNT
PCP0
PCP1
PPCM
PPMF
C67L
NATP
CMAP
CMBP
LPTP
FDCP
CMCP
CIRP
SMSC
W381
SMC1
EMAE
EMAP
EMAL
MEFE
DSTS
MORD
TCGP
PPRP
PPRQ
LPPR
GTF0
GTF2
IDEM
GTF1
BID_
PLID
ECTG
OSCC
NEXP
SBV1
SBV2
DSEN
ECON
GPIC
CTYP
L01C
VFN0
VFN1
VFN2
VFN3
VFN4
VFN5
VFN6
VFN7
VFN8
VFN9
ATMC
PTMC
ATRA
PTRA
PNHM
TBAB
TBAH
RTIP
TSOD
ATPC
PTPC
PFLV
BREV
PDTS
PKGA
PAMT
AC0F
AC1F
DTS3
DTS4
LTR1
LTR2
LTR3
LTR4
LTR5
LTR6
LTR7
LTR8
OBF1
OBF2
OBF3
OBF4
OBF5
OBF6
OBF7
OBF8
XHCI
XTUB
XTUS
XMPB
DDRF
RTD3
PEP0
PEP3
DPTF
SADE
SACR
SAHT
PCHD
PCHC
PCHH
CTDP
LPMP
LPMV
ECEU
TGFG
MEMD
MEMC
MEMH
FND1
FND2
AMBD
AMAT
AMPT
AMCT
AMHT
SKDE
SKAT
SKPT
SKCT
SKHT
EFDE
EFAT
EFPT
EFCT
EFHT
VRDE
VRAT
VRPT
VRCT
VRHT
DPAP
DPPP
DPCP
DCMP
TRTV
LPOE
LPOP
LPOS
LPOW
LPER
PPSZ
DISE
PFMA
PFMS
PFIA
ICNF
DSP0
DSP1
NFCE
CODS
SNHE
S0ID
CTDB
PWRE
PWRP
XHPR
SDS0
SDS1
SDS2
SDS3
SDS4
SDS5
SDS6
RIC0
PEPY
DVS0
DVS1
DVS2
DVS3
GBSX
IUBE
IUCE
IUDE
ECNO
AUDD
DSPD
IC0D
IC1D
IC1S
VRRD
PSCP
RWAG
I20D
I21D
RCG0
ECDB
P2ME
SSH0
SSL0
SSD0
FMH0
FML0
FMD0
FPH0
FPL0
FPD0
SSH1
SSL1
SSD1
FMH1
FML1
FMD1
FPH1
FPL1
FPD1
M0C0
M1C0
M2C0
M0C1
M1C1
M2C1
M0C2
M1C2
M0C3
M1C3
M0C4
M1C4
M0C5
M1C5
TBSF
GIRQ
DMTP
DMTD
DMSH
LANP
XHDS
SHSB
PLCS
PLVL
GN1E
G1AT
G1PT
G1CT
G1HT
GN2E
G2AT
G2PT
G2CT
G2HT
WWSD
CVSD
SSDD
INLD
IFAT
IFPT
IFCT
IFHT
DOSD
USBH
BCV4
WTV0
WTV1
APFU
SOHP
NOHP
TBSE
WKFN
MBDA
_HID
KBFG
MSFG
RPA0
RPA1
RPA2
RPA3
RPA4
RPA5
RPA6
RPA7
PCHS
IO_D
TRPD
IO_H
TRPH
PMIO
GPE3
GPEB
UPRW
GPEC
GPS3
GPSB
SCIS
PMLP
GE08
GE17
GE35
GE45
GE51
GS08
GS17
GS35
GS45
GS51
GPR_
GU00
GU01
GU02
GU03
GIO0
GIO1
GIO2
GIO3
GL00
GL01
GL02
GP24
GP27
GP28
GB00
GB01
GB02
GB03
GIV0
GIV1
GIV2
GIV3
GU04
GU05
GU06
GU07
GIO4
GIO5
GIO6
GIO7
GL04
GL05
GL06
GL07
GU08
GU09
GU0A
GU0B
GIO8
GIO9
GIOA
GIOB
GL08
GL09
GL0A
GL0B
GPRL
GO08
GO09
GO14
GO17
GO45
GO51
GR00
GR01
GR02
RCRB
AFEA
AFED
AFES
AFER
HPAS
HPAE
ADSD
SATD
SMBD
HDAD
RP1D
RP2D
RP3D
RP4D
RP5D
RP6D
RP7D
RP8D
UP0D
UP1D
UP2D
UP3D
UP4D
UP5D
UP6D
UP7D
UP8D
UP9D
UPAD
UPBD
UPCD
UPDD
IO_P
TRPF
CADR
CBDR
LTDR
FDDR
CALE
CBLE
LTLE
FDLE
GLLE
GHLE
KCLE
MCLE
C1LE
C2LE
UXDV
RRIO
RDMA
NFC1
_HID
_STA
NFC2
_HID
_STA
NFC3
_HID
_STA
MUTX
DEB0
DBG8
DEB1
DBG9
PRT0
P80H
P8XH
ADBG
SPRT
SSMP
_PIC
_PTS
_WAK
GETB
PNOT
MBAR
PWRU
PPL1
PL1E
CLP1
CLMP
PLEN
PLSV
CSEM
SPL1
RPL1
DDPS
UAMS
GUAM
P_CS
TRAP
PICM
PRWP
GPRW
SRMB
BRTN
WCAM
_ADR
_UPC
_PLD
AMW0
_HID
_UID
_WDG
CCAC
ECD2
EID2
WED2
WMBC
RSMB
WSMB
RSMW
WSMW
RSMK
WSMK
WMBD
_WED
AMWR
AMWN
WQMO
SPEC
DEVP
SDSP
GDSP
DEVS
DSTS
GPID
KBFT
HKEY
CFVS
CFVG
RAMW
BNUM
B1SC
B1SS
B2SC
B2SS
_S0_
_S3_
_S4_
_S5_
PTS_
WAK_
OSCM
PINI
SSDT
PDC0
PDC1
PDC2
PDC3
PDC4
PDC5
PDC6
PDC7
SDTL
STFE
STFD
FZTF
DCFL
SCBF
CMDC
GTFB
SANV
SARV
ASLB
IMON
IGDS
CADL
PADL
CSTE
NSTE
DID9
DIDA
DIDB
IBTT
IPAT
IPSC
IBLC
IBIA
ISSC
IPCF
IDMS
IF1E
HVCO
NXD1
NXD2
NXD3
NXD4
NXD5
NXD6
NXD7
NXD8
GSMI
PAVP
LIDS
KSV0
KSV1
BBAR
BLCS
BRTL
ALSE
ALAF
LLOW
LHIH
ALFP
AUDA
AUDB
AUDC
DIDC
DIDD
DIDE
DIDF
CCSA
CCNT
SGMD
SGFL
PWOK
HLRS
PWEN
PRST
CPSP
EECP
EVCP
XBAS
GBAS
SGGP
NVGA
NVHA
AMDA
NDID
DID1
DID2
DID3
DID4
DID5
DID6
DID7
DID8
OBS1
OBS2
OBS3
OBS4
OBS5
OBS6
OBS7
OBS8
LTRA
OBFA
LTRB
OBFB
LTRC
OBFC
SMSL
SNSL
P0UB
P1UB
P2UB
EDPV
NXDX
DIDX
PCSL
SC7A
DSEL
ESEL
PSEL
MXD1
MXD2
MXD3
MXD4
MXD5
MXD6
MXD7
MXD8
PXFD
EBAS
