[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es kommt immer irgendwo Hardware rein. Wenn die irgendwas von Terminen reden ist das einfach ein placeholder. Die wissen bis zum Versand nie wie viele Karten sie bekommen. Zb. A*us versendet meistens per DHL Express direkt aus Asia und da weist du es auch nur weil es ne Sammelsendung ist.. 1 of 15 etc.... Aber selbst dann ist bei DHL Express viel Chaos... die Karten nehmen die wildesten Wege. Ein Teil kommt direkt nach 2 Tagen, andere brauchen fast 2 Wochen weil über 5 Länder. Daher auch diese krummen Zahlen.
Die Stückzahlen sind aber generell sehr niedrig was so bei den Shops ankommt darum sind die auch immer so schnell wieder ausverkauft weil eben nur sehr wenig reinkommt an Karten
Mal schauen wie lange das noch so bleibt und wann sich das dann normalisiert und man mal länger Zeit hat als nur 1 min um die zu kaufen ( damit meine ich generell die Karten bei allen shops )
Mindfactory die drei haben sich verkauft in den knapp 2 Wochen : ( 250 , 120 , 60 )
Passiert oft mit Custom Kabeln. Bei denen schiebt man es meist wieder rein. Musst es aber selbst wissen, ist deine Karte. Ohne Adapter greift möglicherweise die Garantie nicht, wer weiß wie sie sich herausreden wollen.
Der Vierzack ist aber anders am Stecker aufgebaut, da mehrere Kabel gleichzeitig pro Pin im Stecker sitzen. Da kann man es nicht einfach wieder reinschieben.
Konnte den Pin einfach so rausziehen und danach wieder reinschieben und hält soweit auch. Habe trotzdem BeQuiet Support angeschrieben und die tauschen es aus.
Gott sei Dank ist nichts passiert habe die ganze Zeit so Uncharted gespielt, wo die Karte ~350W zieht.
Gott sei Dank ist nichts passiert habe die ganze zeit so Uncharted gespielt, wo die Karte ~350W zieht.
Also wenn ich mir alleine die Passung der einzelnen "Buchsen" anschaue, wird mir schon wieder schlecht. Das wird noch ein nerviges Thema werden...
jep da sieht das Adapterkabel irgendwie sauberer verarbeitet aus.
NVIDIA NVFlash 5.792.0​
Du verstehst falsch, die Produktseite hat 2150€ angezeigt, aber die Karte war danach im Warenkorb für 1949€, also ein Fehler im System.
Ich würde fast sagen Aktualisierungszeit zwischen Frontend und Backend....
Btw wo bleibt die FE?
Ne, das ist nicht korrekt. Der Verfügbarkeitsbot war auf 1949, die Artikelseite war auf 1949 und der Checkout dann halt auch. Erst als ich meine Bestellung durch hatte und dann noch mal geachaut habe nach 2 Minuten war der Preis erhöht. Du warst anscheinend ein wenig später als ich da und hast die Preisanpassung "Live" gesehen
Die ersten scheinen schon ihren Block von EKWB für die FE bekommen zu haben obwohl Mitte November als Liefertermin prognostiziert wurde
auf kleinanzeigen gibt es einige asus tuf 4090 karten um die 2k
ist bei mir auch der Fall :wall:
@Vista
Aktiv seit dem 16.10.2022 und Abholung nur auf der Insel Spiekeroog.
Wieviel Hinweise auf Scam benötigst Du noch?
Ich würde den Link lieber entfernen, bevor hier einer darauf reinfällt.
sogar an beiden Kabel habe ich das Problem feststellen können.
habe direkt mit dem be quiet Support Kontakt aufgenommen und das reklamiert.
das ist ja echt ne Nummer :wall:
Sieht offen gesagt nach Nutzerfehler aus. Ausgerechnet die Ader auf die am meisten Zug entsteht, wenn man nicht aufpasst, ist draussen.
Man muss hier etwas aufpassen.
Tja beQuiet wollte schnell liefern....vielleicht brauchen Cablemod, Seasonic und Corsair deshalb so lange...
Sollte wohl jeder nochmal sein Kabel kontrollieren, grade das von BeQuiet.
das Kabel ist unbenutzt !
ich habe 2 Stück davon an beiden ist das Problem vorhanden.
Ein korrekt eingerastetes Kabel darf nicht raus kommen durch einfaches knicken beim verlegen. Hast schonmal ohne Auspinwerkzeug versucht so ein Kabel rauszuziehen aus der Buchse? Da hat man meist nur das Kabel in der Hand und der Kontakt steckt weiterhin in der Buchse. Also das man nun aufeinmal Kabel wie rohe Eier anfassen muß sollte zu denken geben all die Jahre davor konnte man mit den "normalen" Kabeln veranstalten was man wollte übertrieben gesagt und jetzt ist alles ein Anwenderfehler ....
Konnte meine 4090 FE jetzt ordentlich testen, nachdem ich ne Woche nicht Zuhause war. Der Core ist relativ gut, Mem eher solala.
Timespy läuft mit +300 Core und +1000 Mem durch (bei 1250 schmiert bereits der Desktop ab, Core komm ich damit an die 3130mhz). Alles andere ist nur noch bei ca. +280 Core und +750 Mem stabil. Betreibe die jetzt mit Curve UV 2565mhz@0.875V und +750 Mem. Ist damit immer noch grob 80% schneller als meine alte UV 3090 und verbraucht sogar weniger. (3090 war bei 300-330W, die 4090 jetzt bei 250-280W) Alles darüber stürzt in Spielen zwar nicht ab, erzeugt aber hier und da Grafikfehler/Artefakte.
Kann mich aber, trotzt Temps unter 60C bei minimaler Lüfterdrehzahl, nicht von meiner Wakü verabschieden, finde die +-1000 min RPM immer noch deutlich zu laut, bin aber auch 300RPM Lüfter gewöhnt.
Spulenfiepen ist subjektiv deutlich leiser als bei meiner alten 3090 Stix OC, kann aber auch an den lauten Lüftern liegen.
PS: Idle Verbrauch der 4090 ist bei mir niedriger als bei der 3090. 3090 hatte bei 4K240Hz 55-60W verbraucht, die 4090 jetzt 40-45W.
Hauptsache 20€ für das Kabel verlangen aber QC ist nicht.. weil muss ja schnell auf den Markt :rolleyes2:
Ich noch nicht, hab meine FE aber auch recht spät bekommen und erst danach den Block bei EKWB bestellt, Liefertermin soll der 28.10. sein
Das ist wirklich wenig Taktspielraum für den Speicher. Bei mir hab ich +1700MHz anliegen, was schon nen ganz netten Schub im 3D-Mark liefert. Die GPU hab ich aber nur Testweise angerühert. Da reicht mir die Standardpower für alles was ich zocke noch.
Weiß einer wofür das BIOS Update für die TUF ist ?
Ich muss schon auch sagen soooo langsam ist die 3080 auch nicht. Klar ist die 4090 besser. Keine Frage. Aber es braucht jetzt keine langen Gesichter wenn man keine abbekommt.
Schau, schlechter ist es wenn man eine lärmende oder defekte 4090 liegen hat.
Mittlerweile habe ich kein Bock mehr auf die neue Generation weil die Händler einfach nichts gegen Botter gemacht haben.
So bleibe ich bei der 3080
Also ich hatte bei Proshop bestellt. Ist die Karte im Warenkorb, ist sie für 10Minuten reserviert gewesen. Ich hatte in der Zwischenzeit erstmal Tests überflogen für die Karte und dann in Ruhe bestellt.
Das ist halt nachhaltig sowas von dumm, sorry kann man nicht anders sagen.
Sollte man wirklich im Interesse aller 4090 Nutzer ein Beitrag zu schreiben. Geht ja nicht um irgendein Hersteller Bashing, sondern um 2-2,5k € teure Karten, die dann bestimmt im Schadensfall keiner zahlt...
Ja gut das kann ich ja nicht wissen. Bild aus Rechner hat mich darauf schließen lassen. Sorry.
Ich hatte schon Pins die beim Reindrücken rausgekommen sind. Das waren keine 12VHPWR Stecker. Kann leider immer passieren. Hier wohl besonders leicht. Evtl. sind die zu weich oder Chargenfehler. Wird sich zeigen.
Ähnliche Themen
