[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Föhn.... es wird immer lächerlicher. :ROFLMAO:
Öhm. Ich habe das genau so gemacht. Vor ca. Einem Jahr. Das Kabel war nämlich bocksteif und ich musste es biegen. Und zwar so dass nichts im Stecker versetzt oder verbogen wird. Ging nur vernünftig mit der Hilfe des Föhn.
Naja über 2k für ne GPU, da wird man ja wohl auch noch was übrig haben für einen anständigen Harrföhn.
Genau das ist doch das Ding warum machen die es Bocksteif ?
Mein weiß geslevtes Original Corsair Kabel ist es nicht weil die Litzen frei sind.
Nun, es ist wie es ist. Und wenn ich ein bocksteifes Kabel vor mir habe, weiß ich wie ich damit umgehen kann. Es hilft mir ja nicht zu lamentieren. Da könnt ich auch über den ganzen Anschluss lamentieren. Hilft nicht.
Einfach zu Steif gebaut das Kabel für den Zweck hat nix mit lamentieren zu tun.
Da kommt nicht jeder auf die Idee mit einem Haartrockner bei zu gehen und dann haste halt vielleicht Probleme.
Ich denke, weil "bocksteife" Isolierung + "dick-adrige" Leitungen billiger sind, als zb hochflexible Silikonisolierung + "fein-adrige" Leitungen
Zumal, die evtl. darauf spekulieren, dass bocksteife Kabel eher ersetzt werden müssen, wenn diese schneller die Grätsche machen (=mehr Umsatz)
Birgt halt vielleicht ein gewisses Risiko bei den neuen Anschlüssen.
Sorry, grad Kopfkino bekommen... :ROFLMAO:
Solange die Partnerin weiß, wie sie mit einem bocksteifen "Kabel" umzugehen hat und nicht herumlamentiert, isses gut :d
Wenn sie mit nem Föhn ankommt, würde ich mir Gedanken machen. Obwohl...
:fresse:
Eh, ich verstehe warum man sich lustig macht, aber ganz ehrlich, blöd ist der Hinweis auf den Föhn überhaupt nicht. Wenn man partout kein anderes Gehäuse will und unbedingt enge Biegeradien realisieren muss, dann kann das schon sinnvoll sein.
Eh, ich verstehe warum man sich lustig macht, aber ganz ehrlich, blöd ist der Hinweis auf den Föhn überhaupt nicht. Man man partout kein anderes Gehäuse will und unbedingt enge Biegeradien realisieren muss, dann kann das schon sinnvoll sein.
Natürlich ist das Sinnvoll ist auch gut das auf sowas hingewiesen wird darum hab ich es ja auch verlinkt.
Ich lache nur um den Umstand daß es überhaupt notwendig ist.
Ich würde bei einer 2000€ GPU kein Riser verwenden.
In vielen Fällen geht alles gut, ja. Aber selbst 50w über den PCI Slot können auf Dauer das Kabel beeinträchtigen (die einzelnen Adern hängen dicht beieinander und oft mit einer sehr dünnen Isolierung).
Nimm mal eine 10w-Glühbirne in die Hand 🔥💡🔥
Wenn das Riser irgendwann durch die Abwärme erschöpft ist, dann passieren unschöne Dinge.
Da gehen doch keine 50 Watt durch. Die 40er Karten nutzen PCIe nicht ansatzweise aus. Dazu halte ich das eher für eine Grundsatzdiskussion als eine Problemlösung. Trotzdem hatte ich das Kabel vermutet, es lag aber nicht daran. Das verwendete Kabel hatte absolut saubere Kontakte und keine Knicke. Das neue Kabel auch nicht - funktioniert genausowenig.
Der Riser verschlechtert die SIgnalqualität und die SignalLatenz des PCIe-Datenbus. Wie gut deine Grafikkarte oder das Motherboard damit klar kommt, kann sehr unterschiedlich sein.
Kannst ja mal den den PCIeDatenBus auf PCIe3.0 begrenzen. Vieleicht kommt PCI3.0 besser mit dem Riser klar, als PCIe4.0
Ich kam nicht mehr ins Bios bzw. bekam kein Bild mehr.
Meine 4090 Frostbite ist tot. Ich habe eine 4060 gekauft, eingebaut, ging sofort. Egal welches Riserkabel, es ging sofort und ohne Probleme. Beim Ausbauen habe ich penibel darauf geachtet, dass kein Wasser in die 4090 läuft. Soweit man es von aussen sehen kann, ist die Karte absolut trocken. Ich hoffe, Inno3D sieht das auch so und tauscht einfach aus. Die 4060 bleibt für den Übergang, aber sie ist leider schnarchlangsam.
oh, sorry to hear that; hoffe, der Austausch geht ohne Probleme zustande
Sorry für das "alte" Video...
Wusste garnicht, dass es neben der 4090-Evangelion auch Evangelion-NTs, Mäuse etc gibt
Doch schon. Man könnte einen ganzen NGE PC bauen im Stil von EVA-02
Bei dem Video hat mir übrigens der Zikaden Sound im Hintergrund gefehlt
Siegel ist drauf, die Karte ist 11 Monate alt. Ich sehe da kein Problem.
Ich würde gern den Kühler runternehmen und schauen. Insbesondere würde ich gern nach Wasser schauen. Geht aber nicht. Ich hab da auch eher ein schlechtes Gefühl, wenn Die Karte eingesendet wird und irgendjemand urteilt abschließend. Wie gesagt, es ist absolut kein Wasser oder Fleck zu sehen. Ich habe auch peinlich genau darauf geachtet. Zudem hatte ich Leakshield im Einsatz, da herrschte immer 400mbar Unterdruck.
Einschicken fertig. Ganz einfache Sache .
Kann ja passieren sowas. Für sowas hat man Garantie und ist der Grund warum du eine fertig montierte wakü Karte gekauft hast. Welcher Händler ?
Lass dich nicht abzocken mit Zeitwert etc. falls die Karte zu einer Zeit bekommen hast wo die günstiger war als jetzt.
Schicke die Karte frühzeitig ein bevor die 12 Monate um sind wegen Beweisumkehr etc.
Wurde wohl zwischenzeitlich von 6 auf 12 Monate erhöht , wenn ich mich nicht täusche.
Frohe Weinachten und ein Hardwarefreudiges Weihnachtsfest euch allen!
Worst case (wenn RMA abgelehnt wird) kann er vielleicht was machen…!? ;)
btw:
Frohe Weihnachten und defektfreie Feiertage :)
eieiei... möge das recht auf deiner seite sein @klasse08-15 (was es ja absolut ist; ich mein da eher, dass inno3d das ebenso sieht =>) und der gerät bitte kommentar- und stresslos getauscht werden (y) echt blöder zeitpunkt...
hoffentlich wird mit der manli hier nie was sein... die gallardos scheint es nicht mehr zu geben, kA, ob manli generell überhaupt noch existiert? nach dem wakü umbau dürfte das (für mich; denen sowieso) auch egal sein...
Manli gehört zum gleichen Konzern wie Zotac nach meinem Stand.
Also ja. Die gibt's noch ;)
jop, pc-partner = manli, inno3d und zotac. denke auch dass manli ansich noch existiert, zumindest las ich da nix gegenteiliges bisher. ändert denke ich ziemlich sicher nichts daran, dass ich im falle des falles wahrscheinlich gea*scht bin :d den manli luftkühlblock bekomm ich da nie wieder so drauf wie er war, mal ganz abgesehen von dem verschwundenen siegel :fresse2:
Ich hatte Glück, dass notebooksbilliger erstens 5 km entfernt ist, Karten lagernd hat und preislich sehr attraktiv ist. Internetpreis im Laden abgestaubt, so kurz vor Weihnachten.
Und tatsächlich hätte ich gern auch eine teurere Karte gekauft. Keine 4090, aber 4060ti oder 4070. Letztlich zock ich doch meist Apex Legends und da reicht auch die 4060. Auch wenn statt 171 FPS nur im Schnitt 120 anliegen und es heftige Drops gibt. Die 4060 tut sich halt schwer auf UWQHD.
Computeruniverse. Ich hab 2088 Euro am 14 Januar bezahlt. Ich mache mir auch keinen besonderen Kopf. Bin halt eher der Typ, der gern selbst erst mal schaut.
btw:
Hab ich schon auf dem Schirm und bin deshalb sehr entspannt. Aufgrund der Grafikfehler halte ich es auch nicht für unwahrscheinlich, dass ein RAM-Modul schuld hat.
Ähnliche Themen
