[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Jay ist nirgends aufgesprungen, der hat im September schon ein Video zu dem Stecker gemacht und seine Bedenken geäußert.
Und da war er einer der wenigen die laut rumgetönt haben nicht um den Stecker selber an der Grafikkarte sondern die Kabel selber , da ging es ihm rein um die Kabelpeitsche mit drei bzw 4 Adapter und das da die Kabel reihenweise abfackeln (nicht der Stecker)
, Sein Horror war ja das der meiste Strom nur über ein Kabel der Peitsche das Netzteil kann sich das nicht aussuchen jedenfals sein Aufhänger war das wenn 4 Kabel von Netzteil an die Peitsche gehen das wenn es dumm läuft das Netzteil Strom nur über ein Kabel geht
Von daher bei dem ist jeden Tag was neues ,
Streamer brauchen Klicks, von daher darf man sich über Aufreger nicht aufregen. Buildzoid nehme ich da mal raus, seine Analyse ist recht treffend und persönlich bin ich auch nicht so glücklich mit dem Steckerchen. Vielleicht auch mit ein Grund warum manche Hersteller das Powerlimit ihrer Karten reduziert haben. Das könnte man im Nachgang mit BIOS Updates noch ändern wenn man Sicherheit gewonnen hat. Am Anfang hat es aber den Vorteil, dass es nicht die eigenen Karten sind von denen Brände berichtet werden.
910mV und 2610 MHz und sie summt noch etwas :d
krass ... okay, ich hab auch nen fram limiter im riva bei 117 gesetzt wegen g-sync, evtl hab ich deswegen kein heulen mehr? ich hab jetzt aber auch nur cyberpunk und uncharted gespielt.
Ja. Framelimiter hilft, und bei mir hat auch Freesync (mein Monitor hat kein g-sync) geholfen. Und wenn bei dir das Gehäuse noch anders steht oder irgendwie dichter ist, dann kanns sein dass das reicht. Bei mir ist es so, dass es unter Last ab knapp über 80 fps losgeht. Bei 100 hört man es bereits sehr deutlich. Dann bleibt es bis 120 ziemlich gleich und ab 130-140 fps gabs nochmal einen Ticken mehr und ab 160 fps gings richtig los und wurde ab 200 fps richtig eklig. Ab 240 fps rutschte es dann mal zeitweise in einen Bereich den meine alten Ohren vermutlich nicht mehr erfasst haben, kam dann aber bei über 350 fps mit Macht zurück.
Wenn man jetzt Games mit wenig Last hat wie z.B. BF1 oder BF5, dann war da auch bei 144 fps nix, kein Ton. Aber dafür brauch ich die Karte ja auch nicht. Von daher hab ich beschlossen, dass das für mich nicht geht.
Also was bei mir half:
1.) Lastreduzierung (Framelimiter o.ä.)
2.) laufen lassen. Je wärmer desto weniger und auch die ersten Stunden brachten massiv Besserung
3.) ich bilde mir ein, dass bei mir der Netzteiltausch was brachte, aber das kann sich theoretisch auch mit der Verbesserung über die Laufzeit überschnitten haben (Gegentausch aufs alte Netzteil habe ich nicht gemacht).
4.) freesync half ein klein wenig
5.) es wurde gefühlt auch schlechter wenn ich das nvidia eigene Overlay an hatte. War vielleicht das letzte Müh Last oder so. Also half es dieses Overlay abzuschalten.
Also tatsächlich nicht so stark biegen, wobei man solche Probleme früher schon hatte.
Noch eine Frage, da ich hier gegensätzliche Infos lese:
Hat die 4090 Phantom (nicht GS) nun einen 3 fach oder 4 Fach Adapter beiliegen?
4 laut homepage und bildern
Zeig doch mal Belege, einen Link, irgendetwas.
Ich muss hier gar nichts belegen, ob Du es glauben willst oder nicht, das musst Du selber wissen. Ich habe dies schon selbst erlebt und eine Grafikkarte deswegen an den Händler zurückgegeben, wo auch erst im nachhinein rauskam, das die Grafikkarte schon in Benutzung war. Gibt doch selbst hier im Forum User die mehrere RTX 4090 gekauft haben und nur eine behalten, nachdem getestet wurde welches Modell den eigenen Ansprüchen entspricht. Was glaubst Du macht der Händler mit den anderen Grafikkarten die zurückgehen, die gehen direkt wieder in den Verkauf, wenn keine gravierenden äußerlichen Mängel vorliegen. 😉
Ich auch, trotzdem würde ich daraus nie! eine Verallgemeinerung machen, geht quasi immer schief, es bleibt Hörensagen und Glauben und eben nicht Wissen.
Denkbar ist alles, aber solange man nichts beweisen kann ists schwierig.
wenn jemand alle schutzfolien abgerissen hat fällt das doch auf das die nicht mehr neu ist
ich schaue ja parallel mit in den Verfügbarkeitsthread. Die Karten sind schneller weg als sie in dem Thread erscheinen. Bitte wer botted das alles wech?
bestrifft das nur die customs oder ist die fe auch betroffen von dem brennenden 12hpwr anschlüssen?
Heute wieder FE drop? Was sagt euer Urin?
Moin,also ich versuche auch schon eine Woche eine Karte zubekommen (strix,tuf),ein Ding der unmöglichkeit.😬
Ähnliche Themen
