[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe die alte Version der ASUS TUF und da fiept nichts selbst bei vierstelligen fps in diversen Spielemenüs. Verbaut hab ich den Watercool Block.
Vermutlich. Wenn da nicht die jährlichen Untersuchungen durch den Arbeitgeber währen (freiwillig). Lärmintensiver Job, den ich ausübe.
Keine TUF ist lautlos. Aber das Level an Coil Whine und die eigene Toleranz machen eben den Unterschied. Hier im Forum schon 100 mal festgestellt, da muss man nicht wieder von vorne anfangen. Nach einigen Strix behaupte ich auch einfach mal, dass es keine lautlosen Strix gibt. Klar, kann hier niemandem, der das behauptet, das Gegenteil beweisen. So sind Foren halt. Aber meine Erfahrungen sind da eindeutig. Was sie in jedem Fall geändert haben ist dieses krasse Rasseln zu unterdrücken. Das funktioniert nun recht gut. Das Fiepen aber, was (ebenfalls natürlich nur eine Behauptung) wirklich jede 4090 in der ein oder anderen Form hat, muss man stets selbst hören. Selbst wenn für @Schrotti kein Geräusch vorhanden ist, würde ich dieselbe Karte wahrscheinlich hören. Dabei ist mein Gehör vielleicht noch nicht einmal besser, aber mein Rechner ist nun mal anders, mein Büro und die Umgebungsgeräusche sorgen für eine andere Soundkulisse, meine Empfindlichkeit ist eine andere...
Wer 4090 kauft, kauft fiepen, Punkt. Wer es aus welchen Gründen auch immer nicht hört kann sich (in diesem Fall :d ) glücklich schätzen.
Wenn man eine Karte auf Coil Whine prüft wird man wohl drauf achten, dass die Umgebungsgeräusche minimal sind, und das Hörorgan gen GPU ausrichten.
Bis vor ca. 2 Jahren konnte ich altersuntypisch das Hochfrequente noch recht gut hören.
Es hat die letzten zwei Jahre aber definitv nachgelassen (nicht der Tinnitus aber das Hörvermögen) :sneaky:
Da sehe ich bei den Techtubern bspw. anderes. Da wird einfach im lauten Studio "gehört" oder mal das Mikro an die Karte gehalten. Lachhaft.
Spulengeräusche ist eben noch immer ein Thema, dass auf wenig Beachtung stößt und somit nicht im Interesse bei der Mehrheit der Gamer steht.
Glaube auch nicht, dass sich daran viel ändern wird.
Naja ich gehöre auch zu denen die schonmal eine *lautlose* gaming oc gehört hatten. Es war wirklich so das diese Karte unhörbar war im offenen Gehäuse aus 70cm Entfernung. Ich dachte die Karte wäre kaputt da ich kein fiepen wahrnahm. Erst bei 10cm zur Gpu konnte ich ein leises aber süßes zirpen feststellen.
Es gibt Sie also doch diese Karten. Leider hab ich diese zurück gesendet zum Preis beim Release von 2300€.
Ganz so hoch boostet meine nicht (2715 MHz), aber mir reicht es locker.
an FEs kommt man wohl jetzt überhaupt nicht mehr, oder?
Nur bei ebay zu Organpreisen, mal wieder
Zuletzt waren die doch bei 1.699,- 1.899,- wenn ich mich recht erinnere 🤔
Da möchte ich aber die hier viel beschworene Phrase raushauen: Dann hast Du das Einhorn gefunden. :d
Zugegebener Maßen gab es die aber eher bei Gigabyte, PNY usw. als bei MSI oder Asus.
Meine akzeptable Strix boostet auch bis 2850MHz, fällt in manchen Spielen auf 2820 oder 2805MHz zurück. Aber das war das mindeste, was ich gesehen habe. Insofern betrachte ich das Ding auch als Einhorn. Wenn auch eins mit Augenklappe und nur 3 Beinen. :fresse:
RDR2 ist halt immer noch das Game, was den/der/die/das Coil Whine am lautesten zu Tage fördert. Bei W3 bspw. zieht sie sich genau so viel Watt, allerdings ist es da leiser. In allen anderen Games habe ich den 120FPS Cap drauf, da hört man goar nix mehr. Die Karte bleibt dann aber auch unter 300W.
klingt plausibel (y)
Wenns nicht nur ein Server-Schluckauf gewesen ist, hats die 4090 FE am 19.07. gegeben.
Kämme dann ein Wasserkühler auf die Karte?
Ich hab hier schon Monate nicht reingeschaut, kurze Frage:
Meine 4090 FE dreht ab und an mal voll auf. Scheint mir wie ein Start overboost. Habt ihr das auch selten mal?
Ich hab zwar schon seit launch den 4090 Heatkiller, aber einfach keine Lust gehabt umzubauen.
Wenn das nicht ständig während dem spielen passiert, ansonsten würde ich mal auf die Hotspot Temperatur schauen. Manchmal kann es vorkommen, dass die Wärmeleitpaste nicht richtig aufgetragen wurde und sich das erst nach Monaten bemerkbar macht. Hatte ich bei meiner letzten Karte. Wenn das allerdings nur jeweils einmal passiert, ist es wohl eher was anderes.
So lange das Coulwhine leiser ist als der Tinnitus ist alles ok. ;)
wo hast Du das her? Geizhals?
Der Bestellen-Button auf Nvidia.de ist an dem Tag wieder grün gewesen.
Beim Klick darauf hat NBB aber angezeigt, dass die Karte ausverkauft wäre.
Von daher dann entweder recht fix vergriffen gewesen oder wie gesagt ein Fehler.
Das hatte ich auch mitbekommen. War wohl aber nur wirklich kurz (wenige Stunden) verfügbar. Als ich es bemerkt hatte, war die Karte bei Nvidia noch als verfügbar gelistet, aber nach Weiterleitung zu NBB wurde bereits "leider ausverkauft" angezeigt.
Gibt es noch einen "GPU Alert" wie damals? Ich meine es gab mal eine Telegram Gruppe, sogar von HardwareLuxx, bezüglich Drops der Founders Edition auf NBB.
Ähnliche Themen
Antworten
6K
Aufrufe
397K
