[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@klasse08-15
Krisfix wäre mir die Karte an deiner Stelle auch definitiv wert.
Ich behaupte ja schon länger, dass man mit der 4090 durchaus ne Weile auskommen kann.
Wenn da nicht GAS bei der next-gen anliegt....🤣
Weiß kriswichs eigentlich was er da reparieren muss wenn man ihm eine defekte Karte schickt ohne zu wissen was die Ursache ist?
Bis 18Uhr ist noch bissl Zeit...
Krisfix kennt die Stellen, zum Messen, um herauszufinden, was es sein könnte. Hier zb legt er einen neuen Trace an. Also einen Kontakt zu einem der viele Layer im PCB herstellen.
Das ist schon die Königsklasse bei Reparaturen. Absolut top...
@klasse08-15
Da die Karte noch Garantie hat, weiß ich nicht, wieso man einem Youtuber Schrauber das Teil auf eigene Kosten zusenden sollte ;) Nach der Garantie/Gewährleistung ist das sicherlich eine Option, aber jetzt doch nicht.
eigentlich nicht, klar, da hast du natürlich recht: sollte inno3d aus unerfindlichen gründen allerdings die garantie verweigern...
Weiß kriswichs krisfix eigentlich was er da reparieren muss wenn man ihm eine defekte Karte schickt ohne zu wissen was die Ursache ist?
Ich habe es dir einmal korrigiert.
Eine Karte wird durchgemessen, getestet und diagnostiziert. Danach werden, je nach Schaden, Bauteile nachgelötet oder ersetzt. Wenn man von der Materie allen Anschein nach absolut keine Ahnung hat, sollte man andere die das Wissen und das Können haben nicht verunglimpfen.
Genau darum geht es.
Und sollte dies der Fall sein ist Krisfix eine gute Anlaufstelle.
Wichtig ist in dem Fall der Händler .
Wenn die Karte defekt ist bekommt der Händler irgendwelche Punkte , womit er eine neue Karte bestellen kann. Das heißt Inno3d schickt nicht einfach ne Austausch Karte zurück . Hat auch was gutes, aber der Händler muss stimmen.
Auf jedenfall, wenn es Probleme gibt würde ich mich hier im Forum direkt an den Mann wenden.
Er konnte hier und da in ähnlichen Fällen helfen.
Grundsätzlich hast du Recht, aber daraus kann man ableiten, was inno3D für einen Ruf hat, was Garantie betrifft.
Die Leute malen den Teufel bereits an die Wand :fresse:
Mit geht’s weniger um Inno3D oder Zotac oder Asus. Es ist halt eine Wasserkühler-Karte. Ich darf den Kühler nicht runternehmen und schauen, ob ich oder die Karte schuld hat. Diese Prüfung muss ich Leuten überlassen, die natürlich im Sinne des Herstellers entscheiden. Das nervt mich jetzt bereits im Vorfeld.
Gut zu wissen. Beim Händler Computeruniverse ist es erst mal so, dass laut Profil durch den Wechsel des Warenwirtschaftssystems die Bestellhistorie weg ist. Ich wende mich morgen an Herrn Support und sehe dann weiter.
Wieso stellst du diese Frage, wenn du die Antwort kennst und sie auch direkt beantwortest?
Mein „Problem“ ist auf jeden Fall das geringere Übel. Ich mache auch vorher noch Fotos von der Karte. Damit kann ich den sichtbaren Bereich wenigstens dokumentieren.
Aber am Ende muss man eben ein Nachteil schlucken. Da kommt man nicht drumrum.
Auf jedenfall alles dokumentieren auch falls du dich mit dem Hersteller in Verbindung setzt. Serien Nr definitiv auch dokumentieren.
Habe mal gehört CU soll nicht so toll sein bei RMAs deswegen doppelt und dreifach darauf achten . Die Leute die hier mit CU aber Probleme hatten waren immer verbogene Pins im CPU Sockel . Daher denke wird schon werden.
Ich heule hier nicht rum, ich habe lediglich die Community daran teilhaben lassen, dass meine Karte tot ist und was ich mir für Gedanken mache. Aber so Sprüche wie "Das wusste man ja vorher. 😅" muss ich auch nicht einfach so stehen lassen. Wer sowas raushaut, muss sich auch gefallen lassen, wenn man seinen Kommentar mal von der anderen Seite betrachtet. Was du in deinem Kommentar zum Besten gegeben hast, war halt null Information, null Gehalt.
Ich bau seit 20 Jahren an PC-Hardware rum und auch an Grafikkarten. Ich kenne auch Krisfix und seine Videos. Und auch die Problematik von Garantie vs. originale Wakü-Karte. Und es gab auch schon hilfreiche Kommentare hier, die auch mir noch ein bisschen auf die Sprünge geholfen haben.
@********* Keine Ahnung, warum du alles wiederholst, dabei trotzdem die Problematik gar nicht verstanden hast (jedenfalls die Details nicht) und dich dann noch beschwerst, dass ich hier darüber geschrieben habe - in einem Hardware-Forum, wo man sich über Hardware austauscht und Gleichgesinnte einem Hobby nachgehen. Wenn dich das alles nicht juckt, warum bist du dann hier? Ich habe auch niemanden gebeten hier groß zu diskutieren oder Kommentare zu schrieben. Die User machen es aber - weil es ein Hardwareforum ist. Und ich habe freundlicherweise auch auf Kommentare von Usern geantwortet, die die Sache mehr als "null" juckt bzw. sogar interessiert sind - weil das hier ein Hardwareforum ist und man das so macht.
@Holzmann
Das ist für mich erst Option 2. Ich will erst mal über den Händler einen ganz normalen Garantiefall draus machen. Das ist ja auch der normale Weg. Der Inno-Support hier im Forum nimmt ja keine Karten direkt an. Wenn das gegangen wäre, hätte ich das sofort gemacht.
Nachricht gelöscht
@********* wenn du ein persönliches Problem mit ihm hast, versuch das bitte via PM zu klären.
Ich glaube, wir fahren hier jetzt mal runter.
Selbst wenn meine Frostbite jetzt verreckt, juckt mich das 0, kauf ich halt ne neue, so ist das halt bei Hardware, ist ja nix neues.
Na dann...
Weil du es nicht verstehst, das selbe wie mit Leuten die Fertig PCs kaufen und dann hier fragen bzw. Stunden oder Tage nach Fehler suche gehen, die haben ja für den Support bezahlt. Genau das selbe wie mit ner fertig montierten Wakü Karte. Meld dich doch einfach beim Händler/Hersteller, ist das so schwer?
Ich habe hier weder die Leute noch dich persönlich danach gefragt, was ich machen soll. Ich habe den Thread hier daran teilhaben lassen. Ich habe auch schon zig mal gesagt, was ich machen werde und warum ich dies noch nicht angeleiert habe. Ich sage es gern noch mal ganz deutlich - ich brauche deinen "Support" nicht. Auch brauche ich keine "Tipps" von dir.
Wenn hier Leute Krisfix empfehlen, obwohl ich noch Garantie habe und deshalb der Weg über den Händler und Hersteller der Richtige ist, dann bin ich doch daran nicht schuld!?
Naja also meine "kostenlose" Grafikkarten RMA hat zwei Monate gedauert und ich musste mir daher zur Überbrückung zwingend eine Ersatzkarte holen und dann mit Verlust weiterverkaufen. Da wäre Krisfix vermutlich schneller und sogar kosteneffizienter gewesen :fresse: Allerdings kann bei GPU Defekt natürlich nur der Hersteller was machen, auch klar...
Über Amazon könnte eine bis Ende Januar genutzt werden und bei Gefallen behalten werden aber das wäre ja nicht die feine englische Art.
Kann es sein, dass es gerade generell für NVIDIA RTX GPUs ein Engpass gibt?
Also ja, einerseits der Ban der 4090 für China und dadurch kranke Preise... aber auch z.B. die ASUS ProArt 4080 - nichts lieferbar.
Vielleicht liegt es auch daran, dass ja bald diese SUPER Karten kommen sollen? Anders kann ich mir die Situation gerade nicht erklären...
Ähnliche Themen
Antworten
6K
Aufrufe
399K
