[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hi Leute, ich leg mir grad etwas die Karten.
Ich hab folgendes Problem..
Wenn ich Windows installiere, kommt es während der Treiber-Installationen immer wieder zu Abbrüchen und Artefakten ( Maus lässt sich noch kurz bewegen dann friert das Bild ein ). Danach dann BSOD wie unten in den Fotos dargestellt.
Das selbe System lief aber vorher für 1,5 Tage „halbwegs“ normal .. hatte da beim öffnen von Programmen ab und an mal nen Unterbrechen bei der Maus Bewegung (und Programme brauchten manchmal etwas lange im Startvorgang)
Aber ein Timespy Extreme lief gut durch (ebenfalls Bild im Anhang)
Der Normale Timespy hingegen war von der erreichbaren Punktzahl bei der GPU auf 30K beschnitten (wo sie ca 38K machen sollte) - soll aber laut Foren eher nen 7950X3D CCD Zuteilungsproblem sein.
Hat jemand schon mal was ähnliches wie auf den Bildern gesehen?
Hab bereits schon einiges an Hardware getauscht (aber immer wieder die selben Probleme) ..
CPU, Mainbaord, RAM, SSD.. alles andere ist noch beim alten geblieben.
Ist das nen GPU Problem, oder kann das auch nur am Riserkabel der GPU liegen? (Da das System in nem Loop hängt, würde ich ungern mehrere Male basteln - ist sehr undankbar im V3000 plus Gehäuse 😅)
Ein Netzteil würde andere Probleme verursachen oder?
Danke für eure Hilfe ❤️
System:
AMD 7950X3D
Asus Gene X670E
Inno3D 4090 Ultra Frostbite (am Linkup - AVA 5 PCIE 5.0 Riser Kabel)
Corsair AX1600i
RAM G.Skill 8000mhz CL40 2x24GB (bereits auch schon mit verschiedenen Takten getestet) und auch schon nen 6000mhz Expo Kit getestet
Windows 10 und 11 probiert
Treiber alle auf dem neuesten Stand 👍🏼
Nachricht gelöscht
Danke für eure antworten😊
Ram war von nem Kumpel geliehen 😅 (wollte halt auf Nummer sicher gehen)
Riser ist leider nicht fix umgebaut durch die Wakü und das V3000 plus .. aber werd das dann nun machen ❤️
Es muss ja ne Lösung her 😣
was machen sie mit denen dann? Powerlimit 700w?
Doch noch 4090 Super und Titan? :fresse: Blackwell angeblich verzögert
Wer die 4090 bei VÖ gekauft hat, machte alles richtig :)
Wieder ein Jahr ohne 5090.. Eine 4090 Super wird dann schon wieder ~2500 Euro kosten, ne Titan dann evtl 3500-4000 Euro..
dann lieber auf die 5090 warten :d
und meine 4090 Matrix bleibt mir doch noch länger erhalten :fresse:
Hieß es gestern oder vorgestern nicht noch, dass die 5090 pünktlich kommt und damit im Oktober?
Die war schon ewig auf 2025 verschoben. An diesen Gerüchten hat zumindest niemand mehr gezweifelt.
Am Anfang hieß doch Herbst 2025.
Also schauen wir mal nächstes Jahr.
Keine Ahnung warum man glaubt Herbst 2024 oder Frühjahr 2025.
Aber JETZT ist es dann Herbst 2025. :fresse:
Wenn sie wirklich noch eine 4090 Super oder Titan bringen kommt Blackwell auf keinen Fall früher.
Herbst 25 ist nun auch übertrieben, es hieß schon immer Anfang oder Q1/2025.
Anfangs wurde gesagt ein Jahr später .
Also Herbst 2025.
Aber auch egal kommt wenn es kommt.
Die super oder Titan können die ja gerne bringen . Meine normal die 4090 User brauchen da nicht zwingend wechseln. Lohnt sich einfach nicht .
Naja Herbst 25 wäre mir auch bissel zu spät, erst gestern mal Immortals of Aveum mit UE5 probiert, dass Teil ruckelt ja wie irre, auch mit FG und DLSS Q.
Geht von 116Fps bei mir immer sprunghaft auf bis zu 40FPS runter und das quasi ständig.
...was wohl kaum an der 4090 liegt. ;)
Sofern AMD keine ernstzunehmende Konkurrenz darstellt, solange werden wir die 4000-er Generation am Start haben. Deswegen klopfen wir uns jetzt alle gegenseitig auf die Schultern und freuen uns, dass wir uns frühzeitig für eine RTX 4090 entschieden haben ;)
Ich gebe mal die gewagte Prognose ab, dass es Jensen völlig (Leder-)Jacke wie Hose sein wird, was dir zeitlich passt :fresse: Man wird ganz genau abwägen, wie der Börsenkurs steht, wieviele Chips man für andere Zwecke braucht und wie die Produktionskapazitäten bzw. deren Preise sind.
Ganz so lange wird die 4000er Generation nicht leben. Aber bei dem Thema mit den Aktienkursen ist was dran. Solange KI die Aktienkurse puscht, solange kann man Gamer warten lassen (weil, auch keine Konkurrenz). Wenn dann erstmal alle brav ihre KI Chips gekauft haben, muss man was neues präsentieren und dann kann man auch mal wieder den Gamermarkt streicheln; schließlich weiß ja keiner wie lange der KI Hype hilft und deshalb braucht man andere zahlungsfähige Deppen.
Gerüchte sagen AMD bringt kein high end GPU mehr deswegen hat wahrscheinlich Nvidia auch keine Eile. :d
Solange die Chipausbeute nicht besser ist als bei der alten Generation, kommt die neue Generation auch nicht auf den Markt.
Ähnliche Themen
Antworten
6K
Aufrufe
397K
