[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das Final 7.3.6 des RivaTuners ist bereit zum Download.
Wäre cool wenn NV umfangreiche OC Funktion einführt in ihre App hatte da was vor Paar Tagen gelesen das man das wohl plant.
Würde das begrüßen wenn alles vollumfänglich in der App machbar wäre.
Oc on the fly direkt im Spiel so wie das Freestyle Tool.
Driver embedded OC und OSD Features würden mir auch besser gefallen als Drittprogramme zu nutzen. Allerdings darf das dann nicht so etwas lasches wie das NV Experience OSD sein beispielsweise. Das muss richtig konfigurierbar sein etc..
Also Featureset mindestens analog MSI Afterburner / CapframeX und ich bin dabei. :)
Wen das Capture nicht drin wäre könnte ich mit leben Hauptsache OC und Auslesedaten wären umfangreich das wäre ein großer Schritt für den Treiber.
Das Capture wäre dann nice to have.
Nutzt hier jemand das Performance Overlay von der neuen Nvidia App? Bei mir funktioniert das nicht wirklich. Alle Werte außer FPS frieren innerhalb von 30 Sekunden oder so einfach ein
Ich weiß, dass das funktioniert, das war aber nicht meine Frage. Ich habe Riva Tuner nicht ständig laufen und manchmal will ich mal kurz das Nvidia Ding anschalten. Mit GF Experience lief das auch gut aber nicht mit der App
Das N1 ist eig. ein NAS-Case...
Und coole Idee mit dem Monoblock für CPU und GPU
Teil 2 + 3 :)
Funktioniert in den meisten meiner Spiele einwandfrei.
Mal abwarten, bisher heißt es ja die Werke von TSMC seien nicht stark betroffen.
Und ein Weiter 16 PIN anschluß der Verreckt ist
Als ich heute OW2 gezockt habe und auf einmal ein Beißenden Plastik Geruch wahrgenommen habe war mein verdacht sofort der anschluß und dank AIDA64 sieht man jetzt die 16PIN Voltage und man konnte sehen wie sekündlich die Volt runter gingen angefangen bei 11,8 bis runter zu 11,6 dort habe ich dann sofort den PC ausgemacht und den stecker versucht abzu bekommen und das ergebniss sieht man war ein Kabel von von MODDIY
Hab die Karte heute gleich zu Kris-fix gesendet und habe mir jetzt das Original Bequiet 90° kabel gekauft das war mein erstes und letztes Zubehör Kabel
Da schaut man jede woche ob der Stecker richtig sitzt und trotzdem Fackelt er schrecklich
Gottseidank ist am Stecker der 4090 nix nur das Die pin Rückstände drin stecken aber nix hat geschmorrt war ich noch schnell genug
Man sollte evtl doch bei den Hersteller Kabeln bleiben und nicht von MODDIY oder noch schlimmer Cablemod holen…
Irgendwie kriegen sie es hin dieses Crap Kabel/Anschluss noch crappiger zu machen als es so schon ist 🤣
Ja habe auch heute gleich mit MODDIY kontakt aufgenommen und sie übernehmen die Reperatur kosten für meine 4090 anstandslos
Daher habe ich mir auch das Originale BeQuiet 16pin 90° jetzt gekauft das ist original und Fertig
Ich bereue es wirklich keine Minute, dass ich mir gleich nachdem es erhältlich war, ein originales 12VHPWR-Kabel von be quiet! geholt habe. Es ist zwar nicht gewinkelt, aber passt trotzdem noch ohne großes Umknicken in mein Define 7 rein. Fein!
Ich habe ja bei meinem BeQuiet das 16pin Kabel weil ich nativ den 16pin anschluß am Netzteil habe aber die Kabel sind so steif und man konnte es so schwer knicken das ich eben bedenken hatte das Kabel könnte dann raus rutschen aber BeQuiet hat ja jetzt das 90° kabel und da habe ich heute auch nicht 1 sek überlegt
Ich verwende immer noch den cable mod Stecker in der H++ Variante. Bisher kam das Teil nie über 71°C, hab den Temp.sensor drangeballert.
Nochmal Ejakulanz :o wird es aber von cablemod nicht mehr geben. Immerhin hat der support von sich aus auch gefragt, wie hoch der Versand der GPU zu kriswichs war, auch das wurde erstattet.(y)
Wie lange hattest du das das MODDIY Kabel im Einsatz?
Anhang anzeigen 987353Anhang anzeigen 987354Anhang anzeigen 987355Anhang anzeigen 987356
Wie hast Du gemerkt, dass das Kabel die Biege macht? Geruch, LED an der Karte?
Ähnliche Themen
