[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Erst durch wirkliches Spielen und Ausprobieren kommst du dazu.
Wie gesagt meine Theorie ist.
Einige User in diesem Threar haben ihre Karte seit dem ersten Tag und bisher hat sich niemand über verschmorte Stecker beschwert.
Kabel mitunter zu stark geknickt, Power-Limit auf max, Voltage auf max, max Settings und hohe kontinurliche Dauerbelastung gaben diesen Steckern den Todesstoß.
Es gibt einige, auf die das zutrifft, aber nur bei 3en ist der Stecker verschmort, warum?
Wenn an deiner These was dran wäre, müsste es auch bei mir reproduzierbar sein und das ist es aktuell nicht. Jedenfalls gibt es dafür keine Indizien.
Eventuell ging man davon aus das unter guten Voraussetzungen dieses Phänomen erst jenseits der 600 Watt auftritt. Deswegen Limitierung des PT um eventuelle Lastspitzen abzufedern.
Nun hat dies wohl doch nicht so wirklich gereicht, man hat sich schlicht und einfach etwas verzockt.
Klar, gerade ein US Unternehmen geht das Risiko ein, dass die Wohnungen/Häuser der Käufer abbrennen und sie in Grund und Boden verklagt werden.
Wer auf Nummer sicher gehen will, der steckt vorerst nur 3 Kabel an den Adapter, oder lässt seine Griffel weg von dem PT oder der Voltage :geek:
Woher weißt du eigentlich, dass die 3 betroffenen nicht @Stock liefen? ;)
Wer auf Nummer sicher gehen will, der Steckt vorerst nur 3 Kabel an den Adapter z.b
Oder lässt seine Griffel weg von dem PT oder der Voltage :geek:
Wir wissen ja noch nichmal ob das nich aucch mit 450 Watt oder auch mit 400 Watt oder 350 Watt passieren kann.
Auch wissen wir nich was passiert wenn der Nutzer grad nich in der Nähe ist wenn sowas passiert
Sind ja nun schon 5 Fälle ( mit unserem Luxxer ) bei dennen das passiert ist in den 2 Wochen ... wer weiss wieviele es bisher schon wirklich gibt ... nich jeder schreibt gleich ins Net
und wer weiss wie das in weiteren 2 Wochen aussieht .. vielleicht passiert das bei einigen auch erst nach 1 Jahr oder nach 6 Monaten
Und was ist mit dem Sommer wenn es in den Zimmern wärmer wird und der Stecker dann eben auch ?
nope wenn du nur ein 3 fach Kabel hast, gehen da 450 drüber
nur die 4x Stecker können theoretisch 600
Aber der Endstecker an der Grafikkarte ist doch beim "vier Zack" mechanisch gleich?
Also 600W finde ich bei diesen Stecker alles andere als vertrauenswürdig, soll er ja angeblich können. Kein Wunder warum der über 60 °C warm werden kann. Erschließt sich mir nicht warum die Elektronik-Ing. bei Nvidia so ein Risiko eingehen.
Äpfel mit Birnen, MSI könnte locker für diese Karte ein 600 Watt+ Bios bringen, wieso passiert es nicht?
Wieso ist selbst das Perfomance Bios beschnitten, normalerweise bei so einer Art von Karten sind solche Biose teilweise komplett offen.
Ich kann mich dabei nur zu gut an ein LN2 Bios auf meiner damaligen KingPin erinnern.
Man munkelt dass MSI das Powerlimit limitiert um ggf. Gewährleistungsansprüche gegenüber Nvidia geltend machen zu können, falls nicht die Karte sondern die GPU Hopps geht. Da gibt es aber seitens von nvidia Bedingungen unter anderem das Powerlimit. Ist aber nur ein Spekulatius.
Ich glaube schon, nur man hält sich bedeckt ^^
Aber schauen wir was da noch so kommt.
So sieht das aus... btw. viele Elektromeister hier, hätte ich gar nicht gedacht. Und eindeutig zu viel Kaffeesatzleserei.
Was wir wissen, dass der Stecker wohl, unter Umständen, der Belastung nicht standhält.
Folglich, ich jage nicht so viel Leistung da durch und betreibe die Karte nicht an der Kotzgrenze.
Laut Cablemod werden deren Adapter für Asus und Seasonic unter einer Bestellnummer zusammengefasst, damit sollte das Seasonic auch an ein Asus NT passen oder hab ich da gerade einen Denkfehler?
Spannend wird noch dazu das bei Asus Karten der Stecker anders herum sitzt, ob es dann wohl 2 Versionen gibt ;-) Hatte Der8aur bereits erwähnt.
Woher weißt du das?
Sag mal du hast doch die Bilder gesehen, du darfst gerne selbst ausprobieren.
Mach Voltage auf max, PT auf Max und lass mal für ein paar Stunden deine Karte bei 500-Watt stresstesten.
Vielleicht knickst du dein Kabel noch etwas, wobei das nicht bei jedem der betreffenden User der Fall zu sein schien.
Du kannst dann berichten. Sollte nach deiner Ansicht ja keinerlei Probleme geben.
Es ist doch vollkommen legitim das man, wo man noch nichts genau weiß, erstmal auf Nummer sicher zu gehen.
Gerade bei einer 2K Karte mit mäßiger Versorgungslage.
Zu dem Thema das zu testen.... Wer das Video von Steve (Gamersnexus) zum NZXT H1 gesehen hat, sollte wissen, dass man da immer ein Extremszenario sucht.
Also klar man kann jetzt ein Adapter nehmen und den 100 Mal ein- und ausstecken und ihn mit Gewalt im Kreis drehen bis es zu kokeln anfängt. Nur dann hat man auch nicht viel gewonnen, außer der Erkenntnis, dass Missbrauch zu Defekt führt.
In meinen "Tests" und auch den von mehreren "Fachleuten" ist ja nichts passiert. Somit sollte man eher von vereinzelt schlecht konfektionierten Kabeln/Adaptern ausgehen, oder schlichtweg vom massiven physikalischem Einfluss.
Ich denke Jeder sollte sein Adapter/Kabel optisch kontrollieren und den sicheren halt der Buchsen prüfen. Dann das Kabel sauber einstecken und es frei ohne irgendwelchen Druck hängen haben. Mehr kann man nicht tun.
Brauch ich nicht, das haben schon andere getan:
Ach, jetzt weiß man nichts genaues mehr? Du behauptest doch permanent zu wissen, was Phase ist:
Bei mir geht das rote Licht aus wenn ich den PC hochfahre. Trotzdem bin ich auf 450 W limitiert
Habe so gerechnet:
Strix 4090 500 w default und 600 OC
Max power target 120% (in yt videos)
Ich habe max power target 90% (=450 W) da 100% die 500W Default wären.
Könnte das mitgelieferte 4 8pin auf 12vhpwr Kabel defekt sein?
Ich habe gerade gesehen das du das gleiche Verhalten hast wie ich.
Hast du eine Lösung für die 90% entdeckt?
Ich seh schon kommen, wenn man nicht das Kabel von NVidia nimmt gibts keine Granatie.
Du bist mir zu anstrengend, mach was du für richtig erachtest ;)
Die Stecker sind in Ordnung es gibt keinerlei Probleme
Laut Cablemod werden deren Adapter für Asus und Seasonic unter einer Bestellnummer zusammengefasst, damit sollte das Seasonic auch an ein Asus NT passen oder hab ich da gerade einen Denkfehler? Asus NT müßten demnach Seasonic NT sein.
Ja asus nts sind quasi seasonics. Deswegen sind die ganzen cablemod Kits für beide Marken kompatibel
Man kann nur hoffen, dass Nvidia in Kürze einen zertifizierten Stecker nach reicht, der um 90 Grad abgewinkelt ist und nicht so teuer ist.
Also meine
Meine ist nun auch angekommen. Sorry für die Frage aber was soll das denn bitte für ein Kabel sein, was man auf dem Bild sieht?
Ich habe auch irgendwie kein Anschluss gesehen, dachte ja schon beinahe was wäre der neue 600 W Stecker nicht das sonst zack, boom folgendes passiert:
Ne ernsthaft Leute, was soll das bitte für ein Zubehörkabel sein, weiß das jemand?
Das ist ein ARGB Kabel damit kannst Du adressierbare Beleuchtung aktivieren. Steht auch auf der Produktseite
Diese gewinkelten Stecker werden arschteuer sein aber klar, hätte man von Anfang an beilegen müssen.
Ich brauche ihn nicht mehr... Vertical Mount regelt das schon.
So langsam ergibt sich ein Bild.
Stellt euch doch mal die Frage warum z.b eine MSI Suprim 26 Phasen hat bzw warum die Partner Karten so auf Power/Kühlung ausgelegt sind diese aber nicht genutzt werden kann?
Weil PT und Voltage "künstlich" klein gehalten wurden.
Warum sollte man dann auf Power und Oc entwickeln.
Dies macht doch alles keinen Sinn?
Außer wenn es bei den größeren Karten einen zweiten Stecker hätte geben sollen.
Einfach weil der Stecker die limitierende Komponente ist. Die Bilder der PCIE-Kommission zeigen es deutlich, diese Information liegt uns doch auf dem Tisch.
Wenn der Stecker bei hoher dauerlast schmilzt, muss man eben hergehen und das Power Limit und voltage künstlich beschneiden.
500-600 Watt max unter Dauer und deren Lastspitzen sind wohl jetzt doch ein Problem geworden.
Die Karten sind dennoch schnell, nur für Übertakter oder Benchmark Rekord Jäger gerade zu sinnlos.
Ich bin echt gespannt, wie es weiter geht, das Thema wirft schon ein paar interessante Fragen auf ..
Das ist doch Quatsch. Selbst die 450W sind schon über dem Sweetspot für den Chip. Eine weitere Erhöhung des PT bringt kaum noch einen Performancegewinn. Moderne Hardware läuft einfach oft schon so am Limit, dass kaum noch OC Potential besteht. Und wer Weltrekorde jagt, ignoriert das PT eh mit Shuntmods und lötet ein EVC zum Spannung erhöhen ein.
RTX 2000 und 3000 hatten doch auch kaum noch Headroom für manuelles Overclocking und das war vor dem neuen Stecker.
Vielleicht hat der Dude auch ein Leben, was es nicht zulässt hier ständig im Forum zu idlen. Wäre aber eine zu einfache Annahme. Besser direkt Steinigen. (y)
immerhin liest er hier wohl fleißig mit, auch gerade:
und schreibt unter anderem sowas:
Für mich sind neue GPUs im privaten Bereich erst dann wieder interessant, wenn der Stromverbrauch deutlich(!) SINKT, dabei die Leistung mindestens ebenbürtig bleibt und die Preise für das Spitzenmodell unter 1000€ liegen. Irgendwann ist PC spielen (das mache ich privat damit) einfach zu teuer, in Anbetracht der Strompreise und der unverschämten Margen. Hype und habenwill voll nachvollziehbar. Aber irgendwann setzen wirtschaftliche Zwänge oder wirtschaftliche Vernunft Grenzen. Und die sind bei mir schon lange überschritten.
Weiß nicht, ich bin eher skeptisch. Vielleicht klärt er uns ja auf.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
