[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Durch das ständige prüfen der Verbindung mit neuem aufstecken erhöht sich das Risiko um ein vielfaches. Lieber einmal richtig einlochen und gut ist.
Wie gesagt lediglich optisch Prüfe ich es weder fasse ich den stecker noch rüttel ich an ihm etc
Wenn ich die Filter vom Gehäuse säubere (~1x im Monat - wegen den Katzen) nehm ich mal die Taschenlampe vom Handy und schaue ob sich ein Spalt gebildet hat. War bisher aber nie der Fall.
Ich transportiere meinen Rechner manchmal. Danach kontrolliere ich immer auf GPU Seite ob der Stecker noch richtig sitzt. War aber nie was auffälliges dabei. Das Cablemod Kabel sitzt bombenfest.
Holt mich bitte mal ab.
Ab welchen Werte sollte man alamiert sein?
Welche Werte liegen innerhalb der Toleranz?
Hat jemand eine Ahnung wofür das "E" steht? Es gibt auch eine Version ohne "E", die ist aber teurer und weniger gut verfügbar.
Keine Ahnung, aber der Unterschied ist wohl nur die externen Anschlussmöglichkeiten an der Karte
Habe mit der 4090 auch das Netzteil gewechselt und finde die Steckerlösung von MSI beim MSI A850G nicht schlecht,einfach drücken bis keine gelbe Farbe mehr zu sehen ist.
Ich schließe mich bei 11,8V an...
Würde aber, wenn möglich, nen Sensor an den Stecker basteln und in der Software Mindestspannung setzen und sich alamieren lassen
Das hier war nur kurzfristig und immer unter Aufsicht...
Bei meinen Benches vor paar Tagen musste ich die Corsair-12VHPWR-Kabelpeitsche gegen den mitgelieferten 4-Zack tauschen, weil der Spannungsabfall mit 0,5-0,6V viel zu hoch war bei sehr hoher Last
VGPU-Minimum war 11,47V. Mit dem 4-Zack kam ich bei gleicher Last nicht unter 12,06V. Die Benches waren damit stabiler...
Im Zimmer war es recht kalt, aber die Corsair-Kabelpeitsche war gut warm (viel wärmer als Körpertemp)
Wassertemp war nahe dem Nullpunkt. Und die GPU-Temp mit 1,25V im Schnitt bei 38°C (800-850W GPU bzw. 1.150-1.200W gesamtes System)
Zweimal war die Druckseite komplett mit Eiskristallen verstopft (Schlauch zur GPU und der komplette AB)
:fresse:
Wird Zeit für die 5090, da gibts hoffentlich die Stecker nicht mehr.
Ja, es wird tatsächlich einen neuen GPU-Stecker für die Nvidia RTX 5090 geben. Die aktuelle Generation der Grafikkarten verwendet den 12VHPWR-Anschluss, der jedoch einige Probleme aufweist. Nvidia arbeitet daher an einem neuen Anschluss, der die 12VHPWR-Problematik endgültig lösen soll. Dieser neue Stecker wird als 12V-2x6-Design bezeichnet und ist Teil der kommenden ATX 3.1-Spezifikationen.
Das ist zwar ein neuer Standard, aber die Stecker sind doch untereinander Kompatibel, oder?
Eins weiß ich immerhin sicher, ich werden kein Kabel von CM kaufen :d
Ich hätte von Seasonic/Asus gern so ein Kabel mit neuem Stecker aber auf 2x8 Pin. Ich hoffe da kommt was wenn die neuen Grafikkarten erscheinen.
Wir bekommen eh wieder fiepen und einen Stecker den keiner wollte. :fresse:
Beides? :d
Vielleicht muss man einfach ein Stöhnen ertönen lassen, wenn der Stecker richtig drin ist :shot:
:ROFLMAO:
Na ja - Vorteil: kein Stecker in der GPU / Nachteil: gleicher Stecker im Mainboard -> dann wieder Vorteil: Mainboard ist nicht so teuer, wenn es abfackelt :ROFLMAO:
Ähnliche Themen
