• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
hmm, nicht nur Cyberpunk crashed, assetto corsa competitzione ebenfalls. Metro Benchmark lief ein paar runs durch. Treiber habe ich bereits mit DDU neu installiert. teste jetzt mal weitere Spiele. Alles @stock
an was kann das liegen?
Timespy extreme lief bisher ohne Probleme. Stromversorgung sollte passen
EDIT: F12020 und MSFS crashen auch
Windows 11, PSU Straigth Power 11 1000W
Metro und CP hatte ich auch getestet und die sind bei mir auch random gecrashed. Lag aber bei mir am noch nicht korrekt eingestellten OC.
Ich hatte mal Crash von nem defekten RAM. Dein RAM vom Mainboard hast aber nicht iwie angefasst/umgesteckt oder?
Am VRAM denke ich liegt e nicht aber ggf mal dieses neue ECC im Nvidia Treiber aktivieren?
Crashed Furmark auch?
Guten Morgen,
ich habe grade die Versandbestätigung bekommen für die 4090 FE. :banana:
Sehr geehrte Kundin, sehr geehrter Kunde,
wir haben Ihren Auftrag vom 15.10.22 mit Auftragsnummer BXXXXX bearbeitet und die darin enthaltene Ware am 17.10.22 versandfertig gemacht. Wir übergeben Ihre Ware nun direkt an den Versanddienstleister.
Bitte unbedingt wegen den Lüftern berichten.. Bin gespannt. Falls ich es hier verpasse ggf. ne PM:cry:?
Endlich hat sich der Status geändert. Meine Karte ist endlich in Zustellung. Blöd das ich halt nicht daheim bin...
Deswegen lasse ich auf die Arbeit liefern, von 9 bis 18 ist immer einer da :d
P.S. GE hat sich gemeldet...für einen Monat Adobe...
Was ein guter Start in den OC Tag :) Meine Strix ist einfach so gut!
Da kann ich nicht ganz mithalten, aber fast. Da kommt mir das powerlimit von 520w in die Quere 🤦🏻‍♂️
  • Danke
Reaktionen: SH
Klar werde ich auf jeden Fall machen.👍
Glaube das das bei BMW nicht so möglich ist. Und auch wenn. Dann hätte ich die Karte auf Arbeit. Das bringt mir ja auch nichts.
Am RAM habe ich nichts verändert. Furmark habe ich noch nicht gecheckt. Nur Metro läuft bisher ohne Probleme, zumindest aktuell 10 runs
Doch in der Mittagspause aufmachen und Bilder für uns schießen :d
Je nach Werk braucht er wahrscheinlich eine längere Mittagspause um zur Warenannahme zu kommen. Dann kannste auch gleich KNH durchziehen :bigok:
PS: Bei meiner ist beim RAM bei +950 Schluss. Ab 1000 hab ich schon Bildfehler auf dem Desktop gesehen.
DU bist mein HELD, ich danke dir ^^
Habe gestern Stunden versucht und gesucht, "fast" alle meine Autostart Progranmme Deaktiviert, Deinstalliert um zu gucken, wer meine Suprim X IMMEr nach Windows Start ausschaltet. Auf HWInfo bin ich natürlich NICHT gekommen. Heute Morgen dein POost gelesen. HWInfo aus dem Autostart genommen und siehe da. Die Karte bleibt an :)
Löst natürlich nicht das PRoblerm, aber HWInfo ist jetzt kein Tool was ich immer brauche :)
Also ein bisschen anderes Layout muss es ja auf jeden Fall haben, da die Palit schmaler als die Gainward ist und generell nicht baugleich. Bei den verwendeten Komponenten würde ich aber auch vermuten, dass das sehr ähnlich sein dürfte. Stört mich persönlich jetzt aber auch gar nicht. Karte wird nur innerhalb der Spezifikationen betrieben.
falsches Zitat :)
Hab ich was verpasst? Oder wieso gab es noch keinerlei VerfügbarkeitsMeldung zu der 4090 FE bei bekanntem NBB?
gibt generell keine karten zu kaufen^^
weil kein Drop bei NBB war, darum
Awa die Stunde Mittag reicht schon aus. Vielleicht sitzt er auch im FIZ? :)
Sitzen tu ich wirklich die meiste Zeit. Aber nicht im FIZ sondern im Werk auf dem Stapler. Eine Stunde Mittag? Habe ich was verpasst? Wir haben immer schon 30 min. Reicht oft gerade so zum Essen.
P.S. Karte ist zugestellt. Am Wunschort (vor der Haustür).
na da wundert man sich warum^^ 400 euro zu teuer
Oh okay :) Naja BMW Group scheint nicht gleich BMW Group. Naja immerhin wartet sie jetzt zu Hause auf dich.
Kann mir jemand vlt sagen wieso Tiny Tina´s Wonderland mit der 4090er nicht mehr funzt ?. Ohne OC @ Stock versucht kommt immer direkt Back to Desktop. letzte Woche noch mit meiner 30890TI gespielt
Ähnliche Themen
