[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
immerhin liest er hier wohl fleißig mit, auch gerade:
und schreibt unter anderem sowas:
Weiß nicht, ich bin eher skeptisch. Vielleicht klärt er uns ja auf.
Leute, wenn er schreiben will, wird er es machen, wenn nicht, sein Bier.
Ich verstehe die drölf Enthusiasten hier.. alle haben über 19XX€ für eine Grafikkarte gezahlt und wollen das alles richtig läuft. Jedes Haar in der Suppe ist aktuell Gift. :) Ausserdem jeder zusätzliche Grund zum Zurücksenden ist da Recht. Spulenfiepen, Bananenkarte, Schmelzgefahr.
Wir sind halt alle "etwas" gereizt. :d Aber ist das nicht immer so bei neuer Hardware? :)
So sieht das aus... btw. viele Elektromeister hier, hätte ich gar nicht gedacht. Und eindeutig zu viel Kaffeesatzleserei.
Ich sag zu den unbelehrbaren Kunden mit maroder E-Anlage immer,mir egal mit welchem roten Auto ich komme :d
Nur mal zum Verständnis.Ob ein Kondensator im Netzteil abraucht ist Peanuts,ein Kabelbrand ist da eine ganz andere Hausnummer.
Kann sich ja mal jeder von den Spezies hier selbst ausmalen was ein Brand bedeutet,auch für die eigene Familie.
Nur weil man Nachts den Rechner zum Rendern laufen lässt und so ein popeliger Stecker dicke Backen macht.
Soll keine Panikmache sein,einfach mal reflektieren...
Wenn Coil Whine kein RMA Grund ist, dann musst du sie zurückschicken oder in Zukunft nur noch mit Hörschutz ans Gerät gehen. Was soll man sonst machen?
Das ist doch Quatsch. Selbst die 450W sind schon über dem Sweetspot für den Chip. Eine weitere Erhöhung des PT bringt kaum noch einen Performancegewinn. Moderne Hardware läuft einfach oft schon so am Limit, dass kaum noch OC Potential besteht. Und wer Weltrekorde jagt, ignoriert das PT eh mit Shuntmods und lötet ein EVC zum Spannung erhöhen ein.
RTX 2000 und 3000 hatten doch auch kaum noch Headroom für manuelles Overclocking und das war vor dem neuen Stecker.
Mehr als 16 Phasen und Kühler für deutlich mehr als 900 Watt Leistungsaufnahme sind doch quatsch.. sowohl die GPU, als auch das Phasendesign der meisten Partnerkarten sind ja wohl definitiv nicht der limtierende Faktor?
Was bleibt denn dann übrig?
Lt Pcie Gremium und Bilder von Usern das verschmorte Kabel, als offensichtliche Schwachstelle.
Warum dürfen die meisten Karten sich nur bis max 520 Watt - 550 Watt genehmigen?
Außerdem geht es nicht um iwelche sweetspots bei Karten mit einem grundlegenden massiven powerdesign welche für oc geeignet sind.
Mit der Argumentation könnte sich jeder hier mit einer Gamerock zufrieden geben.
Ich hätte mir für meine suprim gerne ein 600+ Watt bios und mehr voltage gewünscht.. Gerne auch einen Stecker mehr um dann halt 750 Watt aufwärts, um eben etwas mehr Spielraum bei den lastspitzen zu haben.
Fuck, meine 4090 TUF ist gerade beim Warzone 2 zocken abgeraucht. Es stinkt alles verschmort und die Sicherung ist geflogen.
Das hat doch jeder "Blinde" erkannt das dies Quatsch war. Ich habe mal die letzten Wörter dick makiert, warum?
Ganz einfach weil eben die Sicherung bzw. FI nicht auslöst, denn bei einem Kurzschluss schaltet nämlich sofort zuerst das Netzteil ab, wenn das nicht defekt ist. Was eher selten der Fall ist das die OVP und OCP defekt werden kann. Zumal ich schon so einen Fall eines brennendes Kondensator/Widerstand auf einer 1080 TI hatte. Wenn nämlich solch ein Brand (kleiner Feuerball) entsteht dann schaltet das Netzteil nämlich noch nicht ab, da oft noch kein Kurzschluss vorliegt, der folgt dann erst später. Bei einen Kabelbrand was nicht auf einen deutlichen Überstrom die Folge ist (Kurzschluss) erfolgt überhaupt keine Abschaltung weder vom Netzteil und schon gar nicht vom FI, der löst eben nur bei einem Kurzschluss in Zusammenhang mit deinen defekten Netzteil aus.
Ich habe ihn bezüglich meiner Kabelfrage nicht umsonst zitiert. Am besten gefällt mir aber @bigdaniel, scheint ein Verschwörungstheoretiker zu sein und schreibt das in einem anderen Forum gleich mal als Fakt bzw. bewiesen Fall hin. Sehr lustig der "Dude".
Ich habe gerade gesehen das du das gleiche Verhalten hast wie ich.
Hast du eine Lösung für die 90% entdeckt?
Ja bei mir ging's einfach nach dem Neustart und nachdem ich Die Stecker Mal alle raus und richtig fest wieder rein hab. Vor allem der an der GPU
Möchte hinzufügen, dass es Warzone 2 auch noch gar nicht gibt ^^
Ist jetzt die rote LED im ausgeschalteten Zustand aus oder an?
Der Stecker hat wirklich kein Feedback, man merkt Null ob er drinnen ist oder nicht.
So habe meine Gainward Phantom GS nun ausgiebig testen können. Keine falschen Geräusche (Habe den Fan auf 100% geschoben im Afterburner und 10 minuten laufen lassen - laut, aber nicht so wie in einigen Videos hier beschrieben.
Habe von Alternate bestellt.
Sehr zufrieden soweit. Habe eine 1000w von Corsair und scheint mehr als genug zu sein.
Games die ich getestet habe:
Hellblade Senua Sacrifice (Rtx ULTRA settings - 4k)
Control (DLSS ausgeschalten, um die Grafikkarte mehr auszulasten für den Test, alles Ultra, 4k, RTX max)
Bei voller Auslastung erreicht sie 70°, liegt aber daran dass mein Office sehr warm ist.
Die Fans sind durchschnitt. Werde nicht lügen und sagen dass sie leise seien bei 100% Fan-Speed, aber definitiv nicht mit diesem Quietschen/Surren in einigen der Videos.
Hoffe ihr alle bekommt eure auch noch!
Ähm bei der 3000ner Serie durften auch nur wenige über 400W von den 3090ern .
Schau mal nach !
Was hier wieder los ist genau so wie damals das Gerücht das New World die Karten killt!
Es ist immer mit etwas Ausschuss zu rechnen .
Jetzt legt man halt besonders den Fokus auf den neuen Stecker!
Und betreibt Panik mache!
Hier sind schon so viele Leute mit einer 4090 und die laufen alle Anstands los wie es scheint.
Die ist an, denn solange der PC aus ist, ist ja nicht genug Strom da. Wenn ich den PC starte geht das Licht aber aus.
@tomm73 was hast du nur gemacht? Dein gestriger Einzeiler hat den ganzen Thread hier zerbumst!
...und dann bist du auch noch, mir nichts, dir nichts, einfach pennen gegangen, während hier viele schweißgebadet die Nacht durchgemacht haben.
:d :d :d :d ...der geniesst das doch ... :d :d :d :d
Versandbestätigungen von den 1949€ TUFs von Gestern gehen grade raus. Kumpel hat Glück gehabt, obwohl ich eindringlich vor Spulenfiepen gewarnt habe. o_O
Das wäre aber dann zumindest die 5. ASUS Karte die ich mir "anhören" kann.
Finde ich trotzdem Merkwürdig, dass trifft ja auf alle GPUs zu.
Meine Strixx RTX 3080 hatte die LED auch aus, wenn der PC aus war.
Andere gehen in die Oper - du gehst ins Case mit TUFFY :d Viel Glück, dass es eine Symphonie wird und kein Pfeifkonzert ! :fresse2:
Ja die Verlinkung um CB war etwas voreilig - aber vielleicht meldet sich der User ja noch. Ansonsten habe ich kein Problem dies wieder zu revidieren. Versteht ich bin nicht gegen euch aber ich bin auch nicht hier um Hersteller X zu verteidigen.
Habe mir ein Thermometer bestellt und werde mal schauen wie heiß der BeQuiet Stecker wird.. die Karte voll auszufahren traue ich mich aber jetzt nicht mehr 🙈
same hier :d ich werde ebenfalls berichten. Hab die TUF OC mit 550 watt im Furmark getestet. Bis jetzt leider nur gefühlte temps gechecked. War soweit alles in Ordnung.
Sobald das Thermometer da ist werd ich mal Tests machen.
Ähnliche Themen
