• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So mit OC auf ~2900MHz (AB: +155 MHzCore, +1500 MHz Mem, PL 115%, 100%vCore) ging meine FE auf 1500 Umdrehungen und 72°C im geschlossenen Gehäuse mit reichlich Gehäuselüfter (Front). Spiel: Cyberpunk
Update: @Stock hat die 4090 FE bei mir in CP (~2700Mhz, 420W) 1450 U/min (48% laut AB) und eine Temp von 67-69°C
Klar frage mich überhaupt was die 300€ Differenz beim Asus Shop da sollen zwischen non OC und OC
aber das die Unterschiede so "enorm" sind? OC 2700 / non OC 2775 ?
@***** @MS1988
Macht euch kein Kopp, die paar Mhz machen doch nix. ✌️
Hey, ich würde auch nicht alles glauben, was hier an mhz zahlen, im Forum geschrieben wird. 😉
Was hast du denn für Temps @***** ?
wollte gerade mal den Cyberpunk Benchmark laufen lassen. Stürzt aber immer an derselben Stelle ab, auch mit Stock Settings. Bug?
Meins läuft völlig problemlos, Stock und OC. Hast Du vielleicht irgenwelche Mods installiert die in die Grafik oder Texturen eingreifen? Meins ist zwar auch voll mit Mods aber dennoch kein Problem, läuft alles rund.
Cyberpunk hat momentan ein Problem mit dem aktuellsten nVidia Treiber. Artefakte usw. können dabei entstehen. Vielleicht hängt dein Problem damit auch zusammen
Gibt schon einen manuellen Fix dafür, finales Update kommt aber wohl die näcshten Tage.
Je nach Temp hat sie auch kurz 2715 MHz... pendelt sich dann aber bei 2685 / 2700 ein.
Das weiß ich hier am besten :shot:
Deathloop hat bei der 3090 richtig reingehauen - volle Suppe. Ansonsten Division 2 noch ganz gut.
Wie hoch boostet deine Karte @Stock
Exakt genauso verhält sich meine auch .
Spielt es für GE („Invite-Programm“) eine Rolle, ob eine FE verbaut war oder kann man auch einen Invite mit einer Custom bekommen?
Wenn ich mich nicht irre, darf es KEINE 4090 sein. Die Invite´s sollen Usern zugute kommen, die noch keine 4090 haben. Ist doch so, oder?
Warum meinst? Was genau? Lässt es sich ggf mit Afterburner anpassen?
Ich denk ich kann mein Fazit auch bald zur FE machen
Lüfterkurve im Silent Modus ist doof gemacht nach 65 C springen Lüfter an aber gleich mit ca 1500 Umdrehungen was zu einem hörbaren aufdrehen der Lüfter führt.
Bei unter 60C schalten sie sich wieder aus das nervt!
Ca gefühlt ca 4-5 Minuten Lüfter aus dann für ca 1-2 min an wieder aus usw.
Oc Modus Lüfter drehen viel zu doll auf !
Afterburner hab ich es noch nicht hinbekommen eine Lüfterkurve zu bastel die auch greift.
Bleibt nur den Lüfter im Bereich von um die 50% fest ein zu stellen was auch völlig reicht und mega leise ist mit ca 900 RPM da der Kühler recht stark ist !
Kann mir gut vorstellen, dass 4090 User automatisch ausgeschlossen werden. Welche Bedingungen noch eine Rolle spielen wird nur nVidia wissen.
Bleibt nur den Lüfter im Bereich von um die 50% ein zu stellen was auch völlig reicht mit ca 900 RPM da der Kühler recht stark ist !
Schreib doch mal Gigabyte an ob es dafür zeitnah evtl. ein BIOS Update geben wird. Würde mich wohl auch stören wenn die mittedrin aufdreht und nicht langsam hochfährt. Manchmal habe ich das Gefühl, dass die ihre Karten nicht testen. Echt krass vor allem bei Grafikkarten in dem Preisgefüge...
Ah das hatte ich bei meiner 2080 Ti on Gigabyte auch. Man kann es in Griff bekommen aber ich weiß nimmer wie :/ Das ist aber ein bekanntes Problem. dafür müsste es noch in Foren Lösungen geben.
Trotzdem doof dass es bei GB immer noch existiert.
Afterburner mal den "Firmware" Modus aktivieren bei der Lüfterkurve?
Ähnliche Themen
