[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Scheint mindestens drei Kombinationen zu geben
150V 4 solder pad (Igor's)
300V 4 solder pad
300V 2 solder joined (GN's)
Sieht so aus ... vielleicht machen sie 1 Woche lang Version 1 dann 1 Woche Version 2 und dann 1 Woche Version 3 und dann gehts wieder mit Version 1 weiter :ROFLMAO: ... schon seltsam was da passiert.
Eigenlich sollte 1 Produkt was man herstellt immer gleich sein aber bei Nvidia bzw dem 3t Anbieter den Nvidia sich da ausgesucht hat scheint man das sehr locker zu sehen :d
Wir sind nun auch schon bei 18 Fällen :
Danke für die Info die eigentlich für einen anderen Betrag bestimmt wäre :)
das weis bis jetzt wohl nur nvidia^^ wenn die karte nicht durch ein problem stirbt welches am anschluss erkennbar ist, dann wird nvidia das nicht checken
Meint ihr nächste Woche kommen FEs? Oder wird Nvidia die zurück beordern?
eher seawhale
Ich hab das Mesh genommen, hab aber auch vertikal verbaut.
Wenn du etwas biegsameres brauchst, nimm das Flex.
ist der unterschied groß? ich hab dummerweise auch das mesh bestellt. da ich den 90 grad adapter aber anpeile isses wohl egal dann.
die mesh kabel kenne ich von meinem kompletten set, die sind schon echt steif :d
was ich mal gehört habe soll der bei der fe, strix und tuf passen. das schaubild von Cablemod ist eine strix wenn ich mich nicht irre.
ob es noch bei anderen passt ka.
es wird 2 versionen geben.
hmmm
ich kann kein spiel mehr starten
egal ob steam, epic oder witcher ohne launcher.
kriege überall fehlermeldungen
was ist dennn JETZT LOS
Wundert mich das so wenige Leute darüber teilen wie ihre Karte läuft . Was die OC packt .
Kommen meistens nur paar wenige mit einer Perle um die Ecke .
Liegt leider auch daran dass alle Karten dieser gen mehr oder weniger gleich gehen, keine Ausreißer
So hab jetzt mal den ersten Run mit Time Spy Extreme mit der KFA2 @Stock durchgeführt.
Die Lüfter werden bei ca. 1200 rpm dezent hörbar aber alles noch im grünen Bereich.
Was Spulenfiepen angeht bin ich überrascht, konnte absolut nichts hören!
Muss gestehen hab jetzt den Überblick verloren aber ich glaube ein normales Ergebnis für Stock oder?
Kann ich Dir leider nicht sagen, hab ja noch keine von CableMod. Solang man die nicht vorher mit nem Schnitzelklopfer bearbeiten muss, passt das schon...:fresse:
Sorry, aber wo von sprichst Du, weder hat meine 3090FE ein Kunstoffgehäuse, noch wackelt der Stecker, der sitzt bombenfest dran.
Das aufrecht stehende Steckergehäuse hat bei meiner 3090FE damals leicht gewackelt, es war nicht 100% fest, die 12 Pins waren es. Wie das bei deiner Karte war, weiß ich nicht und sprach ich auch nicht 🤷‍♂️
19.500 finde ich gut für stock.
Meine TUF non-oc macht nur 18.600 und mit OC etwa +10% so um 20.600
https://www.3dmark.com/3dm/82105280? stock
https://www.3dmark.com/3dm/80996869? OC (Durchschnittliche Taktfrequenz 3.004 MHz)
Was gibts sonst noch? Gigabyte AERO und Waterforce sehen gut aus. Ist das ein Marken Wasserblock den man hier einsetzt? https://videocardz.com/newz/gigabyt...me-waterforce-and-aero-graphics-card-pictured
Oh das sind ja 4080er seh ich grade
nein ka. seid nem bluescreen vorhin. ojee...
crystal findet die nicht mehr
edit :
pc vom strom nehmen hat geholfen. wtf
Vielleicht weil die 4090 so riesig ist und mehr Abwärme oder überhaupt erst Abwärme an sich da drauf bläst...hab mal selbst die Temps bei mir beobachtet und nur festgestellt das der PCH Chip 5-8 grad wärmer wird als mit der 3090. Wahrscheinlich weil die direkt bis dort hin reicht...wäre zumindest ein Grund...
ne war ein bluescreen vorhin verursacht durch ram "oc" beim start eines spiels auf der ssd kams instant zum bsod.
was anderes kanns net gewesen sein^^
edit :
Habe ich auch seit 3 Monaten sporadisch…glaube hauptsächlich bei Kalt-Start (Netzteil ausgeschaltet). Kaltstart mag mein X570/5800X3D sowieso nicht…muss dann immer reset drücken sonst bootet er nicht ohne „LED Fault“ am motherboard.
Einzige Änderung war damals neuer Prozessor + Bios Update.
Egal…ist zum Glück immer nur SSD #2 wo nix wichtiges drauf ist. Also einmal Neustart und gut ist.
Genauso nervig wie der Fehlende Mauszeiger in Windows…da hilft auch nur „Sign Out“ und schwups ist der wieder da. Vermute das hängt am VR Headset…
Titel wurde ungünstig gewählt :d
:ROFLMAO:
Ähnliche Themen
