• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat einer mit der 4090 PUBG getestet ?
Sobald ich in das Game gehe und schon im Menü wo ein FPS Limit 60 ist bekomme ich
nach paar sekunden einen Bluescreen.
BF2042, Cyberpunk 2077 , Dying Light , Left 4 Dead 2 , Time Spy Extreme, Heaven 4.0 , Port Royal ,PCI E Benchmark , EZ Bench ,Hitman 3 läuft alles .
Nur PUBG will irgendwie garnicht . Wäre nett , wenn einer das Game mal testen könnte .
Hast du mal den 3dmark PCI E Test gemacht?
Bei 3.0 hast du ca. 13Gbits und bei 4.0 26 Gbits
Hier gibt es 3dmark recht günstig https://www.mmoga.de/Software/Steam/3DMark-Steam-Key.html
Kaufe da seit Jahren ein.
Habe leider selber nur ein 10900K und da geht max. 3.0
Das Programm habe ich und ich schaffe nur 12,6 Gbit hab ich schon getestet.
Heute nochmal den Treiber mit DDU deinstalliert,beim neustart ohne neuen Treiber hab ich im GPUz x16 4.0 auslesen können.
Dann Geforce Experiense mit neuen Treiber installiert und die 4090 hat wieder nur PCIe 3.0.
Langsam gehen mir ale Ideen aus denke wirklich schon da ses an der Karte liegt.
Musst wohl einen anderen rechner oder eine andere karte testen. Vllt. Kommt hier jemand aus deiner nähe.
Also mit 0,900V und 2600Mhz läuft die bis jetzt stabil. Werde noch etwas runter.
Aber erstmal spielen nicht nur BeMachen. Spulenfiepen ist so gut wie nicht mehr hörbar.
Lüfterkurve auf 50-55% bis 80 Grad eingestellt. Die Karte wird aber nie so heiß dafür schön leise.
Da bin ich jetzt aktuell auch 2595Mhz @ 0,9V
~280W 61°C 1050rpm CP2077
~310W 63°C 1100rpm Control
Hab jetzt mal rumgespielt mit Power Target limitieren vs Undervolt via Custom Curve. Fazit: es macht kaum ein unterschied. Wenn ich das Powertarget reduziere auf ca. den Wert an Watt wo ich auch mit der Custom Curve mit UV lande, komme ich auf fast identische Performance und Verbrauch. Das Verhalten hat sich im Vergleich zu Ampere deutlich verändert.
wie schaut das bei dir aus? egal welcher browser. bei mir geht nix
Ich wollte grade eine Runde zocken, da bekomme ich eine Nachricht von Experience ich wäre für den kauf einer 4090 FE ausgewählt.:unsure:
Dann bestätige ich das ganze und zack bin ich bei NBB und kann die Karte ohne Probleme bestellen, ich habe auch direkt die AB bekommen.:banana:
Fragt man sich echt warum sie die dann Mittwoch storniert haben.:wall:
Auf jeden Fall krass!
Coole Sache danke Nvidia das habt echt super gemacht da kann kein Bot was machen.:-) (y)
Ich finde man muss auch mal loben wenn was gut ist.:d
Wie kann man daran teilnehmen, oder läuft das automatisch?
noch nicht sicher.
es gab die möglichkeit sich für eine benachrichtigung der 4090 einzutragen auf der nvidia seite
die möglichkeit besteht nicht mehr.
ob das die voraussetzung dafür ist, ist noch nicht bekannt.
Kann ich bestätigen der Unterschied ist minimal, aber vorhanden. War bei mir 20Watt Unterschied zwischen 900mv mit festen Takt und einfach 70%PL (UV hat weniger verbraucht)
ja das hab ich auhc. wenn ich mich anmelde und dann ein ticket aufmachen will lande ich im nirvana
Ich bin gerade am schauen bei New World von 425-450 W bei Stock 2760 MHZ auf 360-390 W mit 2805 MHZ runter:fresse:
Die Lüfter sind die meiste Zeit aus erst bei 63 C laufen die kurz an für eine Minute.
Funktioniert bei mir einwandfrei,
Lobby ist bei mir auf 30fps limitiert.
Ja ich installiere mal das Spiel Neu vorerst.
Habe 60 FPS limit drinne und ein Corsair AX 1000 Titanium und das Corsair Kabel.
Hmm komisch.
würde erst mal die config datei des spiel löschen -> game setting defaults
Hmm komisch.
Ja, wäre dann echt komisch, wenn es am Netzteil liegen würde. Aber der Artikel ist mir eingefallen, als du das PUBG Menü erwähnt hast. ^^
Hmm komisch.
Hab auch ein corsair, bei mir ist am Netzteil ein Schalter der regelt ob an einem Kabel 300 Watt gezogen werden kann, schau nach ob du so einen Schalter hast und schalte evtl um. Vielleicht hilft das 🤷
Edit: gerade danach gegoogelt, der Schalter schaltet zwischen Single und Multi Rail
Wow! Das ist schon kurz. Meine gehen Stock bei 66°C an im Silent Bios aber dann schon höher vom drehen.
Hab jetzt ab 50°C-70°C nur 50-55°C Lüfter. Da sind sie schön leise und das reicht eigentlich auch. Sonst würde die immer an und aus gehen und das ist bei der Karte mit das lauteste. Da sie immer ein Brumm machen und dann anlaufen.
Meins ist Single Rail . Ist praktisch ein Ableger vom Seasonic Prime TX-1000.
Das Corsair soll sogar bis 1350 Watt aushalten können.
Im Menü waren halt 120 Watt GPU und 40 Watt CPU .
Finde ich halt bisschen komisch.
In CP2077 hatte ich 400 Watt GPU und 150 Watt CPU Package Power.
Habe jetzt mal Buchsen getauscht am NT und dann hielt es länger.
Ansonsten probiere ich mal den Nvidia Adapter.
So die FE ist verbaut. Erste "Schnelltests" durchgeführt
AC Valhalla und FarCry 6 soweit io. die Karte läuft bei 288W ca. Cyberpunk ohne DLLS und RayTracing auf Ultra schafte so 40-50 FPS
Was mich verwundert ist dass ich die Temperatur nicht wirklich weit unter 70°C bekomme in Cyberpunk. Geschlossenes, aber sehr gut durchlüftetes Gehäuse und selbst bei 100% Fanspeed waren es noch 65°C
Ansonsten waren die Temps super. in AC Valhalla oder FarCry 6 id.R. iwas um die 60-65°C
Was hat die Master CPso? @Thunderburne
Das kann nicjt stimmen. Du bei pl eine höhere spannung bei z.b. 2600mhz als bei uv. Desweiteren hast du durchs dauernde powerlimit microstutter.
Komisch einloggen kann ich mich da auch nicht. :unsure:
extra nvidia account.der gfe acc geht dort nicht
hab vorhin im chat ne nachricht hinterlassen man möge mir doch bitte eine einladung zuschicken da ich nicht weis ob ich mich für die benachrichtigung eingetragen habe. ^^
Ah ok!
Ach machen die bestimmt die wollen doch verkaufen.
Nein, eben nicht. Sobald ich im Power Limit bin reduziert er Takt und Voltage runter, fast auf das gleiche Niveau als wenn ich es manuell anpasse. Micrustutter hab ich ebenfalls nicht, CapFrameX hab ich extra für Frametimes genutzt.
Ich gratuliere jedem, der eine 4090FE bekommen hat...aber ich will auch eine. :(
Wieso ruft Nvidia mich nicht an...
Stimmt aber. Das liegt daran, dass der Video-Clock direkt an der Voltage hängt. Das lässt sich (noch) nicht manuell einstellen. Daher hast du trotz UV+höherem Takt vs. reduziertem PT+niedrigerem Takt auch identische Performance bzw. mit letzterem sogar bessere. Weil dadurch die Voltage und dementsprechend auch der Video-Clock höher ist als wenn du die Voltage manuell senkst.
Verbrauch und Effizienz steigen mit UV aber natürlich trotzdem noch beachtlich.
Ähnliche Themen
