[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hätten die TDP auf 350 Watt setzen sollen, 2 normale Stromanschlüsse benutzen, Kühler kleiner und hochwertiger verbauen und dann die Grafikkarte 100€ günstiger anbieten sollen.
das wäre ein guter Kompromiss gewesen und die Leistung wäre immer noch extrem gut wenn man sieht was man mit 350W TDP erreicht
Mal ne blöde frage. Ist es nicht besser bei meinem NT den oc Knopf nicht zu drücken? Dark Power 12 pro 1500W 😄😄😄
Weißt du denn überhaupt was dieser Knopf macht?
Eher nicht nach deiner Frage zu urteilen.
Damit wird einfach nur die Aufteilung der Rails überbrückt und das Netzteil verhält sich wie ein Single-Rail Netzteil
ja scheint schon was zu taugen. Aber 2x8pin würde ich jetzt nicht unbedingt nehmen für die 4090 :fresse:
"The first person that wrote this review with the same headline was RIGHT! I installed this on my MSI 4090 Gaming Trio and a week later the cable head that connects to the actual GPU started melting. Luckily I caught it on time and hopefully there are no damages that I know of so far. The same happened to my friend as well. I hope Amazon reads this."
Naja :d
Hatte zwar die Idee aber bringt glaube ich nichts, das Material ist ein Wärmeisolator. Könnte von Innen beginnen an zu schmelzen noch bevor dein TC von außen ein signifikantes Delta Theta misst.
hat mal jemand nen Temp Sensor an seinen Stecker geklebt? Ich lasse gerade Port Royal laufen mit 133% PT ..
Es ist ein Unding, dass Amazon überhaupt so einen Mist verkauft, zeigt wieder nur, dass man von seinen Waren im Sortiment wenig Ahnung hat.
Ja, ist halt wieder diese Sache wem glaube ich. Viele viele andere Kommentare schreiben das alles super ist mit der 4090. kommt halt immer drauf an wem man tatsächlich glauben will.
Also ich bestelle definitiv 4x8 Pin statt 3x8 Pin bei Cable Mod. Bei meiner Karte lag zwar auch nur ein Dreizack bei, aber 450W verteilt auf 4 Stränge erscheint mir sinniger. Hab eh noch 8x8 Pin PCIe frei am Netzteil. Von daher ist mir das egal...
Amazon verkauft nicht was gut ist, sondern verkauft Dinge, die gewinbringend verkauft werden können. Das ist die einzige Maxime, sowohl bei eigenen Produkten als auch bei Fremdhändlern. Informieren muss sich also der Kunde selbst.
Die Frage ist doch trotzdem interessant, ob man mit einer Rail Aufteilung eventuell weniger Probleme mit verschmorten Kabeln bekommen könnte.
Ich hab mal eine Frage spiele COD und wenn ich aus dem Spiel raus gehe, taktet sich meine Grafikkarte nicht runter sondern sie bleibt bei dem großen Takt Wie festgenagelt Grafikkartentreiber, den aktuellsten, habe ich schon zweimal neu gemacht DDU hat wer sonst noch das Problem nur ein Neustart behebe dieses Problem
Lg
Das ist keine Glaubensfrage. Es kann beide Wahrheiten geben.
Die, bei denen nichts mit der Karte und Adapter passiert und die (mutmaßlich wenigen) Personen, bei denen es zu den Defekten kommt.
Einfach eine der beiden Möglichkeiten beiseite schieben funktioniert nicht.
Die potienzielle Gefahr ist vorhanden.
Einfach zu sagen, es ist ein Bedienfehler ist zu einfach.
Außerdem muss man mal die sicherlich hohe Dunkelziffer betrachten. Nicht jeder der sich die Karte gekauft hat treibt sich ständig in Foren rum und hat das Problem überhaupt mitbekommen. Nicht jeder hat bereits nachgeschaut, wie es Anschluss und Adapter denn so geht.
genau die richtige Antwort :LOL:
9502 Käufer mit 4090 GPUs keine Probleme
10 Käufer mit 4090 GPUs abgeschmolzene Stecker
sry, nichts für ungut :hust:
Nimmst du Port Royal zum Testen?
Ansonsten teste 2mal den Stress Test = 40 Loops. Ist zwar kein Garant für gaming stability, aber für eine erste Einschätzung schon ganz ok.
So ne Karte müsste easy 3 GHz bei 1.05v schaffen oder sogar bisschen weniger schaffen.
Was ist denn der Default Boost bei 1,05v?
Müssten dann ca. 2850 MHz sein.
Ist Division 2 und Deathloop als Stabitest immer noch erste Wahl?
Aha, klar. Die 9502 Leute haben auch alle schon ihre Stecker angeschaut :)
Außerdem weiß noch keiner wie sich das Material in 2 Monaten verhält, vorausgesetzt zum jetzigen Zeitpunkt ist alles ok.
ich wette 90% der 4090 User welche die Probleme mitbekommen haben, haben ihren Stecker Kontrolliert. ;)
Kann man sehen wie man will. Man weis faktisch halt gar nichts. Man weis das es ein paar Fälle gibt und fertig. Man weis weder die die Karten verbaut waren, wie man damit umgegangen ist und ob die Stecker richtig sitzen. Man weis nichts. Man weis nur das es 11 oder 12 Fälle gab unter all den Verkäufen die bisher stattgefunden haben.
Jetzt liegt es an dir. Hast du Sorge und prüfst jeden Tag deinen Stecker ? Oder denkst du es wird schon passen. Ich habe meinen Stecker nicht geprüft. Das mache ich frühestens dann wenn ich das bequiet Kabel habe sofern es irgendwann lieferbar ist.
Das was hier teilweise läuft ist Panikmache vom allerfeinsten. Auch wenn ich weis das viele diese Meinung nicht teilen.
Und wie viele der Besitzer, haben das Problem noch nicht mitbekommen? Nochmal ein gewisser Prozentsatz...
Es könnten mutmaßlich bereits hunderte Fälle sein.
Ich sage nicht, dass es so ist und das die Panik noch höhergeschraubt werden sollte, aber man sollte das Thema ernst nehmen und nicht nur als Probleme einer Minderheit abtun, die ggfs. selbst durch Bedienfehler ausgelöst wurden.
Nein weil du jeden Kommentar der dazu kommt in ein fragwürdiges Licht stellst und Dinge dazu orakelst die nicht sein müssten. Weil du ständig über Dunkelziffern redest, ständig darüber das leute ihre Kabel nicht geprüft haben. Genau das ist per Definition Panikmache. Vor allem wenn man bedenkt das du nicht mal eine 4090 hast und sogar direkt geschrieben hast das du ein "ungutes Gefühl" davor hast weil der Adapter ist wie er ist.
Langsam wird es langweilig, mit diesem Verdammten Kabel quatschen schreiben. Wir wissen doch jetzt Bescheid. :coffee:
Lg
hat mal jemand nen Temp Sensor an seinen Stecker geklebt? Ich lasse gerade Port Royal laufen mit 133% PT ...scheint sich einzupendeln
Was genau heißt bei Dir "Stecker"?
Wie Igor schon erwähnt hat, einen Sensor an das Plastik von außen zu legen bringt garnichts, weil Plastik nunmal schlecht Wärme weitergibt (heißt unter dem Plastik kann es ohne Probleme 30-40 Grad Celsius wärmer sein).
Naja Panikmache, es ist sicherlich im Hinblick auf die Sicherheit kein schlechter Ratschlag den Stecker zu kontrollieren aber ich habe es wegen der Steckzüglen auch nicht gemacht. ;)
Ähnliche Themen
