[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@***** ist mir auch aufgefallen. Ich verbrauche beim Zocken weniger Strom als mit der 3090.
Hänge bei Cold War Kampagne in 4K mit RT und DLSS Quality im 139 Fps Limit mit unter 300w.
Bei GTAV in 4 K und hohen Einstellungen langweilt sie sich. 😂
Echt ein geiler Scheiß die Karte. (Abgesehen vom Preis 🙈)
Und die paar mhz machen sicher keinen großen Unterschied.
Ich hab meine jetzt für den Alltag auf glaub 2775 @975mv gestellt.
Also bei meiner Gaming OC hab ich absolut keine Probleme mit der manuellen Lüfterkurve via Afterburner. Wird sofort übernommen, egal, was ich da einstelle.
So mal ein erstes Fazit zu meiner 4090 FE: Bis auf die Lüfter alles gut.
  • Verarbeitung: Soweit Top. Wirklich super stabil (Backstein) und macht einen wertigen Eindruck. Im Vergleich zur 3090 FE würde ich aber meinen, dass Nvidia etwas an den Kosten optimiert hat und die Lüfter iwie weniger massiv sind.
  • Kühler: In etwa gleich groß wie bei der 3090 FE. Kühlleistung solange man bis 500W geht gut. Ich habs nicht wirklich bis 600W getrieben aber alles was gegen 80°C geht finde ich nicht mehr gut. Bei 600W wird wird sie sehr wahrscheinlich 70% Lüftergeschwindigkeit benötigen. Bei mir im durchlüfteten und geschlossenen Gehäuse @Stock um die 68°C, @OC 72°C und mit gesenktem Powerlimit um die 65°C Speicher bleibt nun ebenfalls Kühl und i.d.R. zwischen 70°C und 80°C.
  • Lüfter: Bis 50% soweit i.O. aber ab 50% fängt mein hinterer Lüfter mit einem komischen höherfrequenten "Schleifgeräusch" an. Ab 70% hört man dieses Geräusch sehr deutlich heraus und es fängt an zu nerven. 100% sind auf jeden Fall nervig. Es schleift nix und scheint iwie am Lüfter/Lüfterdesign zu liegen. Der Lüfter beim Auslass hat ein "rhythmisches elektrisches Zirpen". Das ist ebenfalls kein Schleifen, scheint nicht mechanisch sondern iwie an der Lüfterelektronik (Spulen) zu liegen. Insgesamt sind die Lüfter (bei meiner FE zumindest) echt keine Glanzleistung und leider eine Enttäuschung bei so einer teuren Karte. Hier können denke ich die Customs gut punkten.
  • Lautstärke: Grob übern Daumen und nach Gehör ist bis 50% alles noch im grünen Bereich und verschwindet im Gesamtrauschen des Systems. ab den 50% kommt dann besagtes Schleifgeräusch dazu das bei ca. 70% nervt und bei 100% jeden Mitbewohner iwann stört. 100% erreicht man i.d.R. Bei mir waren es in den Games 45-50%. Selten mal etw. drüber
  • Spulenfiepen: Ja, ein "leichtes" Spulenfiepen ist vorhanden. Hatte da schon lautere Karten. Bei geschlossenen Gehäuse eher kaum wahrnehmbar wenn man Gehäuselüfter hat die es eh übertönen. Auch bei 150 FPS in AC Valhalla gleichbleibend.
  • Leistung: Top. Besonders die Möglichkeit das Powerlimit bis auf ~73% im Afterburner runterzudrücken + leichtem OC (+150 MHz Core, +800 MHz Mem) und in Cyberpunk nur um die 4-5 FPS verlieren während man 100+W spart ist echt nice. Auch einfach nur schon auf 90% PL + OC hat gereicht um 30-40W zu senken und trotzdem die gleiche Leistung zu erhalten oder gar ein bisschen mehr. Die Temperaturen sind dadurch auch nochmal etwas niedriger
  • OC: Ich denk ist soweit für ne FE i.O. 3030 MHz Core und 12000MHz VRAM war drin. Drüber wird instabil. Das ganze OC Thema macht aber iwie keinen Sinn mehr. Um die 3 GHz zu bekommen zieht die Karte dann 550W in CP und bringt dafür nur 2-3 FPS mehr. Bei 90% PL und etw. OC waren es 380W und eben 2-3 FPS weniger.
Würde mich interessieren ob andere ebenfalls diese Lüfterproblematik feststellen können? :)
Benchmark:
4090 FE Default:
4090 FE mit groben OC (ohne Kurvenanpassung usw.):
AfterBurner Settings die bei mir bisher stabil liefen (nicht auf Benchmarks sondern aufs Gaming ausgerichtet):
OC 1 (~2900 MHz in CP):
OC 2 (~2800 MHz in CP):
PowerSaving 1 (ca. gleiche Leistung wie @Stock ~2700 MHz in CP):
PowerSaving 1 (ca. 3-4 FPS weniger als @Stock ~2500 MHz in CP):
Also meine Suprim schafft letztendlich stabil 3030mhz und +1500 speicher mit full OC (bei anspruchsvollen spielen wie metro exodus und cyberpunk)
Ist denke ich schon n guter chip.
Buildzoid: "This is the worst 4090 PCB I've seen so far"​
Palit RTX 4090 GameRock OC​
Man sollte aber auch immer bedenken wer buildzoid ist und was er mit den Karten macht. Das die Karte von Palit mit dem PCB nicht für LN2 und oc über dem Powerlimit gedacht ist, sollte jedem klar sein und wird auch keiner dafür kaufen. Für den Standard User ist die Karte komplett ausreichend dimensioniert. Die hohen Amps erreicht man unter Luft nicht mal ansatzweise und da ist man auch sicher unterwegs. Sagt er ja auch so. Das Layout ist nicht für Furmark und aufgehobenen Powerlimit gedacht. Ich kann damit wunderbar leben.
Beste Grüße
Die Leute kaufen die Karte trotzdem weil der Großteil einfach nur zocken will oder mit arbeiten. Man sieht es doch hier. Der Großteil UVen sogar ihre Karte und setzen das PL runter. Noch mal. Die Spannungswandler werden erst kritisch wenn sie zu viel Amps pushen müssen. Dann werden sie extrem heiß und brennen dir weg. Das passiert dir aber nicht wenn du die Karte so nutzt wie sie gedacht ist und die Limits die hinterlegt sind einhälst. Erklärt er auch gut im Video. Die Karte kostet 50€ mehr als eine FE. Klar ist die FE besser aber wo bekommst du die? Die non OC kostet UVP, da bin ich komplett zufrieden mit und kein penetrantes gefiepe.
Beste Grüße
Ah das hatte ich bei meiner 2080 Ti on Gigabyte auch. Man kann es in Griff bekommen aber ich weiß nimmer wie :/ Das ist aber ein bekanntes Problem. dafür müsste es noch in Foren Lösungen geben.
Trotzdem doof dass es bei GB immer noch existiert.
Afterburner mal den "Firmware" Modus aktivieren bei der Lüfterkurve?
Genau das Problem hab ich momentan wieder mit meiner Gigabyte 2080ti! Macht mich wahnsinnig ich bekomm die Lüfter nicht eingestellt.
Dachte mal ich hätte die Lösung gefunden und es wäre der Zero Frozr Mode oder so ähnlich im MSI Programm gewesen. Aber irgendwann kam es wieder. Vielleicht liegt es nur wieder an dem Programm das is ne Überraschungsbox. Jede Woche n anderer Bug.
War Anfangs super angefressen dass die FE storniert wurde und das erst 2h später. Mittlerweile bin ich aber froh darüber weil mir dir TUF doch deutlich lieber ist. Die kam leider nicht mehr am Samstag an, sollte aber heute eintreffen. 😎
Hab gestern den Rechner mal gesäubert und wollte direkt noch n Kabel reinziehen für die 4090. Hab aber gesehen, dass die 2080ti bereits 3x8Pin (bzw. 2x 8pin 1x 6+2 pin) nutzt. Wenn ich das richtig sehe kann ich direkt die selben Anschlüsse genau so für die 4090 nehmen oder? Hab nur PCIe 2 auf 3 gewechselt.
Steelrising.
Und nein. Einfach nur UHD und alle Regler bis auf Resscale nach ganz rechts und RT an. Den Rest macht das Game.
Ist das der reservierte RAM oder der Tatsächlich benutze?
Das mit den Lüftern der Gigabyte Karte hat mich auch extrem genervt. Die Kurve und Einstellungen hier funktionieren bei mir. Hab die Lüfter-% mit im OSD.
@mda31 das mit der Lüfterlautstärke ist für mich auch ein wichtiges Thema. Die Gigabyte Karten gehen anscheinend gut weit runter bis zu 800 rpm oder noch weniger? Ich hab jetzt eine 4090 ASUS TUF non OC und die geht bei 30% im Afterburner nur auf ca. 1000 rpm runter. Ich weiß ja nicht. Ja ist nicht laut, aber ich hatte vorher ASUS TUF 3080, ebenso ca. 1000 rpm (bei aber 53%!) und aber halt deutlich leiser wegen eben kleinerer Lüfter nehm ich an. Ok jmd anderer meinte ja seine ASUS TUF 4090 ist bei den 1000 rpm quasi unhörbar.
Gibt es weitere Erfahrungen zur Lüfterlautstärke, was sind die leisesten 4090? Mir gehts dabei eben um den Teillastbereich, also nicht Volllast wie Gaming, aber wenn halt Lüfter angehen. Und ich finde da die 1000 rpm bei meiner Teillast schon hörbar. Und ich kann ja nichts machen oder? Unter 30% geht ja nicht. Die Karte ist ja krass kühl trotzdem. Vllt 50 Grad!
hmm, nicht nur Cyberpunk crashed, assetto corsa competitzione ebenfalls. Metro Benchmark lief ein paar runs durch. Treiber habe ich bereits mit DDU neu installiert. teste jetzt mal weitere Spiele. Alles @stock
an was kann das liegen?
Timespy extreme lief bisher ohne Probleme. Stromversorgung sollte passen
EDIT: F12020 und MSFS crashen auch
Windows 11, PSU Straigth Power 11 1000W
Guten Morgen,
ich habe grade die Versandbestätigung bekommen für die 4090 FE. :banana:
Sehr geehrte Kundin, sehr geehrter Kunde,
wir haben Ihren Auftrag vom 15.10.22 mit Auftragsnummer BXXXXX bearbeitet und die darin enthaltene Ware am 17.10.22 versandfertig gemacht. Wir übergeben Ihre Ware nun direkt an den Versanddienstleister.
Habe gerade eine TUF OC getestet... die sollte Retoure gehen, da ein Kollege ne TUF aus dem ASUS Shop ergattert hatte.
Die TUF OC macht 2745 / 2760 vs 2685 / 2700 non OC.
Ein bisschen mager für den bitteren Aufpreis...
Hmm, meine läuft Stock 2820. Habe sie aber auch für den Preis der non-OC bekommen, sonst hätte ich sie wohl nicht genommen. ^^
ich suche grad das Video. PCGH war es, meine ich. Du konntest einstellen im Afterburner realen verbrauch und reservierten.
ich finde das Video nicht mehr. Ging darum ob 10GB Video Ram genug für 4k sind.
Btw, hat noch jemand mit ner Suprim X den Effekt, dass beim Start von hwinfo die RGB Beleuchtung der Karte ausgeht und erst nach komplettem Runterfahren und Neustart wieder geht?
DU bist mein HELD, ich danke dir ^^
Habe gestern Stunden versucht und gesucht, "fast" alle meine Autostart Progranmme Deaktiviert, Deinstalliert um zu gucken, wer meine Suprim X IMMEr nach Windows Start ausschaltet. Auf HWInfo bin ich natürlich NICHT gekommen. Heute Morgen dein POost gelesen. HWInfo aus dem Autostart genommen und siehe da. Die Karte bleibt an :)
Löst natürlich nicht das PRoblerm, aber HWInfo ist jetzt kein Tool was ich immer brauche :)
Bei der GA G OC die hier arbeitet sind 49% mit 810 RPM das untere Ende. Drunter fangen der linke und mittlere Lüfter an die RPM nicht zu halten (der rechte hat einen eigenen Controller und die RPM sind hier niedriger; bei 49% ca. 695). 50% sind knapp unter 860 RPM (Links und Mitte). Wenn ich es hören will (offenes Gehäuse noch bis morgen) geht das. 55% sind hingegen schon gut hörbar. 60 nerven schon. Bisher haben 50 bis 55% immer gelangt. Aber noch hab ich auch keine lange Session gehabt.
Benutzen die AIBs eigentlich auch das gleiche TIM wie Nvidia bei ihrer FE? Also diese phase changing material pads?
Klar frage mich überhaupt was die 300€ Differenz beim Asus Shop da sollen zwischen non OC und OC
Die non oc wird in wesentlich kleineren Stückzahlen verkauft und sind nur dafür da dass sie sagen können wir haben ne karte zum UVP
Das Video zusammengefast
Palits 4090 ist scheiße :fresse:
Die Powerstages sind billiger Müll ähnliche findet man auf 150$ Mainboards.
Weniger Powerstages als die FE,
schlechtere Powerstages als die FE.
Er munkelt, dass Nvidia möglicherweise zu viel Geld für GPU und Speicher verlangt und Palit deswegen diese freche Budget-Karte raushaut.
Oder das Palit darauf spekuliert, dass die Leute die Karte trotzdem kaufen, weil die Leute froh sind, überhaupt eine zu bekommen.
Übrigens Palit/Gainward sind die gleiche Firma und die Karten sind baugleich.
Die Komponenten sind auch bei der 3090er auch verbaut und das klappt auch . Man muss halt die Karte innerhalb der Spezifikation betreiben und haben auch weniger mit Spulenfiepen zu kämpfen .
Viele Wakü Leute setzen gerne auf Ref. Design , weil die meistens leiser sind .
Endlich hat sich der Status geändert. Meine Karte ist endlich in Zustellung. Blöd das ich halt nicht daheim bin...
Ähnliche Themen
Antworten
6K
Aufrufe
309K
