[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ob an- oder ausgezogen ist nebensächlich. Das Kabel muss trotzdem reingesteckt werden. Nur verbrennen darf man sich dabei nicht^^
Das „Kleid“ einer FE zu entfernen, ist eine Schande :)
ich musste letztens Mal die Slotblende entfernen, schon das ist ein Krampf.
Bei allen anderen Karten sind das 2 Schrauben, maximal noch je 1 pro Displayausgang, aber bei der FE musste ich googeln :eek:
war für einen Versuchsaufbau mit mit einem anderen Luxxer, da war tatsächlich die kleine Zunge, welche im MoBo Tray eingehangen wird, im Weg. Hat mich aber sehr geärgert dass das sein musste. :grrr:
und auch dass es so aufwendig ist :rolleyes: .
Jetzt isse wieder da wo sie sein muss und die Karte rennt wieder :bigok:
Nach einem kleinen Kampf mit dem Satastromstecker des MSI 850G und der D5 Next ist die Frostbite Pro jetzt eingebaut.
Spulenfiepen hält sich sehr in Grenzen und ist mit Mo-Ra erst bei >200 FPS leicht wahrnehmbar :d
Nur die Leistung erscheint mir recht dürftig im 3Dmark Time Spy
Du bist über dem Durchschnitt mit einer Stock 4090, passt doch?
Beste Grüße
Zur Bestmarke ist ja noch deutlich Luft,die 3080 ging dank WaKü @Stock schon besser im Vergleich zu anderen Karten.
Will mich aber nicht beklagen,jetzt noch mal schauen was mit UV geht.
Hier ging es doch letztens um höhenverstellbare Schreibtische:
Hab mir jetzt Powell von Fezibo für 237,50€ gegönnt.
Die Holzqualität der Tischplatte ist recht dünn und dürftig und spiegelt den doch sehr günstigen Preis wieder. Dafür bin ich vom Motor und Controller wirklich begeistert. Echt sehr leise und dennoch flink. Von 73cm bis 123cm mit Kollisionsschutz und Höhenanzeige, mit Tippen auf Hoch/Runter in 3mm Schritten möglich. Zwei Speicherplätze für Wunschhöhen. Stabil ist er komplett ausgefahren auch, wenn man natürlich vorher die vier Füßchen richtig einstellt. Gut der Tisch selbst ist ja auch nicht wirklich riesig, aber für meine Zwecke genau richtig.
Ja habe ich auch gesehen, keine Ahnung wie sich Türken und Argentinier nun Games leisten wollen…
Ich denke aber das wird sich über die Zeit einpendeln, wenn man merkt das in diesen Ländern plötzlich 70-90% Einbruch bei den Verkaufszahlen zu sehen ist… kann denen doch nicht völlig egal sein, wenn 2 Länder nun plötzlich komplett rausfallen.
Habe gelesen, dass die Entwickler ihre ARG/TR-Preise noch anpassen müssen...
Bei manchen Games scheint das schon passiert sein - zb bei "Euro Truck Simulator 2" :fresse:
Ich hab da ein Phänomen - eventuell seit dem umbau des Boards+cpu.
Und zwar ist es so, dass ich War thunder spiele und nach ein paar Minuten ruckelt und hängt alles. Wenn ich nix tue fängt der rechner sich meist wieder nach etwa 20 Sekunden. Wenn ich Tasten drücke ect. hängt er sich auch mal komplett auf.
Soweit ich nun gesehen habe, kommt das nur 1 mal vor nach nem neustart und dann nicht mehr.
Hier ein Screenshot von GPU-Z während es passiert ist. Man sieht ziemlich gut wo der einrbuc hsatt findet. Ich weiß nur nicht warum. Kein OC oder sonstiges aktuell. Frisch installiert.
Werde das nie verstehen, für Hardware werden tausende Euros verballert aber bei Games muss gespart werden.
Ich spare überall wo es geht, mit allen mir zur Verfügung stehenden Mitteln. Deine dekadente Lebensweise muss ich und werde ich auch nie gut finden. Finde ich sogar abstoßend.
Ich bin da anders erzogen worden, liegt wahrscheinlich daran das ich unter bescheidenen Verhältnissen aufgewachsen bin und du wahrscheinlich mit einem goldenen Löffel im Mund.
Ich nutze Globalisierung aus wo es irgendwie geht, dass sollten nicht nur großen reichen Unternehmen vorbehalten sein, warum auch?
Und wenn ich eine 4090 für 2k bei dem einem Händler sehe und über mydealz an die gleiche Karte für 1,8k sehe nutze ich das auch aus. Du wahrscheinlich nicht, weil 2k? Pah soll’s, Dekadenz rulez, oder was? 🤮
Das man so geizig sein kann und dann noch extra ausländische Kontos erstellt.
Du nennst es Geiz, ich nenne es intelligentes vorausschauendes Handeln. 🤘
Tldr:
welche ist eigentlich nun die beste 4090 karte, wenn man alle punkte mit einbezieht? ... preis, spulenfiepen, oc, lautstärke, usw.
Ähnliche Themen
