[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mich würde auch interessieren, ob mehr als 450 Watt möglich wären, wenn man einen 4fach-Stecker nutzen würde. Oder ein neues Kabel (ATX 3.0).
Sense Pin auf Masse brücken dann siehstes ;)
DU bist mein HELD, ich danke dir ^^
Habe gestern Stunden versucht und gesucht, "fast" alle meine Autostart Progranmme Deaktiviert, Deinstalliert um zu gucken, wer meine Suprim X IMMEr nach Windows Start ausschaltet. Auf HWInfo bin ich natürlich NICHT gekommen. Heute Morgen dein POost gelesen. HWInfo aus dem Autostart genommen und siehe da. Die Karte bleibt an :)
Löst natürlich nicht das PRoblerm, aber HWInfo ist jetzt kein Tool was ich immer brauche :)
Inwischen gibt es ne neue Beta, bei der das Problem wohl gelöst wurde. ;)
Hardware Unnboxed is wohl auch an was drann :
Anhang anzeigen 807288--Anhang anzeigen 807289
mal abgesehen davon könnte man ja selbst das beigelegte Adapter Kabel versteifen mit irgendwas um es vom biegen zu vehindern so als Quick and Dirty Version
Einfach die Kabel vorm Stecker in Gummi gießen :d USB Kabel haben sowas ja auch...
Was für ein Gehäuse ist das genau?
LianLi O11 Air Mini
Bin wirklich begeistert von dem Aufbau und Platz. Hatte vorher ein bequiet! Silent Base 820 – das war aber viel zu hoch und das Netzteil unten hat keine Luft bekommen bis es das Lauteste am ganzen PC war... Die breite, flache Kiste von LianLi mit Lochblechen auf fünf von sechs Seiten und Netzteil parallel zum Mobo ist super.
Und trotzdem 17 cm Towerkühler und 36 cm Graka möglich (y)
Irgendwie habe ich das Gefühl, dass die früheren Käufer – genau wie bei Ampère – gar nicht so falsch lagen. Hatte die 3090 drei, vier Wochen nach Release 10% über UVP bekommen als viele einen dafür ausgelacht haben soviel für ne GPU zu zahlen. Dann kam Mining und Corona...
Jetzt mit der Ankündigung, dass die Produktion zumindest gedrosselt wird, kommen von den ersten Chargen zwar noch viele Exemplare an – danach hängt es aber am AMD-Release. Bringen die etwas Vergleichbares, hält sich der eingeschränkte Nachschub die Waage mit nachlassender Nachfrage. Verk***t AMD aber Effizienz oder High End (oder beides :asthanos:) steigt die Nachfrage noch weiter und wir Early Adopter mit 10-15% über UVP haben das bis dahin durch Stromeinsparung amortisiert 💸 (okay habe nachgerechnet, dass ich die 4090 ungefähr 55 Jahre nutzen müsste um den Anschaffungspreis durch die Stromeinsparung gegenüber der 3090 wieder reinzubekommen – alternativ könnte ich sie auch zwei Jahre bei 25-fachen Strompreis betreiben damit es sich lohnt :ROFLMAO:)
@Scrush
Wegen letztens bzgl. 90 grad Adapter, Die werden laut Kommentare wohl das schon in Arbeit haben.
Wenn du runter scrollst schreibt er sogar das die TUF schon bestätigt ist, somit bestimmt auch die Strix.
Die haben damit noch nie aufgehört.
Wartet doch bis Mosch dem 3. November ab, dann hat AMD die 7000er Serie angeboten, und alles wird billiger.
Die wird nur vorgestellt am 3. Nov. Verfügbarkeit vielleicht erst Dezember.
E. Und wenn die Gerüchte stimmen, dass NV jetzt die Produktion von Hopper priorisiert, sehen sie in dem Leistungsbereich auf mittlere Zeitspanne wohl keine Gefahr.
Die Gainward 4090 ist gerade im Alternate WK von 1950€ auf 2070€ gestiegen :ROFLMAO:
Gut dass ich gestern noch die GS für 2000€ bestellt habe.
Wir kennen die Ursache doch noch gar nicht?
hindert doch keinen daran zu posten das Leute an einem Stecker arbeiten.
Ich dachte eher an was einfacheres ... mehr Isoband drumm eben auf die länge 3cm bis man es nich mehr so leicht verbiegen kann ... vielleicht auch mit etwas anderem unter dem Iso Band drunter was sich nich verbiegen kann .. wie gesagt Quick and Dirty ... sind einfach nur so gedanken die ich dazu hab.
Das meine ich gar nicht, aber es ist sinnfrei jetzt solche Stecker zu entwickeln, wenn man die Ursache noch gar nicht kennt.
sollte das aber die Ursache sein haben wir schneller die Lösung in unseren Händen .. man kann die Dinge so oder so sehen.
Uns schadet das ja nich das Hardware Unboxed daran arbeitet .. die können das doch machen und wenn es was anderes is woran das liegt is das doch für uns egal.
Aber sollte es daran liegen haben wir eben schneller die Lösung parat als wenn sie erst auf die 100 % bestätigung warten und dann erst anfangen zu entwickeln.
@Scrush
Ist aber nur der.adapter selbsrm Kabel brauch ich dann noch extra oder? Das ist nämlich schon bestellt dann den Adapter dazu und dann sollte es safe sein. Das es mit der tuf passt wäre natürlich deluxe
Ja das dürfte nur der Adapter sein, und da kann man dann wahrscheinlich bei Bestellung seine Karte auswählen. So stelle ich mir das zumindestens vor.
Wirkt auf mich so, als will man aus der Panikmache Geld scheffeln.
der Meinung kannst du sein ... jeder hat ja seine eigene und viel Geld kann man mit so nem Kabel nun auch nich machen mit einer 2000 Euro GPU dann schon eher.
Und wie gesagt es kann uns doch absolut egal sein das die nun schon daran arbeiten uns schadet das ja nicht also lass sie doch einfach machen .. und niemand is gezwungen das dann zu kaufen.
Dennoch sollte man über sowas berichten.
Eben, es sind bisher wohl nur 3 Fälle bekannt, in Worten Drei.
Nvidia wird die Sache sicher auf dem Schirm haben ggf. untersuchen, sicher wird man sich auch falls nötig offiziell dazu äußern.
Würdet ihr sagen das kann zum Problem werden? Konnte das einzelne Kabel ca. ~0.5mm reindrücken, fühlte sich jetzt aber nicht locker an. Lieber auf das Adapterkabel ausweichen und zurückschicken?
Hat jemand schon das Bios Update für die TUF gemacht? In den Release Notes steht ja mal gar nichts sinnvolles drin :(
Das sieht nicht gesund aus. Hast du das Kabel zuvor stark gebogen?
Bei meinem Stecker kann ich nichts vergleichbares entdecken.
Ähnliche Themen
