[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sound/weitere Soundeinstellungen/Wiedergabe
Das Gerät anwählen, welches den Sound wiedergeben soll. Kannst auch mal wechseln und schauen, was passiert. Wenn sich aber Klangbalken bewegen, findet eine Wiedergabe statt, möglicherweise nicht am gewünschten Gerät.
Das Kabel muss natürlich auch mal geprüft werden. Wegen eines defekten Kabels hatte ich auch schon Probleme, nicht wahr @Thunderburne ? :)
Alles klar werde ich am Wochenende mal ausprobieren.
Das Kabel Funktioniert ja wenn ich es an einen anderen PC anschließe.
Hab mir das Kabel bestellt, der Grund ist, dass ab ca. 500 Watt Verbrauch, die rote LED anfängt zu blinken am Stecker, woran das liegt hab ich noch nicht raus gefunden aber vielleicht liegt es am Kabel.
Was für ein Kabel hast du grade dran Holzi
Das was beim Thor dabei ist.
Leg dir mal das von CableMod zu mit 3 8 Pin Anschlüssen. 500W auf 2 8 Pin kann klappen, ist aber eng auf Kante.
Nachricht gelöscht
Ich habe das schwarze für Asus von Fasgear genommen.
Fasgear PCIe 5.0 GPU Stromkabel ummantelt 70cm | 16pin(12+4) 12VHPWR Anschluss für RTX 3090Ti 4080 4090 4070Ti | 3x8pin(6+2) PCI-e Stecker kompatibel für ASUS EVGA Seasonic Modular Netzteil(Schwarz) https://amzn.eu/d/d8QtnaY
Haben hier wohl auch einige Leute im Einsatz. War erst skeptisch, aber sind alle wohl soweit zufrieden.
Und kostet weniger als die Hälfte von einem neuen Cablemod Kabel inkl. Versand.
Kann ich bestätigen. Erstaunlich gute Qualität für den Preis. Hatte es mit diversen 4090 im Einsatz, also auch mehrfach ab und angesteckt (DIE STECKZYKLEN!!!! :fresse: ), alles top. Hatte die schwarz weiße Version. Da es keine ganz weiße Version gab, bin ich dann auf das Seasonic Kabel umgestiegen. Haptisch noch etwas besser, aber ansonsten muss sich das Fasgear nicht verstecken.
Die erste 4090 wieder unter 1.900€, es normalisiert sich so langsam. Aber 200€ fehlen noch.
Ich habe die PNY damals für unter 1600€ gekauft, also da ist noch etwas Luft für normalisiert. :oops:
Schade dass es das nicht mit 40cm gibt, ich habe ein Seasonic Syncro Gehäuse im Keller stehen.
Und ich war froh, dass es das in 70cm gibt, denn die 60cm von Cablemod sind zu kurz. :fresse:
Reden wir hier vom Thor 1200w Platinum II ??
Es ist ein Single-Rail NT (Aufteilung der 12v-Schiene) - warum sollten drei 8 Pin Stecker einen Mehrwert gegenüber zwei bieten?
Ob zwei, drei oder vier 8 Pin Stecker einen Unterschied am Ende ausmachen, obliegt alleinig der 12v-Rail. Bei Multi-Rail sollten zwei 8 Pin Stecker auf die Rails aufgeteilt werden.
Dafür muss man aber wissen, welcher Stecker am NT wie an der Rail angebunden ist.
War bei mir der Fall. Strix mit dem Original Kabel blinkte ebenso bei mehr OC. Mit dem 3x8Pin Kabel keine Probleme mehr.
Klingt auf jeden Fall interessant, falls es mit dem neuen Kabel immer noch blinkt würde ich das auch mal probieren, kannst du bitte nochmal einen Link zu dem 3x8Pin Kabel posten, danke.
Vorsicht /:wenn es blinkt ist die 4090 kurz vorm implodieren:) Spaß. Meine tuf hatte damals durchgehend rot geleuchtet wenn der PC off war
Für 500W reichen 2x 8 locker...
Jenseits 600W siehts schon anders aus. Bei fast 850W droppt es mit 2x 8 ziemlich weit unter 12V. Bei 4x 8 lag ich immer noch über 12V
Siehe hier...
Bei meinen Benches vor paar Tagen musste ich die Corsair-12VHPWR-Kabelpeitsche gegen den mitgelieferten 4-Zack tauschen, weil der Spannungsabfall mit 0,5-0,6V viel zu hoch war bei sehr hoher Last
VGPU-Minimum war 11,47V. Mit dem 4-Zack kam ich bei gleicher Last nicht unter 12,06V. Die Benches waren damit stabiler...
Im Zimmer war es recht kalt, aber die Corsair-Kabelpeitsche war gut warm (viel wärmer als Körpertemp)
Wassertemp war nahe dem Nullpunkt. Und die GPU-Temp mit 1,25V im Schnitt bei 38°C (800-850W GPU bzw. 1.150-1.200W gesamtes System)
Zweimal war die Druckseite komplett mit Eiskristallen verstopft (Schlauch zur GPU und der komplette AB) :fresse:
@Holzmann
Auch du solltest es schaffen, dich durch den Cablemod Konfigurator zu klicken und dann würdest du feststellen, dass es auch ein 4x8Pin Kabel gibt. ;)
Aber das 3x8Pin sollte auch reichen. Das gibt es immerhin bei Caseking oder anderswo zu kaufen und du bist keine 70€ dafür los, wenn du es bei Cablemod kaufen würdest.
Ok habe das 3xpin via caseking bestellt, danke euch für den Tipp!
Ich weiß - keiner hat eine Glaskugel, aber was denkt Ihr: werden die Kühler mit der 5090 wieder kleiner, so daß die Grafikkarte insgesamt wärmer wird und sich eine Wasserkühlung wieder mehr lohnt? Mit der 3090 und einem Luftkühler waren ja Temperaturen so um die 70 Grad normal - mit der 4090 kamen größere Kühler und insgesamt waren es ca. 10 Grad weniger im Betrieb. Die 5090 hat ja mehr Leistung, sprich es muss mehr Wärme abtransportiert werden - also entweder höhere Temperaturen oder Kühleroptimierung. Irgendwo werden sicherlich auch die Grenzen bezgl. der Größe sein - klar kann man Grafikkarten mit 4-Slots und mit einer Länge von 38cm (oder mehr) machen, nur diese bekommt ja fast keiner mehr unter.
Insofern bin ich auf Eure Meinung gespannt - auch wenn es noch Zukunftsmusik ist. Aber vielleicht sieht man ja schon bei den neuen Super/TI Modellen ein Trend (kleinere Kühler und höhere Temperaturen).
Ich denke schon, dass die Kühler nicht mehr so "überdimensioniert" sein werden - was natürlich schade wäre. Am Ende ist es aber auch Marge, die die Hersteller liegen lassen, wenn der Kühler "größer" ist, als er eigentlich sein müsste. Asus hatte ja auch schon eine kleinere Variante der 4090 nachgeschoben.
Für den Fall habe ich meine Custom noch behalten. Wir werden sehen was dabei raus kommt . Finde es aktuell schön wie es ist .
Man hat halt flott sein System umgebaut .
Wäre jmd so nett und würde mal den Benchmark in "Topaz Video AI" laufen lassen?
Bekomme bei den 4x-Benchmarks hin- und wieder Fehler (ERR). ECC aktivieren brachte nichts. GPU lief @default (getestet auf 2 versch. Systemen, mit 2 versch. 4090)
Bei 4K "Apollo - 4x SlowMo" zieht die Strix (666W-BIOS) einfach mal so über 650W mit max. PL (GPU-Load @100%) :oops:
Wäre noch besser, wenn jmd mit 14900K oder irgendeinem fetten Ryzen (ab 16Cores) testen würde ;)
Hier unter WIN11...
Die Ergebnisse können unter WIN10 anders ausfallen. Aufallend ist, dass ich unter WIN10 bei den 4x-Benches fast nur Fehler hab
Lief ohne Fehler durch:
Muss mal schauen, obs evtl. am System-RAM liegt (@8.000MHz)
Man sieht, dass die 4090 sehr hungrig ist, der 14900KF kann die GPU schneller füttern. Daher auch mehr als 700W. Welches BIOS ist das?
BTW:
Wer Bock hat, kann mal ein FHD-Video mit mäßiger Quali auf 4K/60Hz umwurschteln. Bei „Enhancement - AI Model“ dort „Iris - Face“ @auto einstellen und abwarten, was passiert (jeweils mit „Low und Medium quality“). Echt krass, was damit möglich ist :oops:
Links (bei beiden Shots) ist jeweils das Original in schlechtem FHD und rechts auf 4K + "Face Recovery" hochgerechnet...
linker Shot "low quality" - rechter Shot "medium quality". Dieser Ausschnitt ist stark vergrößert (daher die Artefakte). Das "Dreieck" ist nur ein Wasserzeichen von Topaz
Ähnliche Themen
