[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei der Founders steht 650Watt 😁
Könnte Copy Paste sein da bei allen Innos nur 3x8Pin Adapater dabei zu seinen scheinen
Die Frostbite wird safe das große Powertarget haben.
Die Frostbite wird safe das große Powertarget haben.Anhang anzeigen 796328
Sicher hier steht 450W/450W
Wenn eine Karte über 600W hat dann die Strixx!
Ein PT von 600 W bekommt kaum eine Karte so meine Meinung.
Die Meisten werden bei 516 W sein von den Low Buget Custom.
Eine Master von Gigabyte vielleicht oder eine Extreme von Zotac z.b .vielleicht 550/580W
Das Sahne Häubchen wird die Strixx!
Wenn überhaupt dann das Highend Model von HoF noch.
und falls nicht bleibt noch ein anderes Bios zum flashen oder?
So wird es aussehen .
Ich meine es wäre toll aber wieso sollten die uns Plötzlich diesen Gefallen tun nach dem man uns das leben die Ganze Zeit schwer gemacht hat beim OC ?
Warum Plötzlich 150-200 W für OC frei geben Wo man dann vielleicht mit 3GHz 4090TI Level erreicht so jetzt mal als Beispiel!
Solche Karten wie die Strixx hätten dann auch keine Daseinsberechtigung mehr!
Ich hab mich entschlossen, bei mir wird's die iChill Frostbite :drool:
Muss mir dann nur noch ne Gehäusedeckelerhöhung konstruieren lassen und 3D Drucken :fresse2:
Und ich mach die Woche nen Umzug in n größeres Gehäuse mit mehr Radi-Fläche! :banana:
Ist halt ser einfachste Weg zur besten Kühlung ohne Umbau und Garantie sorgen!
Ich habe eine Antwort vom Corsair support bekommen wegen dem Netzteiladapter.
Sind einfach noch nicht auf Lager gewesen und kommen bald 👍
Stand jetzt wird es bei mir auch die Frostbite oder Strix 💪
Geizhals scheint die TDP Werte nicht korrekt zu übernehmen, hier bei der Strix steht nur 450 Watt:
Ich brauch da ja auch noch was in die Richtung. Evt. tut es anfangs auch das Corsair oder ich order mir das von ModDIY. Oder gleich das SFX-L Netzteil mit ATX 3.0 Spec von Asus?
Aber erstmal soll die Graka da sein :fresse2:
Wie gesagt darauf kann man zur Zeit alles nichts geben.
Das werden wir erst zu release sehen wen die Karten getestet werden welches Powertarget die dann haben werden!.
Jahre Lang hält NV schon die Hand drüber über OC warum sollten die Plötzlich 150 bis 200W für OC erlauben ?
Damit man mit 3GHZ 4090TI Level fahren kann ?
Wie geil wäre eine Stixx Fullcover in Serie von Asus?
Normalerweise dürften die auch nicht mehr kosten weil die Luftkühler so Riesen Trümmer sind!
  • Danke
Reaktionen: A6
Das ist richtig, Default von Nvidia sind ja 450W, der Asus Wert fehlt dort noch
Vielleicht könnte dir das kurze ALC Terminal in der Höhe helfen. https://www.alphacool.com/shop/graf...-aurora-terminal-flat-straight-acetal?c=20538
Wenn Gigabyte bei den "Einsteiger" Gaming Karten mit dem Reference PCB den 4x8pin Adapter für 600W beilegt, wird das Inno3D Flagship sicher auch den großen OC Headroom bekommen.
3Ghz anyone? :fresse:
Mal sehen welche Leistung die 4090 mit UV im Alltag bringt,mit 350-430W sollte mein 750W BeQuiet Netzteil keine Probleme haben :d
Bleibt nur die Frage ob die Frostbite ins Gehäuse passt,CPU Kühler geht bis 170mm könnte knapp werden.
Die4*8 Pin müssen eventuell genommen werden weil die Karte z.b 540W haben könnte oder 530 .
Der Adapter sagt erstmal nix außer das man darüber bis zu bereit stellen könnte was das Bios sagt steht auf einem anderen Blatt!
Denke mittlerweile werde mich mich dahingehend entscheiden eine FE oder eine Strix zu ordern je nach dem was ich kriege .
Dann halt auf den Wasserkühler von WC zu warten die beides geplant haben.
Kommt halt die kalte Jahreszeit und dann sollte es noch on Air gehen wie bei der 3090 auch.
Hatte es da auch so gemacht und so testet man die Karte ordentlich bevor man die auf Wakü umbaut und die Garantie erlischt.
Wird halt die CPU Mora only gekühlt :d bis dann die guten Blöcke da sind.
Alles andere ist Quatsch und man braucht die Wakü auch eher für den Sommer und daher wirds schon gehen.
Kein bock auf einen Block der dann ggf. Spannungsrisse bekommt und das kam schon hier und da gerne sowohl bei ALC als auch bei EKWB vor und komplett Acetal
habe ich kein bock drauf.
Wenn es so, wie bei der 3090 läuft - gute Nacht
AC gleiches Spiel. Erst einen mit einer richtig geilen Studie heiß machen, und dann kam nichts
Die Beiden haben mich diesemal maßlos enttäuscht :cry:
Ich hab einen Alphacool auf meine 6900XT gebaut läuft seit knapp zwei Jahren inzwischen hat mein Bruder die .
Alpacool auf 3080TI FE verbaut läuft inzwischen bei jemanden mit dem ich noch Kontakt habe einwandfrei.
Da gibt es keine Spannungsrisse oder der gleichen!
Kann ich gut verstehen, ein Trauerspiel, ich habe es bei Kollegen mitbekommen. Bei AC war es glaube ich eine Konstruktion mit Heatpipes auf die Rückseite, bei WC blieb es bei der Ankündigung. Die aber geil war, keine Frage.
Eddy von Alphacool schrieb mir heute das der verchromte ALC Block intern auf 800W getestet wurde, es soll ja noch Karten oberhalb der 4090 geben. Wenn Inno3D in zwei Wochen die fertigen Teile liefern kann, brauche ich mir keine Gedanken um Strix oder Suprim Umbauten machen. Die 4090 macht meiner Meinung eh nur mit Wasserkühlung Sinn.
Das hast du glaube schonmal verlinkt und nein, damit wäre die Karte immer noch zu hoch. Die Karte darf effektiv nur so hoch wie der Ref-PCB sein (ca. 12cm) und nicht höher, ergo bräuchte ich entweder ne Karte mit Terminal am Heck oder ich bastel mir halt ne Gehäuseerhöhung. Bei der kommen die Lüfter einfach außen an den Radiator dran und dann passt es auch ohne Heckterminal, weil ich durch das nach Außen verschieben der Lüfter knapp 2.5cm Höhe im Gehäuseinneren gewinne.
Klar wäre auch schlimm , wenn jeder Block so wäre .
Viele Blöcke sind halt so von der Konstruktion , dass dies halt auch mal auftreten kann und das ist halt doof.
Watercool macht sich da wirklich Gedanken. (Zb. haben die so Hülsen eingebaut für das Terminal statt ein Gewinde im Plexi zu schneiden)
Ich achte halt auf sowas , weil Wasser im PC wäre halt absolut misst und lege da halt sehr viel Wert auf Qualität.
Der kram kostet halt auch ordentlich Geld, wenn ich mal denke was eine 1080 Ti damals nur gekostet hat.
Die Zeiten sind ja leider rum .
Hier ein beispiel mit der Frostbite von der 3080 TI https://www.hardwareluxx.de/community/threads/frostbite-rtx-3080-spannungsrisse-im-alphacool-aurora-acryl-gpx-n-kühler.1307973/
Gab auch von EKWB solche vorfälle zb. bei einer King Mod Graka von CK.
Der Kunde hat es da nicht einfach es getauscht zu bekommen.
Gab und gibt auch echt gute Blöcke von EKWB.
Also so ist es nicht und die ALC Blöcke haben schon ne gute Leistung gezeigt.
Man kann ja auch einen Acetal Block nehmen und da ist man auch auf der sicheren Seite.
Bevor wir alle eine Inno Frostbite kaufen. @INNO3DStephan wie ist denn die momentane Lage der Garantie? Ändert sich etwas bei der 4090 Reihe?
Nur über den Händler? Oder nur in manchen Fällen über den Händler? Wenn ja, welche?
Was ist alles abgedeckt? Darf ich OC betreiben? Darf ich undervolting betreiben? Darf man das BIOS flashen?
Danke 😃👍
@SH Ein gescheiter Händler ist doch völlig okay. Wenn mit der Grafikkarte was sein sollte wird sie halt bei MediaMarkt oder Amazon umgetauscht.
Alle Alternativen sind schlechter. Nach dem EVGA weg ist gibt dir niemand mehr Garantie nach dem Umbau auf eigene Faust.
Konnte man gestern Abend Pre-Ordern. 1599 Dollar
Bis Media Markt oder Amazon mal Karten hat, dauert es bestimmt wieder.
Und du bist dann bestimmt jemand, der am 12.10 bestellen kann und die Karte dann auch gerne erst am 13.10 bekommt.
Ich fahre halt gerne dann 500km durch Deutschland um sie direkt beim Händler abzuholen am 12.10 :)
Wahrscheinlich ja, aber dann hast das Problem mit der Garantie wieder, weshalb man die Frostbite ja eigentlich kauft, seit EVGA Game Over ist.
Ähnliche Themen
Antworten
6K
Aufrufe
380K
