[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Real man have 48GB Vram. :bigok:
GDDR6(X) ist doch für Anfänger. Ich würde dann schon eher die 80GB HBM2E nehmen ;)
Die 48GB Karte hätte dann ja vermutlich wieder ne doppelseitige RAM Bestückung mit den bekannten Problemen. Bekommt die dann nen doppelseitigen 7 Slot Luftkühler?
Oder wird direkt mit AiO mit dazugehörigen MoRa ausgeliefert :haha:
Als Workstationkarte wäre HBME2 in der Tat besser^^
Bin erstaunt wieviele bei dieser Generation abwarten mit dem kaufen, aber ebenso wieviele 3090 Ti Nutzer auf ne 4090 gehen.
Nach dem AMD Release wissen wir mehr.
Denke mal, dass dann die Midclass und ein oder 2 TI kommen, ggf. auch wieder Super.
Dann gibt es aber noch die pros die selber testen wollen ;)
Ob man für das AX1600i ein passendes Kabel bekommt?
Was ist am AX1600i speziell anders? Oo
Also gestern ging ich bei einem Juwelier vorbei und schaute mir die Shice an die er da verkauft und das zu welchen Preisen. Dagegen ist unser Hobby ein Geschenk, nochdazu hatte der Goldklunker kein RGB, kein Lüftergeräusch, kaum Interaktion, keine fps Anzeige, keine Einstellungen, keine Wassertemperaturen. Nur raytracing und HDR.
Geniessen wir lieber unser Hobby. ;)
Die Titan V hatte ja damals in der CEO Edition 32GB HBM2 :love:. Die Lovelace Quadros nehmen ja einfach nur GDDR6 mit ECC.
Schätze auch NV wird erst den Release der AMD Karten abwarten. Und je nachdem wie viel VRAM die aufweisen wird NV halt die 4090 Ti mit 24 oder 48 GB GDDR6X bringen.
Und auch beim GPU Takt scheint es ja noch Spielraum nach oben zu geben.
Daher sollten wir auf starke AMD Karten hoffen, da uns NV sonst ewig auf den AD102 Vollausbau warten lässt.
Ich denke auch das man noch etwas wartet. Zumal ja auch noch massenweise 3000er GPUs unter 1000€ im Lager bzw. Abverkauf sind.
Wo vorbestellt? In Deutschland finde ich leider noch nichts
Das sind andere.
Die, die du verlinkt hast sind
SKU CP-8920274​
Die, die ich brauche sind die
SKU CP-8920284​
Denke bitte an das von deinem Post :) glaube, dass du das falsche Kabel geholt hast
Nicht zu vergessen… die Wohnung wird auch warm im Winter… ich zocke um zu heizen! ;)
Nicht bestellbar im DE Shop :(
@SH Ich brauche eh ein Seasonic Kabel, bis es das oder ein neues NT gibt wird wohl der Adapter reichen müssen.
Gibt es nicht was bei cablemod?
Da würde ich auch wieder bestellen, bin echt zufrieden. Nur finde ich 20cm als maximale mögliche Länge einwenig knapp.
Ist aber vermutlich ein Problem mit deinem Endgerät, bei mir kann ich alles zwischen 10 und 100cm auswählen:
Aber blanke Plaste ohne Sleeve ist nicht toll.
Sleeves kann man nicht wählen?
PSU eintragen geht, jedoch finde ich das irgendwie komisch, also die Seite an sich ist schwierig übersichtlich.
Gibt die doch auch mit Plastik Sleeving?
Bin persönlich aber eher Fan von den Ultra Soft Silicone Wires (Die sollten eigentlich mal vor anderthalb Jahren in meinem Gaming Rig verbaut werden, bin aber immer noch nicht dazu gekommen)
Mich reizt die 4090 so, für mich wäre interessant ob ich diese bei ca 350 - 450W betreiben könnte und wieviel Mehrleistung gegenüber der jetzigen RTX 3080Ti Fe zu erwarten sind. Über Sinn und Unsinn bitte nicht diskutieren.
Der Standard ist 450W. Die meisten Karten werden ein 133% Powerlimit haben. Also 650W. Musst du ja nicht einstellen :)
Ich werde bestimmt mit Undervolting die 350W mit fast gleicher Leistung im 24/7 Betireb gamen.
Mehrleistung solltest du dir denken können.
Aber die Effizienz warten eben viele ab, da die Karte gegenüber der 3090 nicht besser ist, wenn die Leistung mit dem vielfachen mehr an Verbrauch einhergeht.
Interessant für viele wird wohl wieder die Maximalleistung im OC und die UV OC werte sein.
@spyfly kleben die Silikonteile? Sehen staubanfällig aus.
Sind die Ultra Soft Silicone Wires flexibler als die einzel gesleeften Normalen und genauso belastbar von der Stromstärke?
Die gesleevten sind einfach ultra soft silicone mit sleeve drumherum, dementsprechend sind die ultra soft silicone genauso belastbar von der Stromstärke und aufgrund des fehlenden Sleeves sind sie auch flexibler.
Bin nur noch nicht dazu gekommen die in meine Gaming Kiste einzubauen, vorher kommt wahrscheinlich noch die 4090 🙈😅
Nein sie kleben nicht. Der Staub kommt daher das das Kabel seit anderthalb Jahren in ner offenen Kiste lag :rolleyes:
Für mich als Netzteil-Nerd wegen dem Kabel von moddiy.
Warum brauche ich da nur 1 Kabel mit 2x8 Pin, wenn die Adapter von den RTX 4090 customs 4x 8 Pin Stromstecker brauchen? Danke Euch! :)
Weil die 8 Pin PCIe Kabel pro Stecker laut Spec maximal 150W mitmachen.
Die Ports vom Netzteil können mit Dual 8 Pin aber 300W pro Buchse.
Danke dir. Und diese spezielle Kabel ist in der Lage dem Netzteil zu "sagen", dass er nun 600W durch die Dual 8 Pin laufen lassen kann?
Das heißt:
Altes Kabel = 150W pro 8 Pin = 4x 150 um 600W zu bekommen
Neues Kabel = 300W pro 8 Pin = 2x 300 um 600W zu bekommen?
Dafür hat das Kabel zwei Sensing Pins, über die wird die entsprechende Leistungsstufe von 150/300/450 oder 600W konfiguriert.
  • Danke
Reaktionen: SH
Ähnliche Themen
Antworten
6K
Aufrufe
380K
