[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier noch mal eine Info zu den Corsair NTs und dem Netzteil Kabel!
Erst ab 1200W für 600W geeignet!
Da hab ich ja mal Glück gehabt mit meinem HX1200i
Den entsprechenden Adapter hat der Hersteller auf der eigenen Webseite bereits gelistet und ab Ende des Monats soll er erhältlich sein. Der Adapter ist dabei mit allen Type-4-Netzteilen kompatibel, was abermals in einer Liste überprüft werden kann. Um jedoch die vollen 600 Watt über den neuen 12VHPWR senden zu können, setzt Corsair jedoch ein Netzteil mit 1.200 Watt oder mehr voraus. Modelle mit 1.000 Watt dürfen 450 Watt liefern und für 300 Watt über den neuen Anschluss ist ein Modell mit mindestens 750 Watt nötig.
Hab das be quiet! Dark Power Pro 12, hoffe hier wirds auch ein paar Infos zur kompatibilität geben. Seit den Videos zu den ATX 3.0 Netzteilen bin ich ein wenig verunsichert. Da das Netzteil teuer war und noch super läuft würde ich auch ungern wechseln.
Corsair scheint mit 1200W auf NR. Sicher zu gehen für 600W Graka.
Hier wurde schon gefragt:
Bin ja gespannt ob mein 750 Watt RMx von Corsair noch langt.
Könnte knapp werden, habe mit meinem 9700k und 3080 Ti mit 350Watt einen gesamtverbrauch von 600 Watt bei Cyberpunk und Metro Exodus mit max details gemessen.
Das war auch das höchste was ich hatte.......150Watt Luft wäre also noch übrig.
Eine 4090 mit leichten undervolting könnte knapp drinn sein
Warum bist Du nicht in FHD unterwegs?. Cyberpunk kommt mit der 3090 in den von Dir genannten Settings nicht mal auf 60 FPS, und ist bestimmt nicht der einzige Titel. Ich kann ja mal wieder meinen 5 FPS RDR2-Screen rausholen. Eine Graka bekommt man immer klein.
Null-Argment :-)
Aber ich glaue, die Diskussion haben wir alle zwei Jahre 8-)
Du stellst die falschen Fragen und lieferst dadurch selbst Nullargumente. CP2077 spiele ich nicht und RDR2 habe ich nicht. So einfach ist das. ;)
Aber ja, du kannst gerne Spiele runterprügeln auf 5fps wenn dir dabei einer abgeht, und so 24/7 spielen. Ist auch eine Möglichkeit. Welchen 8k Monitor/Fernseher benutzt du dafür? (y)
Ich mache mir da bei meinem AX1000 Titanium keine sorgen , aber habe im alltag auch nicht vor das PL über 450 Watt zu nutzen.
Werde es lediglich zum benchen hoch jagen und das wird das NT packen.
Da bin ich mir sicher.
Wie machen die das ?
Sperren sie bis 1000W NTs oder ist das nur eine Empfehlung für 1200W
Weil liest sich halt so als wen geblockt wird !
Weil es findet ja ne Kommunikation über den 4 Pin Anschluss statt!?
Ich weis es nicht !
Ist nur ne Empfehlung. Die können das nicht limitieren.
Wenn das Nt wirklich am ende ist , dann schaltet es ab.
Dann grenz das doch bitte ein, und benutze es nicht pauschal.
Für 4k bin ich auch noch skeptisch. Deswegen ballere ich noch mit UWQHD rum. Man muss eben auch daran denken, da kommen noch ein paar AAA Titel in den nächsten 2 Jahren und die werden die 4090 sicher schrotten in 4k alles max +RT.
Das ist nicht "CP spiele ich nicht und RDR2 habe ich nicht". Sind schließlich AAA-Titel, oder nicht?
Zum 8K-Monitor:
Gar keinen, ich nutze SSAA oder DSR bzw. DLDSR wenn möglich.
Zu "alles max" was hier in den Foren gerne als inflationäre und extrem leere Floskel gebraucht wird, gehört bei mir nämlich das beste Anti-Aliasing, das man bekommen kann, dazu. Wer bei seinen Games z.b. den Regler für Screen Resolution vergisst (nicht bedient) hat nicht "alles max" :-)
Allerdings stehe ich damit meistens allein auf weiter Flur^^
Ich hab übrigens einen LG 42" OLED hinter der Graka, bzw. seit 7 oder 8 Jahren UHD.
Und ich zocke nicht gerne mit 5 FPS, das ist nur mein übliches Beispiel für das allgemeine "aber 4k zieht so viel Leistung"-Geplärre im Zusammenhang mit "ich muss aber jeden Regler ganz rechts haben" rumgeeier, was meistens fernab der Wahrheit liegt^^
Das Du mir da was anderes anhängen möchtest ... ist die übliche verklärte Denkweise in den Foren, weil man den Spiegel, den ich vorhalte nicht sehen möchte^^
Die 5 FPS bekommst Du nämlich bei "alles max" in WQHD. Darum geht es mir. Ich kann also gar nicht zur "alles max"-Floskel-Fraktion gehören, weil ich ja in UHD seit 7 Jahren mit ausreichenden FPS unterwegs bin.
Ich glaube auch, dass du da alleine unterwegs bist. Darauf wollte ich auch hinaus mit der 8k Monitorandeutung.
Zum 8K-Monitor:
Mein pauschaler Ansatz trifft aber gut zu und auf viele hier im Forum. Du selbst sagst ja, du bist ein Einzelfall.
Das was ich hier beobachte, ist, dass immer wieder einer hier auftaucht und meint, er hat zu wenige fps. Dann wird festgestellt, er spielt in 4k.
Mir sind 5fps in CP2077 in UWQHD noch nie untergekommen und das noch mit meiner 2080Ti, und ja, alles max hier, auch RT psycho (+DLSS Q). Und wenn es denn doch vorkam, dann wohl nur so kurz, dass ich es nicht bemerkt habe oder von meiner Rübe einfach als unbedeutend abgetan wurde, so dass diese Situation nur noch durch Hypnose hervorgeholt werden kann. Es gab früher noch so einige Spiele, die aus dem nichts plötzlich auf 1-5fps dropten, weil man in eine bestimmte Richtung geschaut hat. Das lag daran, dass die Devs schlampig programmiert haben. Vereinfacht gesagt: Es wurde schlicht das ganze Level in dem Moment in der Graka berechnet, obwohl nicht das ganze Level zu sehen war. Das ist nun seltener geworden, nun sind wohl andere Effekte dafür veranwortlich. Aber vllt kommt das heute auch noch vor.
Du selbst hast dich eben dermassen auf diese 5fps Situationen sensibilisiert, dass du das immer wieder zum Thema machst. Dabei kümmert es die wenigsten, weil es einfach selten auftritt. Daher ist mein pauschaler Ansatz in Ordnung, der auf dich als Einzelfall eben nicht zutrifft. Alle anderen wissen schon wie meine Aussagen gemeint sind.
Alles Min, Alles Max, ohne im Treiber rumzuspielen. Nur Regler im Spiel. WQHD.
Und CP .. Alles Max in FHD, ohne es mit dem Anti-Aliasing zu übertreiben^^. Da hab ich nie was von 5 FPS gesagt, sondern keine 60 FPS.
Die Leute heulen doch alle wegen ihrer FPS.
Ich glaub das hat wenig mit der Auflösung zu tun, sondern eher mit "alles max" :-)
Oder es hat mit "nur in RDR2" zu tun? :o
Videocardz berichtet, dass morgen die Zen 4-Reviews kommen. Das wird es wohl sein. 05.10. für Lovelace-Reviews macht mehr Sinn, ist ein Mittwoch und eine Woche vor Release.
Wenn ich AMD wäre und die momentanen leaks und Cyberpunk und Graphen von NVIDIA sehe und weiß, dass meine Karten besser und effizienter sind, würde ich direkt eine krasses Gorillamarketing machen und einfach nur die Nachricht raushauen „our cards will run faster and more efficient“ 😃
CB m8 gerade eine Umfrage: https://www.computerbase.de/2022-09/nvidia-geforce-rtx-4090-4080-ada-lovelace-voting/
War das Release der GeForce RTX 4000 überzeugend?
  • Ja, die neue Architektur und die darauf basierenden Grafikkarten sehen sehr interessant aus
    12,2 %
  • Nein, ich hatte mir von dem Release deutlich mehr versprochen und bin enttäuscht
    24,5 %
  • Keine Ahnung, ich konnte mir bisher noch kein besonders gutes Bild machen
    11,2 %
  • Ist mir völlig egal, ich warte ohnehin auf unabhängige Tests und Reviews
    52,0 %
98 Teilnehmer + 1 Enthaltungen • Ende: 26.10.2022 14:59 Uhr
Weitere Fragen und Zwischenstand siehe Link. Sieht nicht so rosig aus für Lederjacke.
Ich bin wirklich sehr verwirrt inzwischen wegen dieser Netzteilkabel Geschichte 😃
Kein Hersteller antwortet offiziell, ob man die momentanen Netzteile für die 4090 Reihe nutzen kann.
Ich schreibe später mal in das Supportforum von Corsair 😃
Der gute Mann ist aber bis zum 4.10 im Urlaub.
Wenn die tests kommen wird sich einiges klären.
  • Danke
Reaktionen: SH
Sicher ist Sicher. Immerhin dann auch mit 2x 12+4pin :asthanos:
Stellt euch vor, ich komme irgendwann an eine Hall of Fame dran. Und dann habe ich nur einen Anschluss und brauche 2 😃
Wenn ich eins gelernt habt über den 22 Jahren als PC Hardware Fan, dann…
- versuche das größte Gehäuse zu bekommen, um dir nie wieder Gedanken machen zu müssen über Platz
- versuche eines der besten Netzteile zu bekommen, damit man so gut wie nie wieder Upgraden muss und sich nie Gedanken um die Wattzahlen machen muss
Mein 1200AX hat jetzt knapp 5 1/2 Jahre immer zuverlässig Strom geliefert 😃
Na ja das wird nur eine Werkstestkarte sein, ich bezweifle, dass die eine derart starke Karte jemals in den Umlauf bringen, die läge dann garantiert bei 5000+
Abgesehen davon wird man den Speicher nicht mehr gekühlt bekommen bzw. benötigt kein normaler Mensch im Endkundenbereich 48 GB Speicher in der GPU
Ähnliche Themen
Antworten
6K
Aufrufe
380K
