[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Tja schade dass ich mit keiner 4090 zufrieden war und deswegen am Ende nun ein Downgrade anstand, wenn das so weiter geht könnten wir bald wieder 2020er Verhältnisse haben und das für einige Zeit. Insbesondere wenn dann Blackwell ansteht. Wohl dem der eine leise 4090 im Rechner hat.
Macht schon mal den Verfügbarkeitsbot klar. :fresse:
Auf meiner 4090 sitzt ein Heatkiller. Leiser geht nicht.
Dass es eher ums Spulenfiepen ging sollte klar sein. Und ja ich weiß, Eure 4090er machen alle keinen Mucks. ;)
Das mag eher an einer gewissen Schwerhörigkeit liegen ;)
Oder einfach am Alter, weil im Alter hört man höhere Töne immer schlechter und Spulenfiepen ist eben ein sehr hoher Ton. Aber ich bilde mir ein meine Karte ist in dem Punkt wirklich leise. Ich hab ja genau diese geholt weil hier das Spulenfiepen weniger auftrat und die Lüfter auch recht leise sein sollen. Solange letztere nicht über 60% gehen sind die auch leise und mit 60% wird die 4090 bisher sowieso gut genug gekühlt, muss also gar nicht weiter aufdrehen, entsprechend sieht auch meine Lüfterkurve aus, höher geht nur wenn die Karte wirklich richtig heiß wird. Aber gut, meine Karte ist auch runtergetaktet, hilft natürlich auch.
Ich lege noch mal 10 Jahre oben rauf. Hier ist echt Stille :ROFLMAO:
Da verfolgt man diesen Thread mal ein halbes Jahr nicht... dann stellt man fest, 4090 FE überall ausverkauft, auch Custom Modelle nicht käuflich zu erwerben, außer ab 2.3k :d
Laptops mit 4090 ebenfalls, oder Lieferzeiten von 2 Monaten +
Sind die Exportbeschränkungen von USA verantwortlich oder habe ich etwas verpasst?
Muhahahahahaha, richtig schöne Steilvorlage 👌
Seit Wochen/Monaten willst du einen G3 mit MLA und dann bestellt du dir doch einen C3 (ohne MLA) und stornierst ihn dann?
Ich geh kaputt 🤣🤣🤣
Zotac 4090 mit Granzon Block… das Ding ist totenstill, einfach wunderbar! :geek:
Hi
Na dann muß ich euch mal meine Frau ausleihen....................
moment.......das kam jetzt falsch rüber.. :hmm:
Aber die gute hört den Sekundenzeiger auf der Armbanduhr über 10 Meter.
Erst wenn sie nix hört ist echt Stille.
Deswegen muß meine Ichill Frostbite leise sein..sonst hätte ich da sofort ne Meldung bekommen.
Gruß Bernd
Wenn ich genau hinhöre, höre ich auch alle drei "etwas" fiepen, Suprim X,GameRock OC und auch die FE. Aber das Alter schreitet ja fort, darauf setz ich alles :fresse2: #hörsturz
Danke @Cyberbernd für das Angebot, aber meine reicht mir schon :stupid:
Die gute alte Bildschirmfreigabe ^^
Ich versuche wirklich die Spulenhörer-Fraktion zu verstehen, habe in wenigen Fällen auch mal tatsächlich mal meine gehört (in den letzten drei Generationen), wenn ein Game-Menu nach Installation mit 1000fps aufgepoppt ist, was ich dann aber sogleich regulieren konnte.
Bin lange mit 60hz vsync zufrieden gewesen, rührt das daher? Jetzt mit 144hz/gsync bin ich immer noch nicht in der Lage, sowas ausmachen zu können.
Ja, ich undervolte bei der 4090 auf 0.9V, die Karte läuft im Max auf 2700Mhz und zieht auch nur bis 300 Watt. Das ist mE. der Sweetspot der Effizienz dieser Karten. Auch steht der Rechner nicht auf meinem Schreibtisch und blinkt auch nicht mehrfarbig.
Das führt mich unmittelbar zur Frage: Existiert Spulenfiepen nur am absoluten Leistungs-Endpunkt (oberhalb 400W) dieser GraKas? Habe ich immer nur Glück gehabt? Ist das Fiepen von der GPU-Last abhängig?
Wahrscheinlich ist es eine Mischung von allem, aber ich lasse mir nicht unterstellen, dass ich schwerhörig bin. Als reformierter Luft-Kühler habe ich eine Geräuschlast von ca. 22db bei einem Meter Entfernung bei maximaler Kühlung.
Sowas ist von user zu user unterschiedlich manche bekommen einen hörsturz wenn der PC lauter als 30DB neben ihnen ist oder lüfter schneller als 500 U/min drehen und andere hören nix wenn ein lüfter auf 1500U/min läuft oder der ganze PC 45DB hat
Meine TUF macht auch spulenfipsen aber meine ist auch Übertaktet und hat ein XOC Bios und ist immer noch bedeutend leiser als meine erste Suprime X aber mich stört es nicht weil ich eh immer ein Headset trage und davon nix mit bekomme
Ähnliche Themen
