[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Avatar ist das einzige Spiel was nicht läuft.
Grade mal per AB resettet und PT auf 80% gestellt. Systemfreeze nach 13 Minuten und 40 Sekunden.
Weder in der Ereignisanzeige, noch im Zuverlässigkeitsverlauf lässt sich etwas aussagekräftiges finden.
Kann nichts mehr gutes über die Karte sagen.
Avatar muss laufen, erst dann ist dein Setup wirklich stabil.
Mit meiner kaputten SuprimX läuft das Spiel keine 5 Minuten, mit der neuen PNY kann ich einen ganzen Tag spielen....Dann ist es aber wichtig, dass der Rechner insgesamt nicht zu heiß wird, d.h. das Kühlkonzept muss stimmen, da praktisch über Stunden ~400-450 Watt aus dem Gehäuse abgeführt müssen.
Bzw. die Engine ist ein Power Virus, Snowdrop hat mir damals schon mit The Devision 2 geholfen mein UV System auf Stabilität zu testen.
Auch für RAM Tests ist die Engine gut geeignet.
Wenn man Avatar in 4K mit den höchsten Einstellungen spielt ist es so als würde man die ganze Zeit Furmark laufen lassen. :lol:
Es läuft grade eine Inplace Reparatur.
Eine Ersatz GPU habe ich nicht.
Ich vermute auch, dass die Texturprobleme und verwaschenen Lichter irgendein Fehler sind, da viele Videos über das Spiel ordentlich aussehen. Mal abwarten, ob ein Patch kommt.
Mich wurmt so einiges aber vieles lässt sich nur mit unverhältnismäßigen Aufwand lösen, daher....
Gerade 90 min gezockt Avatar keine Abstürzte oder Crashs.
Die Snowdrop Engine hat früher bei the Division schnell Stress bei Ram OC gemacht und CPU OC..
Daran hat sich auch nichts geändert, die Engine ist immer noch sehr anfällig für OC. Egal ob CPU, GPU oder RAM.
Wenn z.B NT nicht so gut ist, die Engine nimmt es dem System übel.
Würde folgendes machen, GPU komplett auf Standard stellen.
CPU auf Standard
RAM auf XMP --> wenn möglich sonst mal 3200 Mhz versuchen
Dann mal im GPU Z, die Temps im Auge behalten, und zwar vor allem die vom GPU Hotspot wenn dieser auf ~85 Grad kommt wäre es z.b shice.
Bei der Gelegenheit auch mal schauen was bei 16 Pin Power Voltage angezeigt wird, ob konstant 12 Volt gehalten werden oder ob es schwankt, wenn es schwankt dann liegt das Problem am Netzteil oder an der Verbindung vom Adapter bzw. Kabel.
@EleCtricStream
Jo das Spiel nuckelt gut an der GPU 430 W sehe ich so gut wie immer GPU Taket auch runter .
Erst mit Undervolting 0,975V kann ich 2760 MHZ bei Ca 400 W halten mit meiner FE also ohne das PT hoch zu ziehen.
Läuft aber einwandfrei das Spiel.
2760 Mhz bei ~400 Watt in dem Spiel sind nice :)
@ stock ist die Belastung viel höher.
Da erreicht die CPU das Temp Limit und die GPU 80°C (teils 500 Watt+ ohne Peaks zu kennen).
Das ist nicht nur ineffizient, sondern extrem laut, da die GPU Lüfter.....sind.
Daher muss ein Powerlimit her.
Mal sehen was bei den 12V ist.
CPU ist bei 60C .
GPU bei offenem PT Sprich 133% GPU Stock 430-470W ca. 68C es gibt jedoch Sequenzen die bis zu 500W erreichen.
Ist halt die Gute Snowdrope Engine die saugt richtig.
Selbst mit 60% PT, unter 350 Watt und unter 70°C für GPU und CPU geht der Rechner aus.
Der Dateisystemfilter 'atc' (Version 10.0, ‎2023‎-‎08‎-‎07T12:21:14.000000000Z) hat die Umgehung von E/A verweigert.
Prozess: afop.exe
Datei: H:\Ubisoft_Games\AFOP\rogue\sdf\pc\data\sdf-........
E/A-Vorgang umgehen: FS_BPIO_OP_ENABLE
Ablehnungsgrund: Not allowed for requesting application.
Vorgangsstatus: {Zugriff verweigert}
Ein Prozess hat einen Zugriff auf ein Objekt angefordert, aber ihm wurden nicht die Rechte für den Zugriff erteilt.
Muss ein Softwarefehler sein. Spielbedingt.
Es variiert.
Manchmal friert der Rechner ohne Geräusche ein (Störgerausch im Audio zu hören) und muss manuell aus und eingeschaltet werden. Einmal ging der Rechner aus und ist selbstständig wieder neugestartet.
Bios ist jetzt @default. Mal sehen.
Bei mir hat "SDiF" den PC hart ausgeschaltet, wenn die Auflösung zu hoch eingestellt war bzw. das FPS-Limit zu hoch war
Also wenn die FPS "frei atmen" konnten hatte ich oft Probleme. Auflöung nur noch max. 4K + 120FPS limitiert - null Probleme
Ein fps limit (119 fps) ist über den RTSS aktiv.
Ich habe nun bei Amazon das Seasonic Kabel für 14€ bestellt. Sieht besser aus als das von Asus. ;)
Habe das ASUS Kabel für mein Thor und das Seasonic Kabel für mein Prime TX und: Oh welch Überraschung, es sind die selben da ASUS Netzteile von Seasonic sind.
Technisch, aber nicht optisch. ;)
Guten Abend,
ich hab mal ne frage und zwar habe ich an meiner 4090 3 Monitore via DP angeschlossen und einen Fernseher per HDMI.
Das Problem was ich hab ist ich hab auf dem Fernseher zwar ein Bild aber kein Ton.
Die Karte ist Senkrecht eingebaut und mit diesem Kabel auf das Board gesteckt.
Corsair Premium PCIe 4.0 x16 Verlängerungskabel 90°​
In der Nvidia Systemsteuerung hab ich eingestellt das über das HDMI Kabel Ton wiedergegeben werden soll und im Sound ist auch der HDMI Anschluss ausgewählt.
Man sieht dort auch einen Ausschlag wenn ich Musik oder einen Film anmache aber es kommt kein Ton.
Das Kabel geht von der Grafikkarte in einen AV Receiver und dann in den Fernseher.
Das Kabel Funktioniert auch da wenn ich es an einen anderen PC anschließe Funktioniert es mit dem Ton.
Wäre geil wenn mir Jemand helfen könnte ich weiß nämlich nicht mehr weiter.
Nur um das Einfachste auszuschließen: Wenn du das Kabel ohne Umweg über den Receiver direkt am Fernseher anschließt, kommt dann Ton?
Ja das habe ich versucht und auch so habe ich keinen Ton.
Das Problem ist mir bekannt.
Hast Du mal die Windows-Einstellungen "Sound" bemüht?
Möglicherweise will Windows, dass das Soundssystem "konfiguriert" wird.
Du meinst unter Sound -> Wiedergabe -> Rechtsklick auf den Nvidia High Definition Audio und dann Lautsprecher Konfigurieren? Das habe ich grade versucht mit allen dort vertretenen Möglichkeiten, aber leider Funktioniert das auch nicht.
Prozess: afop.exe
Das Kabel prüfen. Roman hatte es bei youtube mal gezeigt, dass ein kleines Wackeln schon reicht, dass die Karte nicht mit Strom versorgt wird. Dann geht der Rechner aus. Hatte ich auch einmal und dachte es lag an meiner Wasserkühlung, da es nach Pumpentausch dann weg war, ABER Romans Video hatte mich erst auf die Idee gebracht, dass es wohl das Kabel war, da der Durchfluss zwar niedrig, aber nicht zu niedrig war, dass der Rechner einfach aus geht. Versuch mal das Kabel anders, ohne Spannung, zu verlegen.
Hab mir das Kabel bestellt, der Grund ist, dass ab ca. 500 Watt Verbrauch, die rote LED anfängt zu blinken am Stecker, woran das liegt hab ich noch nicht raus gefunden aber vielleicht liegt es am Kabel.
Wenn das Kabel sich biegt, ist die obige Lücke sichtbar. Da das Kabel durch das Glaspanel zwangsweise gebogen wird, ist die obere Lücke immer sichtbar. Daher wüsste ich grade keine Lösung das Kabel 100%ig anzustecken.
Avatar ist bisher nicht abgestürzt.
Ähnliche Themen
