[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
wenn die 5090 mitte 2024 käme, ich glaub ich müsste nichtmal aufrüsten. am ende kommts auf die Spiele an und bis jetzt läuft fast alles
Mit einem 4K 240 HZ OLED gibt es wieder neue Ziele.
ich weiß nicht ob ich auf 16:9 zurück gehen könnte.
und 240hz erreiche ich vll in fortnite :d
ich hätte gerne einen 38er mit 3840x1600.
der 45er ist auch nett aber nicht in 1440p
Naja 240Hz sind bei den aktuellen CPU Anforderungen von vielen Games heutzutage auch mit 5090 nicht erreichbar. Ich werde mir wahrscheinlich eine 5090 holen aber es hängt ein bisschen davon ab wie Monster Hunter Wilds auf der 4090 laufen wird. Wenn die 4090 da komplett ausreicht brauche ich 2025 eigentlich keine neue GPU. Aber mal gucken was noch so angekündigt wird. Für GTA 6 kann man auf PC ja eher auf die 6090 warten so wie es aussieht. :LOL:
@Tundor welches hast du?
Das Non-Pro (also ohne sleeve) für Seasonic. Oder gibts noch andere?
Hahahah schon wieder, ich wusste warum ich das Seasonic Kabel gekauft habe.
Hätte ich mir inzwischen auch gekauft, wenn ich nicht bei Cablemod schon mein Geld gelassen hätte. Die Kabel scheinen jetzt ja aber i.O. zu sein. Aber den Adapter können sie glaub echt einstellen, ich würde diesem Ding keine Sekunde mehr über den Weg trauen.
Ich habe eine Inno3D 4090 Frostbite.
Leider macht sie seit Kurzem Probleme. Es gab beim Zocken mal komplette Abstürze, der Rechner ging komplett aus. Ich habe aber was anderes als die Grafikkarte vermutet. Vor ein paar Tagen hatte ich manchmal Grafikfehler in 2D. Meist verbunden mit kompletten Einfrieren oder Absturz. Da hatte ich den Treiber in Verdacht und hab den neu installiert. Grad eben hatte ich wieder einen kompletten Absturz. Hochfahren ging noch, aber wieder Grafikfehler und Abstürze. Bei nochmaligen Probieren ging gar nichts mehr. Die LED für die GPU leuchtet dauerhaft und kein Boot mehr möglich.
Natürlich hab ich schon die Fehlersuche gestartet. Kabelverbindung gecheckt und das Cablemod-Kabel (direkt in das 850W Seasonic Focus ATX2.4) kontrolliert und letztlich gegen Standardkabel und NVidia-Adapter getauscht. Keine Veränderung.
Ich nutze ein Riserkabel (4.0). Hab da den anderen Anschluss am Mainboard probiert und auch die Kontaktflächen kontrolliert. Keine Änderungen. Direkt ins Mainboard kann ich die Karte nicht schieben, da ich eine Distroplate nutze und die Karte nur nach aufwendigen Umbau horizontal Einbauen kann. Das werde ich wohl morgen machen.
Hat jemand noch eine Idee? Mir graut es davor, dass die 2000 Euro Karte tatsächlich angeraucht ist.
Übrigens lief die Karte 95 Prozent der Zeit mit maximal 220 Watt und 35 Grad. Speichertemperaturen kenne ich aktuell nicht. Aber die waren immer ok. Die Karte ist auch kein Wasseropfer.
Könnte an zu niedriger/zu hoher GPU Spannung liegen. Hatte vor kurzem auch komische Systemausfälle.
Nachdem ich die Spannung und den Takt angepasst habe (ca. 0,8v@2ghz) läuft das System wieder normal.
Hat die Graka ne LED am Stromstecker? Geht der auf Rot wenn sie abschmiert?
Oder redest Du von der GPU-Led auf dem Board die dauerhaft leuchtet?
@********* Ich hole mir morgen einen anderen Riser. Ich tippe darauf, dass es am Kabel liegt. Das Problem bei mir ist, ich habe zwar einen 1,20 m hohen Selbstbautower, aber die Hardware selbst sitzt in einem O11XL mit einer Heckdistro. Alles ist speziell angepasst. Wenn ich die Karte physisich in den Slot stecken will, muss die Heckdistro raus, damit ich an die Slotblenden komme. Das derzeitige Riser habe ich bereits in beiden Pcie-Slots probiert. Deswegen glaube ich nicht, dass es am Board liegt, sondern eher am Riser.
Wenn das wiederum nicht funktioniert, hole ich eine 4060 lokal und mache eine normale RMA bei der 4090.
Ein anderes Netzteil hab ich spontan nicht zur Verfügung. Könnte natürlich auch der Grund sein. Aber beim Booten bereits überlastet? Ich weiß nicht.
@Orklegend klingt unwahrscheinlich, weil die Karte @stock läuft und keine besonderen Sachen in 2D oder 3D gesehen hat. Ich hab kein Wallpaper-Engine laufen, sondern nur Windows 11 Desktop und 3D läuft bei mir derzeit Apex Legend mit max 220W dank FPS-Kappung auf 171 FPS @UWQHD. Das geht auch 1-2 h gut. Irgendwann schießt sich das System ab. Zwischendrin hatte ich mal 400 Watt per Furmark laufen lassen. Keine Auffälligkeiten.
@HisN
keine LED am Stromstecker, sondern die LED auf dem Strix B550 Gaming-E.
Ich komme beim Booten nicht mehr über diese LED (VGA in weiß) hinaus. Windows erreiche ich nicht mehr.
im Übrigen habe ich ein Cablemod mit drei netzteilseitigen Anschlüssen. Da diese Kabel eigentlich doppelt belegt sind (2x300W) und die Karte nur ein Powerlimit von 450 Watt hat (erste Gen Frostbite), kann es daran nicht liegen. Zudem ist das Verhalten mit dem originalen Adapter identisch. Auch habe ich die originalen Netzteilkabel an verschiedenen Anschlüssen probiert. Nix hilft.
deswegen morgen zuerst ein anderes Riser probieren. Hilft das nicht, kommt eine Übergangskarte rein. Läuft die auch nicht, ist die 4090 wohl nicht schuld.
Der Riser verschlechtert die SIgnalqualität und die SignalLatenz des PCIe-Datenbus. Wie gut deine Grafikkarte oder das Motherboard damit klar kommt, kann sehr unterschiedlich sein.
Kannst ja mal den den PCIeDatenBus auf PCIe3.0 begrenzen. Vieleicht kommt PCI3.0 besser mit dem Riser klar, als PCIe4.0
Einen Versuch wäre es wert.
Meine 4090 hatte auch massive Probleme mit dem (Lian Li) Riser. War nicht stabil zu bekommen.
Nimm mal eine 10w-Glühbirne in die Hand 🔥💡🔥
So kann man das nicht vergleichen... :d
Eine hohe Abwärme entsteht an Stellen mit hohem Übergangswiderstand (Stecker mit schlechtem Kontakt) bzw. an der Drahtwendel in der Glühbirne
btw:
Riser mag ich auch nicht. Aber zugegeben siehts mit Riser gut aus...
Gibt es da offizielle Tests, die das belegen, dass man unter Verwendung eines Riser nach Spezifikation messbare Leistungseinbußen hat?
Naja gut, vielleicht teste ich das über die Feiertage mal.
Wenn man sich vor Augen führt, welcher Aufwand beim Tracen der PCIe4.0 Leiterbahnen auf einem Motherboard getrieben wird, um möglichst kurze und verlustfreie Signalwege zu gewährleisten(Anpassung), ist ein Riserkabel eh absurd. Mag sein das der PCIeDatenBus genug DatentransfairReserven hat, um auch mit höheren DatentransfairFehlerraten noch ausreichend gut zu funktionieren. Technisch gesehen, greift sich der SchwachstromLehrling bei sowas aber sofort an den Kopf., spätestens wenn er die Bandbreiten und Taktfrequenzen des PCIe Bus zu Gesicht bekommt. Ein PCIe Datenbus ist ja schließlich keine TürGegensprechanlage.
Kannst ja mal versuchen die FehlerRate des PCIe Datentrasfair aus zu lesen, wenn du einen handfesten Beweis brauchst. Frag mich aber jetzt nicht wo und wie man die Fehlerrate auslesen kann. Dazu hab ich von Software zu wenig Ahnung...
Der Aufwand wird nicht zuletzt deshalb betrieben, weil man die Kosten für Redriver ICs einsparen will. Längere Übertragungswege sind mit Redrivern problemlos umsetzbar, siehe Kabel für Enterprise PCIe SSDs. Für PCIe 4.0 Grafikkarten ist das aber noch nicht notwendig.
Zu Leiterbahnen- bzw. Leitungslänge...
Das 3-adrige JST XT zu JST XH-Kabel (I2C/UART) meines EVC2SE ist 40cm lang wird ohne Abschirmung geliefert
Hohes 4090-OC war damit überhaupt nicht stabil, je nachdem, was in der Nähe des Kabels ist ("Antenneneffekt"). Provisorisch das Kabel mit Alufolie umwickelt und mit Masse verbunden.
Seit dem stabiles OC. Testweise Alufolie wieder entfernt - wieder instabil... :rolleyes2:
Ähnliche Themen
