[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Alles qool.
Bald werden Brandmelder mit RGB und USB-intern-Anschluss für das Case verkauft und man can ruhig RTX 4090@600W ballern. :o
Habe bereits am 25 September auf die Brand-Problematik hingewiesen. :o
sogar an beiden Kabel habe ich das Problem feststellen können.
habe direkt mit dem be quiet Support Kontakt aufgenommen und das reklamiert.
das ist ja echt ne Nummer :wall:
Bei meinem BeQuiet Kabel alles gut :-)
Geliefert von BeQuiet direkt aus dem Online Shop.
Ob es so intellgent ist, jetzt extra auf ein Atx 3.0 Netzteil umzusteigen damit man
den 12VHPWR Stecker direkt am Netzteil hat ? So kann das Problem sogar auf beiden
Seiten auftreten. Am Netzteil und an der Graka.
Danke wusste ich nicht.
Das hier:
Oder das teurere Asus:
Das Thor hat keinen 12VHPWR, nur den PCI 5.0 Power anschluss... also einen 2x8-Pin zu 12+4-Pin Adapter.
Möglicherweise gibt es eine andre Ausführung als die, die du gepostet hast.
Edit: Das Lian Li 850W hat nur einen 300W 12VHPWR Stecker, der nicht mit RTX 4000 kompatibel ist o_O...auf Geizhals steht aber 12+4Pin
Ergo Geizhals hat einige Netzteile falsch gefiltert...indem der 12VHPWR (300W) mit dem 12VHPWR mit Sensorpins (600W) gleichgestellt wird...
Edit: Die Asus Netzteile ROG Loki und TUF Gaming Gold haben aber dern 12+4-Pin Stecker. Beide aber noch nicht released...
Die Liste mit dem 12+4Pin Stecker wäre (soweit ich suchen kann):
Alle ATX 3.0 und noch nicht verfügbar...
Thermaltake ToughPower GF3
Asus ROG Loki
Asus TUF Gaming
Silverstone HELA
Seasonic Vertex
MSI MPG A1000G PCIE5 (nicht zu verwechseln mit dem non-PCIE5)
Und mit ATX 2.3
Gigabyte UD1000GM PG5
Ja stimmt, die haben das rausgebracht, als das gerade noch nicht finalisiert war.
Asus war da also zu schnell, Hat nur einen 12 Pin Anschluss :d
hatte auch direkt bei be quiet! bestellt, wie gesagt war an beiden Kabel einer der Steckkontakte locker, der Hersteller sendet kostenlos Ersatz sobald verfügbar.
der Pin rutscht vermutlich beim einstecken oder biegen der Kabel etwas zurück, einfach nach einstecken des Kabels nochmal kontrollieren ob der 12VHPWR richtig sitzt.
dennoch sollte man das im Blick behalten, bei erneuten Steck - Vorgängen kann sowas auch immer wieder mal passieren.
ich hab dennoch Ersatz beauftragt, evtl. ist das einfach nur bei dem ein oder anderen Kabel der Fall, vielleicht aber auch ein Qualitätsproblem was mit einer neuen Charge behoben ist.
Mein Kabel ist nicht groß gebogen da ich kein Seitenteil aus Glas habe und es total Banane ist wie es da drinnen aussieht. Insofern werde ich da keine Probleme haben :)
Hab heute meine 4090 Phantom von Alternate bekommen. Das Lüftersägen oder ich würde es eher als Summen bezeichnen, ist bei mir nur minimal wahrnehmbar bei geöffnetem Gehäuse. Wird dann vom Spulenfiepen übertönt.
Beim Time Spy bei doppelten Frames wie mit der 3080 ist das Fiepen aber auch nicht schlimmer wie mit der 3080 Suprim X. Bin also von den Geräuschen zufrieden mit der Karte könnte viel schlimmer sein.
Ein Problem hab ich allerdings. Bei jedem Neustart friert der PC ein kurz bevor er in den Anmeldescreen von Windows umschalten soll. Der drehende Kreisel bleibt dann stehen und es tut sich nix mehr. Mach ich dann den PC mit dem Gehäuseschalter aus und starte wieder neu funktioniert es wieder. Beim nächsten Neustart dann das gleiche. Im Bios hab ich mal die Einstellungen zurückgesetzt und auch Windows Fast Boot ausgeschaltet. Hat alles nix gebracht. Eventuell hat noch wer nen Tip?
Danke!
Hat noch jemand eine Windforce bei Alternate gerade bestellt? Habe gerade mit Express noch für 1949 zugeschlagen aber steht jetzt auf "Bestellung kann nicht bearbeitet werden, da Artikel nicht lieferbar" :(
War mit ampere genauso. Deren Systeme ist nicht schnell genug. Dafür kannste per Knopfdruck stornieren 😆
Ich würde laufen lassen solange es eine 1949er ist
Die Stückzahlen sind aber generell sehr niedrig was so bei den Shops ankommt darum sind die auch immer so schnell wieder ausverkauft weil eben nur sehr wenig reinkommt an Karten
Mal schauen wie lange das noch so bleibt und wann sich das dann normalisiert und man mal länger Zeit hat als nur 1 min um die zu kaufen ( damit meine ich generell die Karten bei allen shops )
Mindfactory die drei haben sich verkauft in den knapp 2 Wochen : ( 250 , 120 , 60 )
Dachte es waren 600 suprims?
kann mir jemand sagen wie ich in cyberpunk dlss 3.0 aktiviren kann auf meiner 4090 ?
Danke @ hwk dachte schon bin zu blöd es zu finden
Betrifft das eigentlich auch die Corsair kabel..?
Meins sitzt eigentlich gut ist zwar sehr steif und mein Deckel kriege ich auch zu.
Lg
Das kann denke ich jeden Stecker treffen. Die sind einfach nicht optimal. Hier müsste sichergestellt werden das die Kontakte besser gegeben sind. Das sind ja die etwas größeren Kontakte als bei den Arduino Dev Boards. In der Akkutechnik (Modelflug usw) kennt man das Problem weshalb man da ganz andere Stecker nutzt. z.T. auch "gefederte" Kontakte wie bei den "Bananenstecker" im Labor
Man kann es aber verhindern/minimieren in dem man eben schaut dass die Stecker maximal gut sitzen (kein seitlichen Druck, gerade Kabelführung vom Stecker weg)
Habs gerade mal bei der FE getestet.
Furmark + 33% Powerlimit und 100% Voltage und die Karte mal 20 min auf 580W-600W laufen lassen.
Stecker blieb mit den Temps (außen) bei ca 50°C rum.
Wenn das gut ist vorsichtig Deckel zu und schauen dass nix am Kabel groß gebogen wird^^
Inno 1798 Euro! Edit- aso, eine DEMO-Karte!
Achtung! DEMO @BmwM3michi
Irgendwie kam heute quasi nix bei MM und Saturn. 1x eine Gaming OC, die instant gebottet wurde und 1x eine Zotac Trinity OC bei der ich Angst wegen dem Lüfter habe :-/
Zum französischen shop meine Erfahrungen:
Am 19.10. eine PNY 4090 bestellt die zwar nicht auf Lager war, aber als innerhalb von 5 Tagen als lieferbar gekennzeichnet war; diese Karte war dann doch nicht lieferbar
Gestern am 24.10. mittags eine Gainward 4090 bestellt (dürften eine größer Lieferung bekommen haben) und heute schon die Versandnummer bekommen.
Also ich kann nix negatives von der Abwicklung berichten, bis jetzt ne klare Empfehlung, zumal die wirklich mehrere Karten bekommen dürften und die nicht innerhalb einer Minute weg sind.
(y)
Bei 17 cm Towerkühler und der 4090 TUF musst aber den Adapter an der GPU extrem stark biegen damit die Scheibe wieder drauf geht oder?
Jap, ich will dringend einen 90°-Stecker haben nach den ganzen Schockbildern hier.
Aber sicher nicht für 50$ Aufpreis über den großen Teich, das riecht doch förmlich nach Verschwörung, dass Kabelhersteller für teures Geld Ersatzteile für schlecht konstruierte Centartikel sofort im Angebot haben :fresse2:
Du hast ja scheinbar in den Slots 6 und 7 vom Motherboard unten noch 2 weitere Karten eingebaut. Passen da dann auch noch die 140/120 Bodenlüfter im Gehäuse?
Nö, die Graka zieht ja jetzt auf gesamter Länge Luft ins Case^^
Tatsächlich ist der Airflow in dem Teil ziemlich perfekt: 2x 140 mm in der Front, 1x 120 mm hinten – mit der Konfiguration haben auch Deckel, Boden und Seite Luft gezogen und erst himter der CPU wurde wieder Luft aus dem Gehäuse gedrückt. Hatte befürchtet, dass bei den ganzen Lochblechen die Frontlüfter alles direkt dahinter schon wieder rausdrücken – aber wie gesagt: Funktioniert super.
Ich würde bald behaupten dieser Kabelbinder beim BeQuiet unter dem Schrumpfschlauch ist kontraproduktiv, da er alle Kabel absolut starr aneinander presst und kein Spiel mehr vorhanden ist. Erst ohne jenen kann man die einzelnen Adern mal überprüfen und Biegungskräfte wirken auf die Adern einzeln und nicht auf das starre Ganze 🤷‍♂️
Das BeQuiet Kabel geht von 12VHPWR mit 12x AWG16 auf 24x AWG18 Kabel über in 2x 12Pin Netzteil. Nen 12Pin Stecker in "normaler" Größe wäre kaum größer gewesen, aber dafür irgendwie deutlich stabiler wirkend, und dennoch deutlich kleiner als 3 bis 4x 8Pin PCIe.
Also mein beQuiet Kabel sieht i. O. aus. Die Info das man die Kabel nicht biegen darf, ist mir neu. Habe es bei mir auch gebogen, hoffe das geht noch klar. Warm wird das Kabel allerdings schon, das Fenster wird auch richtig warm an der Stelle wo das Kabel liegt.
Hatte ja heute eine Windforce bei Alternate für 1949€ bestellt und gerade kam eine Mail. Die Karte war heute angeblich überhaupt nicht verfügbar, war ein Fehler im System. Man bietet mir jetzt eine Gainward Phantom an, natürlich für 2070€ nachdem der Preis bis heute seit Release immer 1949€ war :ROFLMAO: Und nachdem es ja immer noch Meldungen zu dem Lüfter gibt, auch bei deutlich später gekauften Karten, gehe ich davon aus, dass eine Phantom jetzt keine Besserung im Vergleich zu meiner Phantom GS ist und die das Sägen einfach alle haben. Wäre mal aber interessant zu wissen, ob hier jemand eine Windforce heute im Versand hatte bei Alternate und falls ja, zu welchem Preis. Direkt nach meiner Bestellung war der Preis nämlich noch kurz bei 2149€ und noch einige Minuten "Auf Lager".
Ähnliche Themen
