[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@Holzmann
Netzteile:
Seasonic Prime TX-1300 1300W ATX 2.4 kann ich empfehlen!
ATX 3.0 brauchst du nicht zwingend für das 16-Pin PCIe 5.0 (12+4-Pin 12VHPWR) Kabel
Nebenbei das Kabel hat auch eigentlich mit ATX 3.0 nichts zu tun, sondern lediglich mit dem PCIe 5.0 Standard
Na also, wenn du dir den Beitrag von Gamers Nexus zu dem Thema jetzt angeschaut hast, dann kennst du jetzt die möglichen Ursachen
Ah Userfehler? Wirklich? Du meinst der ungebildete 0815 User weiß wie und wo er die Leitung des Adapters knicken darf? Steht es irgendwo auf der Verpackung? Gehst du davon aus dass alle ausgebildete Elektrofachkräfte sind und keinen Hinweis benötigen?
Ich weiß, du weißt es, wir alle wissen es. Für mich ist es als wenn man seit über einen Monat einen Zug gegen eine Wand fahren sieht. Es war von Anfang an vorauszusehen, insbesondere vor dem Hintergrund, wo sich die Buchse auf dem PCB befindet in welche Richtung sie positioniert ist und wie klein so manches Gehäuse auf einmal geworden ist.
Meiner Meinung nach, hätte man sogar noch weiter gehen müssen und die PCI-Sig nvidia und alle Board Partner dazu verdammen müssen, Adapter mit einem gewinkelten Stecker bereitlegen zu müssen.
Perfekt. Dieses Bild zeigt genau das bzw eines der Probleme.
Also in dem Fall schaut dass eure Stecker "gerade" drin sitzen (kein seitlichen Druck/Zug abbekommt) sowie die Kabel 1-2cm schön gerade rausgeführt werden und nicht direkt am Stecker gebogen werden.
Dann sollte alles passen und man kann mal die 600W benchen und schauen obs verhebt.
Falls iwelche Kabelbinder an den Kabeln sind muss man beim biegen aufpassen dass ihr dadurch nicht die eine Seite die Kabel fast schon quetscht und auf der anderen Seite die Kabel aus dem Stecker rauszieht.
Mit Kabelbinder am Kabel würde ich besser nicht groß was rumbiegen. Eher nachteilhaft oder gleich diesen Kabelbinder wegmachen. Lockere Kabel lassen sich besser legen.
Ich würde mich da jetzt nicht allzu verrückt machen. Die Stecker sind mit Sicherheit ein Problem und sry, ja bei ner 2000€ mit Hausbrandgefahr ein absolutes No-Go aber eben Stecker ordentlich rein, testen und gut ist.
Ihr sollte nicht den PC alle 2 Tage auseinander bauen und die Stecker neu stecken und Kabel neu biegen^^
Hatte ja heute eine Windforce bei Alternate für 1949€ bestellt und gerade kam eine Mail. Die Karte war heute angeblich überhaupt nicht verfügbar, war ein Fehler im System. Man bietet mir jetzt eine Gainward Phantom an, natürlich für 2070€ nachdem der Preis bis heute seit Release immer 1949€ war :ROFLMAO: Und nachdem es ja immer noch Meldungen zu dem Lüfter gibt, auch bei deutlich später gekauften Karten, gehe ich davon aus, dass eine Phantom jetzt keine Besserung im Vergleich zu meiner Phantom GS ist und die das Sägen einfach alle haben. Wäre mal aber interessant zu wissen, ob hier jemand eine Windforce heute im Versand hatte bei Alternate und falls ja, zu welchem Preis. Direkt nach meiner Bestellung war der Preis nämlich noch kurz bei 2149€ und noch einige Minuten "Auf Lager".
Also ich würde mich über die Lüfter auch nicht verrückt machen. Morgen kommt meine vermutlich, dann mal sehen. Ausm geschlossenen Gehäuse soll man ja nicht viel hören, siehe auch Post #12.913 auf der vorherigen Seite, da schreibt doch jemand über die heute angekommene Gainward ^^
Und das für UVP bestellt, wo die Preise gerade wieder explodieren, zahl ich sicher keine 200-300 mehr für ne andere Variante. :d
Frag doch Alternate, ob du die nicht auch zum gleichen Preis kriegst, da die heute morgen ja noch auf UVP war ;)
Schon irgendwie lustig, wie alle GPU's direkt weg sind, scheissegal was da für ein Preis steht ;D
Schön scalpen lassen! ^^
BTW so sieht der Adapter ohne Schlauch aus.
Bild aus igor's LAB:
Es verlaufen 4!!! 12V Kabel zum Stecker und werden innerhalb des Steckers auf 6 Pins aufgedröselt.
Darin scheint es zu Problemen zu kommen. Hat einer einen Adapter übrig und würde ihn aufsägen? :d
@miauze Das Problem sollte eigentlich NUR bei dem Adapter auftreten...
Habe heute zwei 4090 über Amazon bestellen können (direkt Amazon Deutschland) eine TUF und eine Strix.
Strix ist schon auf dem weg.
Guckt eigentlich von euch ab und an auch jemand bei Amazon?
Bei Mindfactory habe ich heute nochmal ne Suprim X bestellt.
Habe heute auch den erste Rückläufer als angebliche Neuware erhalten vom MM war ne TUF OC.
Kaum Spulenfiepen Taktet mit OC bis 3160MHz im Speedway ... VRAM war aber bei 1450 Schluss
VF-Curve 2840 bei 1050mV
Bislang hatten alle Karten Spulenfiepen je nach Last und FPS
Am schlimmsten waren jedoch bislang leider fast immer die Strix und MSI ... hörten sich nicht gesund an (Je nach FPS und Last!!)
Eigentlich suche ich genau davon eine "Gute".
Wie läuft denn das jetzt wieder bei Proshop? Wollte mir die Demo-Inno mal kommen lassen. Schlechtestmögliche Karte aber immerhin preislich gut und es gibt Waterblocks. Steht auf Lagernd aber kann nicht bestellt werden.
Habe heute zwei 4090 über Amazon bestellen können (direkt Amazon) eine TUF und eine Strix.
Zuletzt gab's die TUF für 2,7k bei Amazon... NEIN danke!
Schreib mal Amazon an bevor du die Karte zurück schickst ... da geht eigentlich immer was vor allem wenn Sie am Markt viel günstiger ist.
Hm also irgndwie hab ich kein Glück bei der 4090.
Habe hier eine Asus TUF OC und eine Zotac AMP AIRO.
Die TUF ist gefühlt ein Düsenjäger... in 3dMark habe ich das gefühl die hebt gleich ab. deutliches Spulenfiepen im hohen FPS Bereich sowie wenn die Karte beansprucht wird (Cyberpunk).
Die Zotac hat gefühlt kaum Spulenfiepen bzw mit geschlossenem Gehäuse merkt man asolut nichts, jedoch rumpeln die Lüfter bzw Motoren der Lüfter ziemlich heftig sobald die Lüfter anfangen zu drehen. Hatte die Hoffnung das ich eine "gute" Karte erhalte wie manch ein anderer hier im Forum, leider ohne Erfolg... keine Ahnung was von beidem schlimmer ist.
gehen beide wieder zurück
Wollte noch eine Inno3D xChill kaufen.. im Wahn wurde es eine Inno3d OC für 2300€, UVP ist 2000€ oder 2200€ ?... Bin am überlegen ob ich die überhaupt auf mache bzw liest man ja das einige PCB´s schlechtere Bestückungen haben was CPU bzw Vram angeht und diese gehört auch dazu... ist da was dran bzw mach ich mich da zu verrückt?
Gibt es noch Geheimtipps ?
Ich hätte die Möglichkeit eine Suprim X zum EK (2350€) gebraucht zu kaufen, diese scheint wohl nur minimal Spulenfiepen zu haben. Abtrittserklärung von MF bzw im Garantiefall würde der VK das auch erledigen, was meint ihr bzw wie verhält sich MF bei Abtrittserklärungen, konnte auf der HP nix finden.
Ist das wirklich so⁉️
Wenn ein normaler 8-Pin abfackeln kann, kann auch das Kabel von beQuiet abfackeln, aber die Chance ist gering... :d
Irgendwas innerhalb des 12+4-Pin Steckers vom Nvidia Adapter geht kaputt. Was immer es auch ist die Kabel von beQuiet, Corsair, Asus, etc haben das nicht.
Die verkleinerten Kontakte des 12VHPWR Steckers sind nicht das Problem. Sonst hätte man schon viele Meldungen mit den RTX3000 FEs und den 3090Tis gehabt..
Wir schon nicht abfackeln? Werds einfach testen. :o
@TomCom205 , ich schau eigentlich regelmäßig bei amazon (direkt amazon als verkäufer) aber irgendwie kein glück , komisch bei dem 3090 release der angeblich schlimmer gewesen sein soll hatte ich relative zeitnah auf amazon eine evga 3090 bekommen können zu normalen preis
@Slipknot das sieht ja auch ganz normal aus und sind denn kabel nicht kabel um "gebogen" zu werden bzw gängige praxis beim verlegen , abknicken ist naturlich was anderes und wird leider zu häufig benutzt in den bezug auf die stecker und kabel adapter ,
Heute kam endlich das be quiet! Kabel und es machte auf mich einen sauber verarbeiteten Eindruck, scheint ja sehr wichtig zu sein.
Ich habe es in meinen Augen in einem so hoffe ich gesunden Rahmen zurechtgebogen, ein Kompromiss aus Vernunft und Optik.
Weiterhin habe ich weder Kosten, noch Mühen gescheut und aus Sicherheitsgründen eine Elektrikerin beauftragt, die stets alle Werte überwacht und zur Not durch Schmelzung Komplikationen anzeigt.🧑‍🔧
Ähnliche Themen
