[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der Käsekönig bezahlt Ihren MAs hoffentlich ordentliche Betriebsrenten bei den Preisen. Einfach mal 400€ mehr für die TUF non OC wie im Asus Webshop oder bei CU und auch die werden das Ding sicher nicht ohne Gewinn verkaufen. :ROFLMAO:
Hast du eigentlich eine 4090FE bekommen? Weil wenn einer hier dann du.
Tut sie nicht und das schrieb ich bereits. Du nervst.
warum so aggressiv?
die zertifizierung spielt bei der leistung nunmal keine rolle, das wollte ich nur sagen.
schönes leben wünsche ich dir
edit:
@SH
muss der bilderquote sein?
So, billig Gamingrock nonOC eingebaut. Die nonOC hat "nur" 3PIN auf 12PIN, ist also 450W gelockt.
Hier mal ein kurzer Run:
Beste Grüße
Super, hab auch eins :)
Welche 4090 hast du? Das Meshify ist ja relativ knapp bemessen bei 340mm😅
Das ist die Gainward Phantom, hat eine Länge von 330mm.
Die Gigabyte Windforce oder die Palit Gamerock sollten da auch reinpassen, hatte vorher extra im Startpost geguckt :-)
Hat die TUF non OC eigentlich auch max PT 600W?
Ich glaub meine hat mehr als genug Platz
Beste Grüße
AMDBase halt. Welcher Thread ist das denn?
Frage zu einem "ATX 3.0 PCIe 5.0 600W Dual 8 Pin to 12VHPWR" Kabel für die heute eintrudelnde 4090: Ich habe ein Seasonic Prime TX 1000, und Seasonic gibt aktuell ja nur Kabel raus für Netzteile die nicht älter als 1 Jahr sind.
Als Alternativen habe ich im Netz Cablemod und MODDIY gefunden. Cablemod versendet erst ab 70€, bei MODDIY kann ich ein 60cm Kabel für 35€ bestellen. Hat jemand Erfahrung mit MODDIY? Ist Cablemod vorzuziehen?
Hatte mit Seasonic Kontakt, mein TX1000 ist auch älter als 1 Jahr, aber laut Aussage des Supports kein Problem, einfach ein Datum jünger als 1 Jahr eingeben für das Netzteil, wichtig ist die passende SN & Rechnung der 4090
Ähnliche Themen
