[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat jemand von euch eine Empfehlung für Wärmeleitpads? Welche hat ihr so mit Wasserkühlern im Einsatz? Gerne auch via PN.
Lohnt es sich der hohe Preis für Pads mit hoher Wärmeleitfähigkeit? 5 W/mk werden bereits für 5 € (100 x 100m, Dicke 1 mm) angeboten (quasi no name), die von Phobya kosten 19€ bis hin zu 18 W/mk für 138€ (AC Apex).
Bei meiner 1080Ti habe ich solche mit 5 W/mk verwendet und keine negativen Auswirkungen bemerkt...
Lohnt nicht, außer für den Händler…
Habe die „Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk“
Hatte damals diese Rechnung gemacht…
Beispiel für die 3080FE…
1x 80x40x3mm Gelid Extreme 12W kostet ca. 17€ oder 0,53€/cm² oder 34€ nur Rückseite!!!
2x 120x20x1,5mm „Eisschicht“ 11W kosten aber 70€ oder 2,92€/cm² oder 140€ nur Rückseite!!! :rolleyes2:
übertreibt man es…
2x 120x20x1,5mm „Eisschicht“ 17W kosten satte 250€ oder 10,42€/cm² oder 500€ nur Rückseite!!! :oops:
wir sind ja im Luxx :d
Echt heftig, was manche „Lappen“ kosten!!!
Eine Alternative könnten 3mm AC Rise Ultra Soft 7W für 0,40€/c sein, die angeblich sogar besser, als Gelid Extreme 12W sein sollen
(hab dazu zwei Tests von Igor verglichen - die „Rise“ waren 15k besser, als Gelid Extreme und sind sogar viel günstiger)
btw:
Möglichst keine Silikon-Pads nehmen, weil die (je nach Quali) ausbluten (ölen) und aushärten können
Sag gern mal Bescheid ob es läuft. Habe auch schon mit dem Gedanken gespielt so ein 90 Grad abgwinkeltes Kabel zu kaufen.
Avatar lässt mein System immer noch noch nach ein paar Minuten einfrieren. Da hilft nichts. Muss ich wohl auf einen ordentlichen Patch warten.
Auch ein Spiel wo die Leistung selbst mit Dlss im Leistungsmoduls nicht reicht, da das Spiel mit 60+FPS nicht flüssig läuft. Irgendwas stimmt da nicht. Cyberpunk Path und Psycho läuft mit FrameGen nahezu 1a.
Avatar läuft bei mir ohne Abstürze.
Hab sogar Max Grafik Settings frei geschaltet über den Launcher.
Jemand eine Ahnung, was das wieder für eine Shice sein soll? Gestern alles qool, heute nach dem Einschalten unter Windows regnet es entweder black screens (SDD arbeitet aber weiter) oder PC resetet sich (einmalig) oder siehe pics (auch einmalig):
Oder Telemetriemonitor:
Kannst Du als Test bitte den Ram runtertakten?
Vom Standardwert ausgehend sollten -500 reichen.
Danke im Voraus !
Sieht verdächtig nach VRAM-Fehlern aus.
Beste Grüße
Ok, werde jetzt mal stock fahren.
Zuverlässigkeitsverlauf:
oder:
@Orklegend
Hast du irgendwas übertaktet? Klingt für mich eher nach unstabilen System.
Alle anderen Anwendungen/Spiele laufen ohne Abstürze.
Im Moment läuft die Karte mit 2560mhz@0,880v.
Mit stock settings legt die Karte zu viel Spannung (1.05v) an. Damit stürtzt das Spiel auch ab.
Darf aber nicht sein .
Die Karte muss @ Stock laufen.
Avatar ist das einzige Spiel was nicht läuft.
Grade mal per AB resettet und PT auf 80% gestellt. Systemfreeze nach 13 Minuten und 40 Sekunden.
Weder in der Ereignisanzeige, noch im Zuverlässigkeitsverlauf lässt sich etwas aussagekräftiges finden.
Kann nichts mehr gutes über die Karte sagen.
Nun gut Avatar habe ich nicht .
Das Game hat mich in den Tests nicht überzeugt bis auf die Grafik .
Grafiktechnik bin ich eher enttäuscht. Hatte mir nach der Digital Foundry Analyse mehr erhofft.
Viele Texturen und die Globale Lichtberechnung wirken oftmals verwaschen und matschig.
Selbst viele YouTube Videos sehen anders aus. Vielleicht hilft dagegen ein ordentliches Reshade Preset.
Ah ok irgendwie auf den Bildern sahen die Texturen gerade ziemlich stark aus.
Dachte wäre Grafik mäßig so eine Granate das Game . So finde ich das Game für mich uninteressant. Avatar habe ich nie mir angeschaut und das Game lebt mehr von sammeln und erkunden. Story ist da nicht viel soweit was ich rausfinden konnte .
Daher verzichte ich darauf .
Also mich würde das extrem wurmen. Wer weiß ob es nicht noch mehr Games gibt, die du halt aktuell nicht testen kannst. Oder zukünftig. Wenn die Karte @Stock nicht richtig läuft würde ich zumindest mal eine andere GPU testen um das Problem einzugrenzen. Wenn es ein Problem des Games wäre, müsste es ja auch mit einer anderen GPU passieren wenn der Rest des Systems gleich bleibt.
Es läuft grade eine Inplace Reparatur.
Eine Ersatz GPU habe ich nicht.
Ich vermute auch, dass die Texturprobleme und verwaschenen Lichter irgendein Fehler sind, da viele Videos über das Spiel ordentlich aussehen. Mal abwarten, ob ein Patch kommt.
Mich wurmt so einiges aber vieles lässt sich nur mit unverhältnismäßigen Aufwand lösen, daher....
Mit meiner RTX4090 läuft avatar völlig unauffällig und problemlos. Würde daher auch sagen, dass es an deinem System (muss ja nicht unbedingt die Hardware sein) liegt. Würde nochmal Windows frisch installieren, aktuelle Treiber drauf und dann @stock testen. Ist es weiterhin da: Hardwarefehler, ist es weg: Softwarefehler. Zumindest ist die Wahrscheinlichkeit sehr hoch, dass es so rum ist.
Ich hab es wegen der Optik (weiß) und wegen der Biegsamkeit bestellt. Als ich dann die 4070Ti vertikal eingebaut habe, hab ich mir noch die 90° Version bestellt, die ist genau so wertig.
hast Du mal nen Link, bitte?
Nur wegen der Optik oder was ist der Grund?
Edit: wegen den 90 Grad nehme ich an
Nur wegen der Optik, aber nicht die 90 Grad Version. Der Stecker ist in der falschen Richtung für die SuprimX.
Aber das Kabel von Asus ist optisch nicht mein Fall (siehe Bild).
Ähnliche Themen
