[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dafür hat das Kabel zwei Sensing Pins, über die wird die entsprechende Leistungsstufe von 150/300/450 oder 600W konfiguriert.
Ahhhhhhhhhh. Jetzt hat es Klick gemacht. Danke dir für die schnelle Antworten. Very appreciated :)
Ich bin wirklich sehr verwirrt inzwischen wegen dieser Netzteilkabel Geschichte 😃
Kein Hersteller antwortet offiziell, ob man die momentanen Netzteile für die 4090 Reihe nutzen kann.
Ich schreibe später mal in das Supportforum von Corsair 😃
Ich bin mir zu 100% sicher das man die 4090 mit sogut wie jedem Netzteil nutzen kann. Auch lt. Asus sind Adapter Kabel beigelegt! Das einzige was es zu beachten gilt, dass die Watt des jeweiligen Netzteils ausreicht. Denke mit OC ist man ab 1000 Watt safe. Für Standard reichen sicher 850 Watt+ vielleicht auch 750 Watt. Mit Undervolting sogar weniger.
Für Standard reichen sicher 850 Watt+ vielleicht auch 450 Watt. Mit Undervolting sogar weniger.
Vermutlich wurde schon nen ordentliches 750W reichen.
Ich werde es zumindest mal mit dem SF750 Platinum probieren, vorher brauche ich aber noch nen Wasserblock der in mein Case passt :haha:
Wo man ggf. schon ein bisschen aufpassen muss, nicht jeder beliebige Anschluss am NT kann immer 300W rausballern. BeQuiet z.B. ist da so ein ätzender Kandidat, da muss man die Last auf die richtigen 12V Schienen verteilen. Straight Power 850W etwa hat vier Schienen, zwei von denen können aber nur je 21A liefern.
Es gibt das Kabel ja aber auch als 3x 8-Pin Variante:
Für solche NTs gibt's das Kabel auch als Triple Version: https://www.moddiy.com/products/ATX...iple-8-Pin-to-12VHPWR-16-Pin-Power-Cable.html
Edit: da war wohl jemand schneller ;)
Ja hatte das falsche verlinkt, schon korrigiert :d
Ich frage mich ja wo sich die unterschiedlichen Customs wirklich unterscheiden werden. Wenn alle Karten 660 Watt können und alle nur einen 16 Pin haben kann ich ja in der Theorie jedes X-beliebige Bios auf die Karte flashen, ist ja dann eig nur ne rein optische Sache und wenn man auf Wasser geht dürfte es ja vollkommen schnuppe sein
Kühler und Platine, werden ja nicht alle die Referenz verbaut haben.
Ja wird aber kaum eine Rolle spielen wenn alle 16 Pin haben ist ja dann nicht mehr so wie bei den 8 Pin wos Modelle mit 2x8 und 3x8 gibt und man hört ja dass so gut wie alle Ref Design sein sollen
Da bin ich auch mal gespannt…
Meine 3090 FTW Ultra lief mit einem 2x 8Pin-BIOS am Besten :fresse: (mehr als 520W)
Und krank, dass das 3090 FTW Ultra BIOS (500W) auf markenfremden Karten am Besten lief :d
Auf meiner zweiten FTW3 läuft 500W Bios top, power draw wird perfekt verteilt auf die drei Anschlüsse und auch über PCIe wird nicht zu viel Strom gezogen, OC ist auch sehr gut.
2200€ habe ich dafür abgedrückt. :fresse:
Ich wäre nicht zu optimistisch, dass ein Cross-Flash ohne weiteres überhaupt noch möglich ist bei den 40er Karten.
Wenn ich überlege, mein Corsair AX1200i ist jetzt fast 10 Jahre alt und hat bestimmt 20 verschiedene Grakas und mehrere Wakü-Umbauten überlebt. Gekauft hab ich es damals für ein SLI aus 2xGTX580 und einem 3930k, und ich hab aus jeder der folgenden Generationen mindestens eine, und von vielen mehrere Grakas gehabt.
Also defintiv mehr als 30 Steckvorgänge.
Weiß gar nicht warum man da jetzt so ein Alarm drum macht. Sind doch alle modular die Netzteile. Gibts halt zu jeder neuen Graka auch ein neues Kabel. Und dann wird mein Netzteil noch weitere 10 Jahre halten *hüstel*. Oder so. Gar kein Problem.
Ich hab für die 24GB-Pascal (Titan RTX) damals 2.6k abgerückt (dafür hatte ich 24GB 2 Jahre vor allen anderen^^). Wird mir diesmal nicht passieren. Oberhalb von 2k .. wahrscheinlich kein Kauf. Auch meine 3090 hat deutlich weniger als 2K zum RELEASE gekostet.
  • Danke
Reaktionen: SH
Wird bestimmt dann wieder paar verrückte geben, die es testen werden 😃 inklusive mir 😂
Bonus aus dem OC UK Forum. Die Spezifikationen des Molex https://www.molex.com/webdocs/datasheets/pdf/en-us/0455860005_PCB_HEADERS.pdf
Der Kasten ist halt Qualität. Hatte auch eines und ich Depp hab's dann verkauft, als ich SLI abgeschafft hab :fresse::wall: Ärgert nun mich ganz schön^^
Ich hab für die 24GB-Pascal (Titan RTX) damals 2.6k abgerückt. Wird mir diesmal nicht passieren. Oberhalb von 2k .. wahrscheinlich kein Kauf. Auch meine 3090 hat deutlich weniger als 2K zum RELEASE gekostet.
Naja gut mit 1200W brauchste dir natürlich keine Sorgen machen. Ich habe damals, vor 5 Jahren oder so?, bewusst 750W gewählt, da mir SLi nicht mehr ins Haus kam und zu der Zeit der Verbrauch der Grakas nicht so hoch war. Zur 3090 Strix hatte ich schon etwas bedenken, naja und für die 4090 glaube ich könnte es noch knapper werden aber am Ende lande ich evtl. bei RDNA3 who knows :banana: Bloß da bräuchte ich nen neuen Monitor...
Macht es hier nicht auch wie bei den AMD Karten einen Unterschied wie viele bzw. welche Ports die hinten haben?
Die 3090 Gigabyte hatte ja auch 3x Dp, 2x HDMI wo andere nur 4 hatten
@HisN
30 Steckvorgänge sind garantiert. Weit darüber hinaus + hohe Last, da sollte man vorsichtig sein. Hatte schon den ein oder anderen Stecker, der gut warm wurde
Da ist eine kleine Wärmebild-Cam schon hilfreich
BTW:
Hier geht es zu, wie einem Tauben-Schlag… :d
Müsst ihr morgen nicht arbeiten, ihr Psychos :d
Interessant wäre, ob man bei Bedarf (wenn es mal eine Karte gibt) auch 2 Corsair Kabel 600W 12VHPWR ans Corsair Netzteil anschliessen könnte - z.B. beim AX1600i.
Wüsste nicht was dagegen spricht. Das sind ja "dumme" Kabel.
"600W load requires a 1200W rated CORSAIR PSU or higher. 450W load requires 1000W or higher. 300W load requires 750W or higher."
Sollte bekannt sein.
Aber sind halt nur sichere Setups.
Ein 750 bis 850W Marken NT mit 10 bis 20% Reserve in der Lastspitze taugt da meist genauso viel wie ein No Name mit 1000W.
Mal eben einen Anstieg von CPU und GPU mit plötzlich +600 bis 800 Watt kann eben nicht jedes NT abfangen.
Normalerweise ja, aber das 2x 8Pin-BIOS lief ohne Probleme auf der 3x 8Pin-GPU. Und die Last auf allen 3 Strängen war auch ok laut „Zange“. Dennoch dachte man anfangs, dass 500W über 2 Stränge laufen, weil in GPU-Z nur 2x 8Pin angezeigt wird :d
Mir geht es nicht um die Energieversorgung, eher ums Biosflashen und der Kompatibilität mit den Displayports/ HDMI.
  • Danke
Reaktionen: SH
Was man von manchen Smartphone-Cables nicht sagen kann :fire:
Habe ein teures USB C 3.2 Kabel bei Anker gekauft (war ein geschenkt), einen Tag später RMA, es hatte nur 2 Leitungen, wovon eine durchgeschmort war beim ersten Einstecken.
Sollte aber Lade und Datenkabel sein.
Ich traue niemandem meher^^
Alles qool.
Bald werden Brandmelder mit RGB und USB-intern-Anschluss für das Case verkauft und man can ruhig RTX 4090@600W ballern. :o
Guten Nacht Lektüre.
Genialer Artikel, aber das zeigt auch dass man sich von AMD keine Wunder beim Pricing erwarten sollte
Ähnliche Themen
Antworten
6K
Aufrufe
380K
