[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ok danke dann versuche ich mal mein Glück
Hab ein altes Datum angegeben und ne 3090TI Rechnung man bekommt trotzdem das neue/richtige Kabel für die 4090 sehr kulant.
Da find ich die 20 Euro plus Versand für ein noch immer teures Netzteil Dark Power 12 Pro 1500Watt mal echt „teuer“ und ziemlich unkulant.
Ja, mit 4x 2+6 Pin. Meine ist eben angekommen.
maximal Sinnlos das selbst ASUS dann 300€ mehr für die OC verlangt im eigenen Webshop. Dient vermutlich dann einfach nur um den Durchschnittspreis anzuheben :)
Bzgl. BeQuiet Kabel, eine Antwort vom Support.....
mifcom.de ist down
Ob viele so unbedingt ne 4090 wollen, dass sie direkt nen ordentlich teuren Fertig-PC anschaffen?
Und die Suprim kommt morgen... :-)
(die TUF bleibt zu - zuerst kommt die Suprim ins Case)
Die TUF ist in meinen Augen eine der schönsten Karten, schlicht und zweckmäßig. Bei der Suprim bin ich mir nicht sicher, ob sie mir bei der 4090 nicht ein wenig zu "schick" ist
Du hast es doch hoffentlich vorher abgemessen, oder? :)
Schiebst du die Pumpe höher?
Klar - nur die FE und die Frostbite hätte gepasst.
Heatkiller-Tube und Mora Halterung liegt schon hier und morgen wandern Pumpe und AGB dann an einen der Moras. :)
Was ist das für ein Gehäuse?
Das ist das Corsair 7000D - also auch kein kleines Gehäuse.
Passt aber halt nur nicht wegen meines aktuellen Aufbaus der Wasserkühlung.
Hat eigentlich jemand Probleme mit dem Taichi x670e und der Strix 4090? Bei JayzTwoCents hat er es nicht ans laufen bekommen …
och nach einigen usern hier ist es völlig egal ob 2 3 oder gar 1 kabel verwendet wird .... :d
Darum ging es vorhin ja nicht, und hier gehts um den Nvidia Adapter, 3x8 PIN = 450W freigegeben, 4x8 PIN = 600W Freigegeben.
Timespy Extreme auch mal laufen lassen:
20k GPU Punkte, passt. Mit der 3090Ti hatte ich 12k
Beste Grüße
Beste Grüße
Stock? Das macht die GameRock OC nicht @ Stock
Nee, OC. Aber bei max. 450W ist da dann schluss. Mir gehts aber bei der Karte nicht um OC, die muss Produktiv erst mal Geld einbringen :d
Beste Grüße
rofl... 4090 TUF angekommen, allerdings ist mir gestern Abend meine CPU Pumpe verreckt... Glück muss man haben. Natürlich gibt es hier in OWL nicht einen Shop wo man nen CPU Kühler noch vor Ort kaufen könnte.
Ich dachte, dass die Gamerock neben zu ist
Also, dass mna die Heatpipes nicht sieht (ein Gitter hätten sie verbauen können)
Die vielen Sticker deiner Fan´s könntest du noch verblenden :-)
Wie gesagt, nur Erbsenzählerei, meinerseits. Das Case sieht aber schön aufgeräumt aus (y)
kleinanzeigen schon gecheckt? vielleicht haste ja Glück
Habe meine auch gerade bekommen und ausgepackt. Zwar nicht so schön wie die FE aber immerhin die schönste Air AIB Karte.
Allerdings habe ich mich erschrocken was für ein Brummer das ist. Bin gespannt ob die in mein R Define 6 passt.
Dagegen sieht meine TUF 3090 wie eine 3050 aus.
Immerhin hat Tuf den Vorteil dass sie 2x HDMI haben.
So gleich gehts ab zum basteln :-)
Habe meine auch gerade bekommen und ausgepackt. Zwar nicht so schön wie die FE aber immerhin die schöne Air AIB Karte.
Mehr Berichte von euren TUFten Karten bitte! :fresse:
Antwort von Bequiet bzgl. Y Kabel:
Warum machen hier immer welche solche Panik??? Irgendjemand hat mir hier geschrieben ich darf auf gar keinen Fal die Y Kabel nehmen.
Die „Y-Kabel“ des Straight Power 11 sind grundsätzlich vollwertige Kabel. Jede Phase hat eine durchgehende Verbindung von Netzteilbuchse zu PCIe-Anschluss. Es reicht also zwei Doppelkabel zu verwenden.
Beachten Sie, dass Sie beim Anschluss ans Netzteil die Last auf beide Rails verteilen. Verwenden Sie dazu bitte PCIe1 und PCIe3. Lassen Sie den PCIe2** Anschluss einfach frei."
Sieht ja fast verloren drin aus, ich brauch ne größere 4090
Beste Grüße
Na hat sich jemand die Suprim X Liquid geholt bei CU?
Hatte sie im Warenkorb, aber nicht bestellt :d
Ähnliche Themen
