[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Alles qool.
Bald werden Brandmelder mit RGB und USB-intern-Anschluss für das Case verkauft und man can ruhig RTX 4090@600W ballern. :o
Erstmal schön ne 4090 LuKü ins eigene mini ITX Gehäuse und ab an den Riser und NT^^
Habe ein teures USB C 3.2 Kabel bei Anker gekauft (war ein geschenkt), einen Tag später RMA, es hatte nur 2 Leitungen, wovon eine durchgeschmort war beim ersten Einstecken.
Sollte aber Lade und Datenkabel sein.
Ich traue niemandem meher^^
Ich denke @L0rd_Helmchen meinte wohl damit, dass die NT-Kabel "einfache" Leitungen sind (ohne verbaute, restriktive Schaltungen), wie so manches Smartphone-Kabel
Ja wird aber kaum eine Rolle spielen wenn alle 16 Pin haben ist ja dann nicht mehr so wie bei den 8 Pin wos Modelle mit 2x8 und 3x8 gibt und man hört ja dass so gut wie alle Ref Design sein sollen
Das sehen ich auch als großen Fortschritt zur Ampere Generation. 600-660 Watt sollten erstmal mit dem Reference PCB drin sein. Also keine Not zum BIOS flash und sonstigen Basteleien wie den nachgeschobenen, rückseitigen Wasserblöcken. 3 GHz, wir kommen? 🧐
  • Danke
Reaktionen: SH
Ich vermute mal, dass die neue AMD 7000 Serie PCIe 5.0 supporten wird, und daher die Verfügbarkeit ab mitte Dezember gegeben ist, welche in etwa zeitgleich mit dem Release der Karte sein sollte.
Antwort auf meine Frage zum neuen 12VHPWR Stecker für Seasonic ATX 2.x Netzteile im Bestand. Ist also in der Mache.
Bin gesapnnt ab wann es das Corsair Kabel SKU CP-8920284 geben wird. Zum Bestellen finde ich aktuell keinen einzigen Händler. Habe das HX1200 was dafür ready wäre.
Gibt es da schon Tests auf PCIe5.0-Plattformen?
Ich mein, bei PCIe4.0 gibt es ja schon keinen spürbaren Vorteil bei GPUs gegenüber 3.0 - warum dann schon 5.0? :rolleyes2:
Bin in der genau gleichen Position. Habe auch das HX1200. Wenn du was finden solltest, bitte mich taggen :)
Mich auch bitte :wink:
Wie merkt ihr denn, dass ihr getaggt wurdet? Muss man da immer auf die Glocke klicken und alles manuell absuchen? Das wäre mir viel zu umständlich.
Huhu :)
wann ist denn der "offizielle" Launch in Deutschland? Ist das der 12.10. ?
Ab wann ist die CPU AMD Ryzen dran? Diese Woche war das, oder?
Danke und LG
Das ist mir klar. :-)
Nur wie merke ich selbst, dass du mich markiert / erwähnt hast? Wenn man nach Erwähnungen suchen muss, sind die ja irgendwie sinnlos.
Hm, ne, da steht nur du hättest einen beitrag von mir zitiert.
Ich schaue aber nie die Glocke, finde das zu umständlich und durcheinander da. Habe einen Bookmark auf "deine abonnierten Themen" und sehe da schön übersichtlich alles. Tagging ist für mich dann leider sinnlos, merke ich nicht.
Einfach den Thread hier abonnieren. Irgendwann kommt schon der Post das man das olle Kabel kaufen kann. Ich brauche auch eins. "Vermutlich"
Da liegt ein 600W Adapter bei !
Diese Woche haben die Board-Partner erst damit begonnen, RTX 4090-Testmuster zu versenden
Falls die Lager wirklich so voll sind, stellt sich die Frage, wann die Preise unter die UVP fallen? 🤨
Dann sollten auch alle "Einsteiger 4090" :fresse: mit dem Reference PCB ein 600W Powerlimit haben.
Bei der Founders steht 650Watt 😁
Das ist bestimmt das Referenzdesign. 133% PowerLimit und Max 600W :)
Könnte Copy Paste sein da bei allen Innos nur 3x8Pin Adapater dabei zu seinen scheinen
Denke mittlerweile werde mich mich dahingehend entscheiden eine FE oder eine Strix zu ordern je nach dem was ich kriege .
Dann halt auf den Wasserkühler von WC zu warten die beides geplant haben.
Kommt halt die kalte Jahreszeit und dann sollte es noch on Air gehen wie bei der 3090 auch.
Hatte es da auch so gemacht und so testet man die Karte ordentlich bevor man die auf Wakü umbaut und die Garantie erlischt.
Wird halt die CPU Mora only gekühlt :d bis dann die guten Blöcke da sind.
Alles andere ist Quatsch und man braucht die Wakü auch eher für den Sommer und daher wirds schon gehen.
Kein bock auf einen Block der dann ggf. Spannungsrisse bekommt und das kam schon hier und da gerne sowohl bei ALC als auch bei EKWB vor und komplett Acetal
habe ich kein bock drauf.
Ähnliche Themen
Antworten
6K
Aufrufe
380K
