[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Juhu miteinander,
kann mir jemand sagen was das ist 😂
deutet das auf einen kommenden defekt hin?
Habe dies immer wieder mal, geht aber bei Bewegung der Maus weg.
Ist eine 4090 FE
dell oled? ich hab das auch. allerdings nnicht als standbild sondern das ist schneller wieder weg als ich reagieren kann. und nur aufm desktop. nicht ingame.
computerbase kannste für native res tests ab sofort in die tonne treten. only DLSS/FSR benches in einem.
ich hab das z.b. beim scrollen. twitter z.b.
so genau konnte ich mir noch keinen reim drauf machen
Hat jemand eine Lösung für die voreingestellte Lüfterkurve ab 30%?
(Lüfter drehen mit mindestens 30%).
Es müsste doch andere Custom Designs geben, die eine leisere Lüfterkurve aufweisen.
Bisher sind mir die FE: https://www.reddit.com/r/nvidia/comments/12mdjv5/lowering_minimum_fanspeed_on_the_rtx_4090_fe/
, die Inno3D Modelle, die Tuf: https://www.reddit.com/r/nvidia/comments/yihsjr/asus_tuf_4090_fan_behavior/ und die Trinity
mit den lauten Lüfterkurven bekannt.
Das müsste doch anders gehen...
Juhu miteinander,
Ist eine 4090 FE
Ich habe das auch. Das kommt von Chrome meine ich. Wenn Chrome geschlossen ist passiert nie was. Kenne das aber auch nur so dass das ganz kurz auftritt und sofort wieder weg ist.
Juhu miteinander,
Ist eine 4090 FE
Eventuell auch Kabel prüfen.
Ich probiere jetzt einfach mal Firefox als Standardbrowser, mal sehen ob es dann weg ist. Ich meine das ist genau dann aufgetreten als ich von Opera auf Chrome gewechselt bin.
Kein Probs mit Chrome läuft Tadellos egal mit welchem Treiber.
Es passiert auch nicht ständig. Vielleicht 2-3 Mal am Tag bei mir das ganz kurz so schwarze Artefakte zu sehen sind für 0,1 Sekunden oder so. Hat mich bis jetzt nicht so sehr gestört um den Browser zu wechseln, jetzt mache ich es einfach mal.
Würde auf Speicher tippen … GraKa unter Wasser? Hatte das mal wenn der Speicher zu kalt und der Takt zu hoch ist. In jedem Fall aber kein grundsätzliches Problem.
Mhm ja Speicher wäre möglich...Habe da seit ich die Karte besitze +999MHz drauf und nie Probleme gehabt. Kann man auch mal testen da etwas runter zu gehen. Habe Luftkühlung aber im Winter ist es bei mir im PC Zimmer öfters sehr kalt, da Fenster öfters offen.
Ich weiss nicht ob Chrome noch in den Einstellungen separat den Button GPU Beschleunigung hat wen das aktiv sein sollte eventuell mal deaktivieren oder anders rum.
Das habe ich schon mal ausprobiert und es hilft tatsächlich. Dann sind aber Youtube Videos z.B. sehr laggy
Jo schon ewig Chrome
Ich habe jetzt den Speicher auf +499 zurück gestellt und nutze halt Firefox. Seitdem ist das mit den schwarzen Artefakten nicht mehr aufgetreten .
Nutzt ihr alle Chrome? :fresse:
Bleibe Firefox treu, seit bald 2 Jahrzehnten. ^^
Hier auch Firefox.
zu den ganzen Super und TI Super updates fällt mir nur ein:
Juhu miteinander,
Ist eine 4090 FE
Das schaut aus wie der Chromium Checkerboard Bug. Schau mal hier:
So wie ich das verstanden habe ist das ein Bug den Microsoft adressieren muss und wohl in irgendeinem DEV Build wohl auch schon gefixed hat. Ich finde es einfach beruhigend zu wissen, dass das kein defekter VRAM ist.
Ahh okay, wusste doch ich spinne nicht das es an Chrome liegt :d Also Speicher wieder auf +999. Firefox bleibt aber glaube ich. Echt ein schöner Browser. Habe ich schon 10 Jahre oder so nicht mehr genutzt.
Du, theoretisch könnte es in jedem Fall auch ein defekter VRAM sein. Beim Übertakten leg ich da meine Hand nicht ins Feuer. Ich habe aktuell einen nie übertakteten defekten Prozessor hier liegen (Intel will aber den Prozessor erstatten). Sag niemals nie.
Aber der Checkerboard Bug ist schon bekannt. Von daher wollte ich das nicht verschweigen.
Ähnliche Themen
