[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nein weil du jeden Kommentar der dazu kommt in ein fragwürdiges Licht stellst und Dinge dazu orakelst die nicht sein müssten. Weil du ständig über Dunkelziffern redest, ständig darüber das leute ihre Kabel nicht geprüft haben. Genau das ist per Definition Panikmache. Vor allem wenn man bedenkt das du nicht mal eine 4090 hast und sogar direkt geschrieben hast das du ein "ungutes Gefühl" davor hast weil der Adapter ist wie er ist.
Das ist keine Panikmache, meine persönliche Kaufentscheidung trübt das aktuell, weil mir der Stress nach dem Kauf aktuell zu groß ist. Mehr sage ich nicht.
Und die Dunkelziffer habe ich genau einmal erwähnt und auch zurecht wie ich finde. Es ist zu kurz gedacht einfach die Statistik aufzustellen, dass bisher nur 10 Adapter fehlerhaft wären. Mehr sage ich nicht.
Doch tust du und genau das ist das Problem. Und ob du es akzeptieren willst oder nicht. Du machst Panik. Aber ich würde das Thema jetzt beenden, weil es nicht sein muss das wir uns deswegen eventuell in die haare kriegen.
Das tut keiner. Es entscheidet nur jeder für sich selbst ob er wegen diesen Fällen ein ungutes Gefühl hat oder nicht.
Weißt du denn überhaupt was dieser Knopf macht?
Eher nicht nach deiner Frage zu urteilen.
Damit wird einfach nur die Aufteilung der Rails überbrückt und das Netzteil verhält sich wie ein Single-Rail Netzteil
Natürlich weiß ich was der macht. Dann hätte ich aber ja eine Leitung mit ganz viel A
jo lassen wir das, aber Panik mache ich nicht, indem ich sage, dass es durchaus mehr Fälle geben könnte als die, die an die Öffentlichkeit gekommen sind und man das Thema evtl. ernster nehmen sollte.
Das war meine Aussage. Ich hab nichtmal empfohlen, dass bitte alle ihre Stecker checken sollen...
Es ist ein Unding, dass Amazon überhaupt so einen Mist verkauft, zeigt wieder nur, dass man von seinen Waren im Sortiment wenig Ahnung hat.
Nicht Amazon ist der Verkäufer, sondern "dongguanshidalangjunzhilaimaoyishanghang"
Geschäftsadresse:
dalangfukanglu229hao11dong12651shi
dongguanshi
dalangzhen
guangdongsheng
523770
CN
So bin sehr begeistert mit meiner Karte MSI Supreme x seit gestern habe ich auch kein Spulen Fiepen mehr oder sehr leicht, wenn überhaupt habe nur die ganze Zeit gespielt in hohen FPS.
Lg
Kein Fiepen bei der Supreme? Das kann ja nicht lange dauern bis die ersten kommen und dir unterstellen du hörst schlecht.
Es ist durchaus vernünftig zu sagen, dass die Dunkelziffer der nichtbekannten Fälle - selbstverständlich - die Zahl der bekannten um ein Vielfaches übersteigt.
Erstmal kontrolliert nicht jeder seine Kabel.
Dann wird nicht jeder überhaupt um mögliche Schäden wissen (nicht jeder Käufer liest Internetforen).
Zudem kann der Fehler/Schaden bei einer einfachen Sichtkontrolle (ohne Rausstecken) "unbekannt" bleiben (wenn nur die Pins/das Plastik um die Pins schmilzt, sieht man das von Außen nicht, wenn der Stecker in der Graka sitzt). Zudem kommt, dass leichte Verformungen von Plastik meist nur dem geschulten/aufmerksamen Auge auffallen (bevor das Plastik quasi komplett durchschmilzt). Heißt also, dass sich auch bei einer intensiven Sichtkontrolle (Stecker wird entfernt) bereits beschädigte, aber noch nicht durchgeschmolzene Pins vom ungeschulten Auge nicht erkannt werden könnten.
Außerdem meldet nicht jeder seine Schäden auf Reddit oder in Foren, sondern wendet sich direkt an den Händler/Hersteller (Fälle werden uns nie bekannt).
Wir haben hier also in vielerlei Hinsicht ein großes Problem, den Schaden einzugrenzen und die potentielle Zahl Geschädigter zu benennen.
Hinzu kommt noch, dass wir hier von dem Highend Produkt einer Art "Luxusline" sprechen, heißt also die Zahl der potentiell geschädigten ist sowieso relativ klein, da die große Masse an Käufern (60er, 70er Karten) noch überhaupt nicht zum Zug kamen. Wenn wir also von tausenden, nicht hunderttausenden potenziellen Kunden in Deutschland sprechen, ist die Zahl derer, die Probleme Publik machen, natürlich verhältnismäßig sehr gering (hinzu kommt, dass nur eine kleine Anzahl von Geschädigten, erfahrungsgemäß, überhaupt ihre Erfahrung öffentlich kundtun).
Dunkelfeldforschung (so nennt man das) ist und bleibt extrem schwierig und meist nebulös. Vollkommen unabhängig, ob es dabei um Kriminalitätsstatistiken oder um Steckerprobleme bei NVIDIA geht. Meistens hoffen die Hersteller (Automobilbranche *husthust*), Probleme entweder aussitzen oder über stille Rückrufe (Kleinreparaturen bei Inspektionen, die nicht gesondert dem Kunden mitgeteilt werden und auch nicht in Rechnung gestellt werden) lösen zu können, bevor es zu Klagen kommt - das kann NVIDIA hier natürlich nicht, da es bei Grafikkarten nunmal keine Inspektionen gibt - und die Adapter anscheinend als Brandbeschleuniger zum Versicherungsfall werden (können).
Solange wir hier noch keine weiteren Informationen haben, sollten 4090 Besitzer auf jedenfall a) ihre Karten/PCs nicht anhaben, wenn keiner im Haus ist und b) die PCs nachts ausmachen (wenn geschlafen wird). Ausbauen ist natürlich vorerst die beste Wahl (bis NVIDIA sich gemeldet hat/ bekannt wird, ob und welche und wie Kabel Probleme machen könnten), aber das kann man schlecht erwarten von Menschen, die vermutlich keine Alternative haben.
hat mal jemand nen Temp Sensor an seinen Stecker geklebt? Ich lasse gerade Port Royal laufen mit 133% PT ...scheint sich einzupendeln
Offenes Setup oder geschlossen?
Hatte zwar die Idee aber bringt glaube ich nichts, das Material ist ein Wärmeisolator. Könnte von Innen beginnen an zu schmelzen noch bevor dein TC von außen ein signifikantes Delta Theta misst.
Müsste ich mal testen…
Wenn das Material nicht zu dick ist, kann die WB-Cam quasi durch undurchsichtiges Material was „sehen“ (messen). Wie genau die Messung ist, kann man sicher auch irgendwie rausfinden. Und beim Stresstest wird der Kunststoff auch warm bzw. heiss (siehe mein Video)
Ich glaube nicht, dass hier eine "Dunkelziffer" besonders hoch ist. Ganz einfach weil die 4090 ein reines Enthusiasten Produkt ist. Wer für eine Grafikkarte 2k€ ausgibt, der liest einschlägige Threads und weiß über die Problematik bescheid. Und: In der jetzigen Situation würde wohl JEDER der Enthisuasten mit 4090 dies in den entsprechenden Foren öffentlich machen, wenn bei ihm auch was schmort. Ich denke, die 10 Fälle die wir bisher kennen sind die Fälle die auch aufgetreten sind. Eine Dunkelziffer ist wenn dann sehr gering. Aus genannten Gründen. Bei ner 3050 aus nem Mediamarkt Stangen PC wäre das natürlich anders:).
Amazon verkauft es ja auch nicht. Es ist ein Händler der ÜBER Amazon verkauft, selbst wenn es im Amazon-Lager ist.
Nur wenn dort steht "Verkauft durch Amazon" ist es von Amazon. Alles andere könnte quasi auch von Ebay oder Alibaba stammen...
Wenn es Probleme gibt, sperrt Amazon den Artikel oder Händler...der Schaden ist aber schon da und kurze Zeit später wird der Artikel unter einem anderen Namen und Händler weiterverkauft...
Und ja Amazon müsste was dagegen tun, sie sind aber unfähig oder es kostet denen zu viel Zeit/Geld...
Gerade meine KFA2 erhalten und direkt ausprobiert. In der Tat ist das Spulenfiepen so minimal wie ich es schon lange nicht mehr gehört habe. Man kann der Karte schon noch Geräusche entlocken, aber man muss schon sehr genau hinhören um diese zu bemerken. Im normalen Gebrauch würde das gar nicht mehr ins Gewicht fallen. Meine 4090 TUF habe ich im Gegensatz dazu selbst mit Airpods (aktive Geräuschunterdrückung an) drin noch surren hören können. Das ist überhaupt kein Vergleich im Bezug auf Nervigkeit.
Den Lüfter der Karte habe ich auch nicht über meine Gehäuselüfter hören können. Ich würde diesen ungefähr auf dem Niveau einer 4090 TUF im Quiet-Modus einschätzen. Läuft auch ruhig, selbst wenn er aufdreht.
Edit: Wenn man die Last dann mal runternimmt merkt man schon, dass die Lüfter einen gewissen Pegel erreichen. Ich würde es jedoch immer noch als leiser als die TUF im Performance-Mode einschätzen.
Edit2: Fall jemand diesen Post hier findet, habe hier noch einige Erfahrungen zu den Lüftern gepostet.
So meine MSI Suprim X geht jetzt zurück, hab genug von dem blöden Drecksding.
Nicht nur das die Karte Spulenfiepen hat wie blöd wie bei vielen anderen hier, die Karte verhindert aktiv das ich meinen Rechner herunterfahren oder in den Energiesparmodus versetzen kann.
Jeder Versuch den Rechner herunterzufahren via Windows resultierte in nem Neustart, egal ob übers Startmenü oder cmd shutdown.
Nur das Drücken der Power Taste am Gehäuse konnte den Rechner ausschalten, aber das ist wie wenn ich jedes mal zum Fernseher laufen muss um ihn abzuschalten anstatt die Fernbedienung zu nutzen.
Hab gestern und heute so ziemlich alles an Troubleshooting versucht was ich im im Netz da finden konnte ohne Erfolg.
Dann dämmerte es mir dass das einzige was ich an Hard/Software geändert habe am Rechner die Graka war (Board Bios / Win Treiber waren schon vor der 4090 auf dem aktuellsten Stand), also heute die 4090 raus, die alte Zotac 3080Ti wieder rein und siehe da es läuft alles wieder ohne Probleme.
Die Ada MSI Karten werde ich ab jetzt meiden und schauen das ich ein 1950€ Model abgreifen kann, bis dahin heißt es zurück zu Ampere.
Der fucking AMD Chipsatztreiber wars :motz:
Seit 12.10 gibt es ne neue Version und ich hatte nicht mitbekommen das es ein Update gab, also hatte ich noch die Version von davor.
Mit dem aktuellen Chipsatz Treiber fährt der Rechner mit der Suprim X ohne Probleme aus Windows heraus runter oder in den Energiesparmodus.
Ach warum ich die Suprim X überhaupt noch habe fragt ihr euch? Das liegt an dem Geschäftsgebahren vom Media Markt.
Media Markt Deutschland (und damit vermutlich auch Saturn) verkauft zwar liebend gerne online und versendet ihr Zeug aus einem Zentral Lager, aber wenn es um Widerrufe, Rückgaben etc. dann wird das auf die regionalen Märkte abgewälzt. Und zwar immer auf den Markt der eurer Adresse am nächsten ist. In meinem Fall hatte das DHL-Retoure Label immer die Adresse des Media Markts der eine Minute von meiner Arbeit weg ist. Also bin ich persönlich mit der Karte dort him um sie zurückzugeben. Und was dann folgte darüber kann ich nur den Kopf schüttlen.
Es ist völlig egal was ihr für einen Rückgabe Grund wählt, falls die Karte in einem Recher eingebaut war wird angenommen das sie nen defekt hat und zum Hersteller zur Überprüfung geschickt, weil das der regionale Media Markt nicht selbst überpürfen kann und dafür haftet wenn er die Karte ohne Überprüfung zurücknimmt. Auch wenn ihr online gekauft habt und euch im 14 tägigen Widerruffenster befindet.
Erst wenn die Karte vom Hersteller überprüft wurde (was im Falle MSI viele Wochen dauern wird) bekommt man das Geld wieder vom regionalen Media Markt.
Ich habe die Karte dann wieder mitgenommen in der Hoffnung den "Dealbreaker" mit dem Herunterfahren irgendwie lösen zu können, was mir zum Glück gelungen ist. Und da das Spulenfiepen der MSI im Vergleich zu dem Lüftergehäule der Phantom viel viel weniger Schlimm ist werde ich die Suprim jetzt erstmal behalten. Außerdem heißt es ja dass das Spulenfiepen mit der Zeit weniger werden soll, mal schauen ob das bei mir auch so ist.
Nach dieser Erfahrung werde ich aber mit sehr hoher Wahrscheinlichkeit keine PC-Komponenten mehr bei Media / Saturn kaufen.
Wenns nur Spulenfiepen ist, das KANN nach einigen Wochen deutlich weniger werden...wenn die Karte belastet wird.
Da scheinst Du etwas Pech gehabt zu haben. Als ich letztes Jahr zu MM wegen einer defekten Graka ging, konnte mir der Mitarbeiter bei meiner Reklamation/Garantiemeldung wegen einem Defekt an der Graka umgehend das Geld vollständig zurückerstatten und die Karte zurücknehmen (war eine 2080, 1 1/2 Jahre 'alt'). Ich war ohne Termin hin und direkt zu deren Reklamations-Schalter.
Wobei ich zugestehen muss, dass der Mitarbeiter es sowieso nicht so genau ´nahm. Der hatte nicht mal den Karton aufgemacht, um zu schauen, ob da überhaupt eine Grafikkarte drin war. Scheinbar sah ich einfach vertrauenswürdig genug aus. Am Ende hatte er einfach vom System die Option bekommen, hat mir das mitgeteilt und dann habe ich die eben gewählt.
Wie so oft im Kundenservice hängt es häufig davon ab, welchem Menschen Du ggü. stehst und wie man sich selbst verhält. Zudem kann man im Zweifel in einem lokalen Markt auch immer nach dem Marktleiter fragen (der hat in der Regel mehr Möglichkeiten als einfache Supportmitarbeiter).
Ist das „neu“ bei MM…?
Bisher konnte man online bestellte Ware beim örtlichen MM (oder in anderen Filialen) zurückgeben und das Geld wurde auf dem gleichen Weg, wie bei der Bestellung zurückgegeben
Das kann man doch frei wählen?
Per Post - Sendungen, die du per Paketdienstleister erhalten hast​
Gib deine Bestellnummer und deine E-Mail-Adresse ein, um einen kostenlosen Retourenschein zu erstellen.
Ich habe keine Ahnung ob das "neu" ist, das wäre meiner erster Widerruf gewesen.
Ich habe diese Aussage vom Marktleiter meines regionalen Media Marktes so bekommen (Typ mit weißem MM Hemd), weil sie 2 Fälle mit defekten 3000er Nvidia karten in den letzten Jahren hatten wo sie dann auf dem Schaden sitzen geblieben wären.
aber die Abwärme ist völlig absurd, ich hab im 15qm Arbeitszimmer trotz offenem Fenster schnucklige 28 Grad.
Das wird noch viel absurder. Intels neuste 13th Gen frisst 300 Watt weg, kombiniert man das mit einer 4090 und geht von mehreren Festplatten/Lüftern aus, landen wir irgendwo bei 800 Watt Abwärme. Wenn es jetzt noch Menschen mit vernünftiger Soundanlage (AV-Receiver) gibt, kommen wir an den Punkt, wo selbst eine vernünftige Klima-Anlage im Sommer dagegen nicht mehr anrennen kann (Abwärme des eigenen Körpers bei Berechnungen nicht vergessen!).
Dieser Wahnsinn, immer mehr Watt reinzupumpen... bescheuert.
Naja, ich halte meine 4090 vorerst bei 60% PL, warte auf ein ATX 3.0 PSU und dediziertem Kabel (hoffentlich fackelt mir bis dahin die Bude nicht ab (40% Scherz)) und gut ist.
Hast den Bildschirm noch vergessen!
Ich nutze einen LG OLED C1 in 65 Zoll als Monitor und der verbraucht mit unter über 200 Watt je nach Helligkeit 🤣...
5.1.4 Dali Set :d und nen 77er Oled... ich hab schon seit Jahren ne Klimaanlage im Wohn und Arbeitszimmer
Da bin ich bei dir! Mit der Ausnahme, dass es gewiss eine Dunkelziffer gibt. Nicht jeder Enthusiast treibt sich in Foren rum… sondern wickelt die Geschichte ohne „großen Aufstand“ ab. Damit möchte ich die Problematik keineswegs lächerlich klingen lassen….
Selbst wenn die „Dunkelziffer“ bei 5x der bekannten Fälle ist, ist die Zahl im Vergleich der verkauften Karten nicht mehr als ein Furz im Wind.
Wir unterhalten uns hier von sagen wir mal aufgerundet 20 uns bekannten Fällen - WELTWEIT!
was ist jetzt eigentlich mit den FEs? Wie bekommt man da am besten Infos. Der Hardwareluxx bot scheint ja am Mittwoch nicht ausgeschlagen zu haben ... ich hab das ding echt tag und nacht laufen und möchte doch nur so eine karte haben
Naja du bist nicht der Einzige der eine FE kaufen will, die paar Karten sind halt direkt wieder weg. Das wird auch noch ne Weile dauern, bis man als Normalsterblicher eine Chance hat, die Karte zu kaufen.
hier gabs am mittwoch jedenfalls kein event und leute scheinen welche bestellt zu haben: https://www.hardwareluxx.de/community/threads/rtx-4090-gpu-verfügbarkeitshinweise.1324038/page-19#post-29522748
Da kannst Du nicht viel mehr machen. Bots/Ticker im Auge behalten und nach Einstellen von NBB hast Du ca. 30-80 Sekunden Zeit, danach sind die safe weg. Manchmal werden hier im Thread auch links geposted.
NBB kündigt selten Drops an, es bringt manchmal nur etwas, die Drops in UK im Auge zu behalten, die deutschen Drops kommen in der Regel in einem gewissen Abstand dazu.
Geht mir genauso...deswegen hatte ich im Sommer schon die 3090 gedrosselt und genau deshalb wird bei mir die 4090 dann auch mit <300W laufen.
CPU ist ein 5800X3D ab nächster Woche. Für 349€ :d
Und als Monitore habe ich ein 1080p 27" und ein LG C2 42", die maximal zusammen 150W fressen...
FYI: Im Sommer wars über 35°C hier im Zimmer...
Ähnliche Themen
