[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist korrekt, und damit braucht man dann (je nachdem in welchem Umfang man Afterburner etc genutzt hat) eben diese Programme nicht mehr, für manche sicher praktisch.
Wenn man es genau nimmt brauchte man vorher Afterburner auch nicht für sowas weil man auch vieles über die (weniger komfortablen) Command Line Tools von Nvidia machen kann :d
Vielleicht meint er den OC-Scanner, da kann man sich ja theoretisch einen Spannungspunkt in der Kurve aussuchen, nachdem man gescannt hat.
Es gibt einen "Voltage Maximum (%)" Slider in der App, dann gehts ja vielleicht mit "Tuning" im UV Bereich, für manche sicher praktisch :d, zumindest um einen Anhaltspunkt für die Optimierung zu bekommen.
Abgesehen davon, ob das jetzt vorher schon im Terminal oder mit 3rd Party Software ging, ist es doch praktisch wenn das von Nvidia direkt (mit GUI) bereitgestellt wird
Es war doch nur eine Frage der zeit bis Nvidia das selber umsetzten tut es gibt ja nur Afterburner und dort passiert rein garnix mehr seit jahren hier und da ein update für die neue Generation und das wars dann gibt es ASUS Tweak was so semi gut läuft
Und das Nvidia OC sieht fast 1:1 aus wie Afterburner und hat alle wichtigen einstellungen was will man mehr
Das Automatisches Undervolting seit Jahren geht, wäre mir neu. ^^
Sorry - hatte UV übersehen...
Mom. ist es ja eher OV. Bei wenig Last zb 0,9V - bei viel Last 1,1V
Wurde ja auch mal Zeit... :d
Ob die eine UV Variantejemals raus hauen? Wäre echt mal ein Schritt in die richtige Richtung.
Nvidia ist ja jetzt dafür die Karten in die itx Gehäuse zu stopfen
Zuerst zu große gpus bauen das alle neue cases kaufen und jetzt für kleine werben :) make money
Aber Vorsicht. Zuerst richtig einstecken
Ich hatte damals die offizielle Stellungnahme eines NVIDIA Pressesprechers bzgl. der Steckerthematik gar nicht richtig mitbekommen...:unsure:
Aktuell glaube ich, dass ich die 4090 vorerst mal behalte und die 5090 nicht kaufen werde.
Glaube die Karte wird dreck. Noch schlimmer als es schon die RTX 2080TI war.
Für AMD und sogar Intel ist das dann die Chance aufzuholen.
nein, der duft vernebelt ihm die sinne, das ist etwas anderes... "zu kopf gestiegen" kommt halt noch dazu :d
Da gehe ich mit. Muss man natürlich abwarten aber die Vorzeichen sehen nicht gut aus. Und die 4090 dürfte vor allem auch wegen aktuellen Frame Generation Techniken noch einige Zeit stark genug bleiben. Kohle weglegen und in die 6090 dann zum GTA 6 PC Release investieren ✌️Aber so ähnlich habe ich es vor dem 4090 Release auch gesehen und dann war die Karte auf einmal ein absoluter Überflieger. Also mal sehen.
ich wollte auch nie so viel Geld für ne GPU ausgeben und jetzt kann ich hier garnicht schreiben wie viele ich davon hier hab 🫣
Auch will ich nicht wissen wieviele von uns die 5090 direkt am Erscheinungstermin bestellen oder vielleicht sogar gleich in der Kralle haben :p
Ja wenn die Karten sli fähig sind wird es ein Armageddon da viele bencher sich erstmal 2-5 Karten kaufen werden
Wieviele? Raus mit der Sprache :d
sind schon einige :hust: ,
sind aber auch nicht alles nur 4090er
Muss mal wieder ein Familienfoto erstellen, aber ich suche noch ein OVP zu meiner weißen Strix.
Wenn jemand eine über hat, gerne melden !!!
Verdienst du und die Anderen irgendwie Geld mit falten? :fresse:
das wäre ja zu einfach, aber dann würden es wohl noch mehr Leute tun :d
Meine 1080 Ti habe ich auch behalten und die 2080 Ti übersprungen da mir die Leistung nicht gefallen hat. Danach wurde es eine sehr starke MSI Suprim 3080 die mit 2.1Ghz sehr nahe an der 90er war. Die Zeiten als 80er und 90er so dicht zusammen waren, sind aber wohl vorbei.
Bei Blackwell bin ich noch unentschlossen, kommt auf die Leistung an. Ab +50% wirds interessant. Wiederverkaufswert der 4090 wird aber auch ganz ordentlich sein.
Ja habe extra vorher auch noch Hellblade 1 gezockt, da hat es echt immer wieder geruckelt… Hellblade 2 hat bisher nach 5 Stunden nicht ein einziges mal gezuckt.
@MS1988
Aber Spiel mal das UE5 Game Immortals of Aveum (aktuell im Game Pass), dass ruckelt und zuckelt an jeder Ecke… furchtbar. 🤮
Immortals of Aveum
Das Spiel stellt eine kleine Besonderheit dar.
Es läuft auf meiner 7900 XTX sehr smooth.
Mit dem kürzlichen Update FSR 3 FG dazu, was nochmals ein Boost bringt.
Dagegen läuft das Game auf meiner 4090 sowas von Shitty ... Stutter hier und da.
Zum Kotzen.
Ich würde mal sagen:
Da liegen bezüglich Frametimes schon Welten dazwischen.
Mit ein Grund, warum ich zwei Systeme am laufen hab.
Selbst testen, wo es besser läuft.
Keine Ahnung, wer hier was verkackt hat.
NV oder der Publisher.
Ähnliche Themen
