[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie macht ihr das immer ? ;D Ich sehe nur die Gigabyte Karte bei MF
einfach hier in den Thread und dann mal alle 2-3 Minuten Seite aktualisieren und den Links folgen :)
Ich verstehe Nvidia nicht. Fast alle wollen eine FE. Selbst die Tech Influencer sagen mittlerweile, dass sich kein AUfpreis zu einer FE lohnt. Zudem sehen alle AIB's, ausser der Tuf, aus, als wären Sie für 12 Jährige designed. Und Jensen verkauft ganze 3 Stück in Deutschland?
Warum machen die nicht einfach bei NBB eine Warteliste. Man bezahlt und wartet bis die Karte kommt. Meinetwegen auch 4 Wochen. Besser als jeden Tag F5 drücken aber den entscheidenden Moment verpasst zu haben. Da macht Jensen doch viel mehr Marge und kann doch viel besser abschätzen wieviele produziert werden sollen. Zudem hat er die Kohle dann noch als Vorschuss?
Verstehe nur ich das nicht?
Ich verstehe es auch nicht wirklich, als sollten die FE's knapp sein weil nVidia möchte, daß sie als Sammlerstücke durchgehen oder irgendwelchen Fame in den Communities generieren. Anders macht das für mich auch keinen Sinn.
Wenn hier im Forum gerade mal 4 Leute eine ergattern konnten und nicht mal 2 Minuten nach 15 Uhr bereits alles weg war, dann muss die Anzahl sehr klein gewesen sein, niedriger zweistelliger Bereich oder so. Und das ist nicht mehr vernünftig zu erklären, so groß sind die Engpässe nicht mehr, da steckt irgendeine Absicht dahiner, die wir noch nicht verstanden haben. Due Customs waren da ja wirklich reichlich vorhanden im Vergleich, es kann also nicht wirklich an der Produktion liegen.
Meine Suprim X von office-shop wurde storniert, jetzt hab ich wahl zwischen Gigabyte Gaming OC und TUF OC.. :unsure:
Vielleicht verdienen die mehr an dem Chips als an eigene Karten.
Habe gerade mal mein Netzteil gecheckt... Mein RM580x hat nur 3xPCIE-Kabel, der NVIDIA-Adapter hat aber vier Anschlüsse. Kann ich eines der Kabel die vom Netzteil kommen doppelt belegen oder sollte man das besser lassen?
Musst du rausfinden ob 300W pro Port dein NT abgibt
Weiß jemand, ob das bei UPS mit der Sendungsverfolgung immer so lange dauert? Alternate hat mir die Nummer heute früh gegen 9:30 Uhr geschickt, Tracking funktioniert aber immer noch nicht...
Bei der 4090 FE musst du nicht alle 4 anschließen. Da reichen auch 3 der 4 Stecker, allerdings darfst du dann das PL nicht über 100% anheben, das ist dann gesperrt.
Ich weiß aber nicht, wie es mit den Adaptern der AIB Karten aussieht.
Ja meist ab 18 Uhr wenn die Pakete abgeholt wurden sind
Nicht vergessen, dass dutzende hier Stornos bekommen haben^^
Ist ja nicht so, als ob nur vier bestellen konnten. Irgendwie ist was bei der FE Sache faul.
Hab gestern um 18 Uhr eine Mail bekommen, dass Alternate meine Sendung an DHL übergeben hat. Bis jetzt steht im Tracking „Status offen“. Ist das bei euch auch so?
Meine Gaming Trio ist angekommen:
Sie passt so gerade noch in das Lian Li 011 dynamic. Karte leise, hat aber Spulenfiepen. Mal sehen ob sich das noch legt. Power Target auf 80 bringt so ziemlich die selbe Leistung in Warzone wie 100. 750w straight Power 11 platinum scheint bis jetzt auszureichen.
Wenn ich mich nicht verzählt habe, sind das elf Reihen längs, mit vier Reihen tief und 6 Reihen hoch, macht also
11x4x6 = 264 Karten
Möglicherweise geht die Reihe längs natürlich noch etwas weiter.
Ähnliche Themen
