[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
FYI: Auf EBK bietet jemand ne FE für 2,3K an. Ist noch versiegelt. Fast noch human :ROFLMAO:
Immer wieder schade das wg paar hundert Euro einem tatsächlichen Zocker die FE vorenthalten wird, nur um sie auf Ebay KA zu parken und sich daran zu bereichern. Kann gar nicht oft genug sagen wie schäbig ich das finde. Soviele Ellbogen kannst gar nicht haben...sorry für OT, bin sehr zufrieden mit der Gaming OC. Musste kurz raus 😂
Brauche mal eine Meinung von euch:
Der Lüfter meiner Zotac Trinity rattert ein wenig. Nicht arg laut, aber schon wahrnehmbar. Jetzt weiß ich nicht, ob da ein Lager unrund läuft oder nicht (meine 3080 FE hatte das auch).
Würdet ihr in der jetzigen Situation die Karte zurückschicken oder eher behalten. Hab sie für 2100€ bekommen, also verhältnismäßig "günstig". Zudem hat sie den blöden 150V Adapter. Das gute ist, zotac gibt insgesamt fünf Jahre Garantie.
Ich befürchte mit der ganzen Kabel Problematik könnte es ja vermutlich erstmal schwieriger werden einen adäquaten Ersatz zu bekommen.
Kann das sein, dass Spulenrasseln mit der Zeit weniger wird ? Gefühlt empfinde ich das jedenfalls, oder aber ich gewöhne mich an den Klang :d
Hab meine TUF 4090 OC auch mal durch den 3DMark gejagt. Stock mit Bios auf OC.
Hatte nebenher GPU-Z offen, weil ich mal wissen wollte wie viel Strom sich die Karte genehmigt. 481Watt war das höchste an Board Power. Dafür bleibt sie aber immer unter 70Grad.
In Cyberpunk langweilt sie sich sogar. Spiele dort aber auch nur in QHD. Bin jedenfalls sehr zufrieden mit der Karte. Obwohl sie gerne mal ein laut von sich gibt, bleibt sie definitiv bei mir.
Sobald der 90Grad Adapter und der Wasserblock bestellt bzw. da sind, kann ich auch endlich mein Gehäuse wieder schließen.
So hab jetzt mal den ersten Run mit Time Spy Extreme mit der KFA2 @Stock durchgeführt.
Die Lüfter werden bei ca. 1200 rpm dezent hörbar aber alles noch im grünen Bereich.
Was Spulenfiepen angeht bin ich überrascht, konnte absolut nichts hören!
Muss gestehen hab jetzt den Überblick verloren aber ich glaube ein normales Ergebnis für Stock oder?
Interessant, deine geht bei Volllast nur auf 1200rpm? Meine dreht auf 1700rpm auf und das in einem H7 Flow mit guter Lüfterbestückung. Geht bei deiner Karte Zero-RPM im Idle einwandfrei? Meine ist immer auf min. 1000rpm.
Sorry hab ich mich da falsch ausgedrückt, ab ca. 1200 rpm nimmt man die Lüfter war, bei mir war in etwa 1350rpm unter Volllast. Hab aber auch 3x120mm Lüfter unter der GPU. Zero-rpm geht ist aber etwas träge, dauert eine Weile bis die Lüfter ausgehen.
Ok, danke für die Info. Frage mich ob evtl. mit meiner Karte etwas nicht in Ordnung ist, wenn die so hochdreht. Airflow ist auf jeden Fall genug vorhanden. Wie sahen die Temps bei dir aus? Meine Karte geht quasi direkt hoch auf 70c und dann drehen die RPM auf um die Temperatur auf Biegen und Brechen zu halten.
Hmm keine Ahnung, ich hab das Jonsbo D30 und die Lüfter direkt unter der GPU und zudem im Zimmer relativ kühl. Meine hat die 70c nichtmal gesehen, max. liegt so eher bei 67/68c.
Siehste, sag ich ja dass die Karte top ist :)
Also ich Zock schön weiter.. Cyberpunk :) .. Adapter ist egal, bisher rieche ich nix. Die Temparaturen von aussen am Terminal gemessen, waren bisher nicht bedenklich. Alles < 56 grad. Von daher, gib ihm.
Nvidia 4090FE - OC +220 auf Core und +500 auf Speicher bei 1.05V. Lande da bei 2895 Mhz ingame. Bin einfach zufrieden damit. Lande bei ~600 Watt für das gesamte System. Da geht noch mehr, aber dann braucht die Karte viel zu viel. Bei anderen Spielen werd ich PT runtersetzen ohne OC.. Wo ich sowieso bei 4k > 120 fps bin, oder ich setz die Auflösung hoch per DSR, wie bei TheWitcher3. Einfach schön, ohne Geflimmer und trotzdem Scharf.
Night City mit dem LG 42C2 und mit DLSS auf Quality und Raytracing ist einfach.. wirklich schön.
Roman hat die Frostbite 4090 getestet:
- Nur 450W Bios. Es ist nicht möglich das Powertarget zu erhöhen
- Nur 3 PCIe Stecker am Stromadapter dran
- Spulenfiepen vorhanden
Leider nicht attraktiv genug für 2500-2600 Euro
Gerade festgestellt, dass die bestellten Cablemod Kabel für mein Corsair nur 27cm lang und damit zu kurz sind. Und natürlich sind die 24 Stunden, innerhalb derer man die Bestellung noch stornieren könnte, schon um.
Mfg
Kiryu
Versuch dein Glück per Email… der liest auch Sonntags manchmal Emails und antwortet eigentlich sehr schnell.
Hab den Support schon angemailt und nebenbei das korrekte Kabel bestellt. Wenn es sich nicht mehr stornieren lässt...ist bei den Preisen am Ende auch schon egal, will eigentlich die Karte einfach endlich nutzen. Auch wenn man natürlich nichts zu verschenken hat.
Mfg
Kiryu
Laut Igor : zug und biege empfindliche litze ohne zug entlastung ist schlicht nich zulässig und durfte man so eigentlich wohl garnicht in den verkehr bringen .. ( hat Nvidia aber leider getahn )
Dieses Pad wodrauf verlötet wird scheint auch nich grade idial zu sein bzgl der Thermischen Belastung beim Lötvorgang .. das Pad könnte dadurch weich werden und brüchig
und bei Mechanischer belastung ( also beim biegen ) dann "flups" machen und abfallen so wie hier auf dem Bild :
Er sagt wir haben da enorme Qualitätsschwankungen bei den Adaptern von Nvidia
Er sagt eine richtige Qualitätskontrolle kann man mit so nem Ding ( Der Nvidia Adapter ) nich machen
Er sagt löten is scheisse und Crimpen währe besser gewesen ( wie ich letzens auch schon sagte .. eine Buchse = ein Kabel so wie es all die Jahre zuvor auch schon immer war )
Crimpen statt Löten: wie man die GeForce RTX 4090 schadensfrei mit Strom versorgt und richtig biegt!​
Und wir sind nun auch bei Fall Nr. 19 angelangt :
Von den nächsten 2-3 Fällen werde ich noch berichten aber danach ist meine mir selbst gestellte Aufgabe dann auch erfüllt sodass ich dann nach diesen nächsten Fällen dann
meine Berichterstattung dazu einstelle da die Sache nun auch nicht mehr klein geredet werden kann was ja damals hier im Thread ein paar Leute versucht haben zu tun.
Ich weiß nicht wie ihr das sieht aber das ist die fetteste Karte die NV rausgebracht hat
Ich meine ….
Ich Game ja mehr die Indiependen Spiele aber es kommen da auch größere Kaliber zu Stande und selbst dann langweilig sich die Karte
Ich hatte vorher eine RTX 3080 Aorus Xtreme ( was eine schöne Karte gewesen 💁🏽 ) und die hat echt Sprit verbraucht und lief auf Volllast mit 69 Grad
Meine Trio läuft auf Luft mit 33 Grad
Kein Witz ! Ich Check HWInfo und Co stets mit Riva Turner usw und ich habe nur das Lancool Mesh 2 während das Nachfolgemodell mittlerweile Mesh im Boden vorzuweisen hat ( wird gekauft mit Hardware Umzug )
Ich habe allerdings auch die 60FPS Begrenzung
Mein OLED kann noch keine 120Hz
Wollte mir erst einen Kaufen wenn LG so gnädig ist und 38 Zoll zur Verfügung stellt
Heilige Sche….
Der Verbrauch liegt im Schnitt auf 200 bis 250 Watt ohne UV ^^“
Ich glaube die Karte ist einfach too much für mein System
Generell habe ich da wohl eine kleine Chip Lotterie gewonnen
Kein Fiepen, kein rasseln und der boost ist laut MSI Afterburner sehr hoch
Was ich nicht leiden kann ist die RGB Software Mystic Light
Da funzt kaum was
Hatte echt Probleme mit der G Skill - RGB Fusion Software im kombinierten Zustand
Jetzt leuchtet die Karte da ich das MSI Center installiert hatte
Danach wollte G. Skill und RGB Fusion nicht mehr
Also das Center deinstalliert sowie G. Skill + RGB Fusion
Den PC habe ich dann vom Strom genommen (Trick 17 wenn die Riegel nicht mehr von der RGB Fusion erkannt werden)
Jetzt macht es wieder Leuchti Leuchti 🫶
Die Karte ist doch extrem leise, er hält sogar sein Mikro direkt daneben. 450 Watt ist, wie wir inzwischen ja wissen völlig ausreichend für eine 4090. Eher ist sogar 70-80% zu empfehlen. Okay sicher nichts für den extrem-Overclocker aber halt die einzige fertige Wakü-Karte. Proshop.de hatte die kurz vor dem Lanuch für 2,3k gelistet. Ist natürlich nicht jedermanns Sache, auch die Optik aber verkehrt finde ich die Karte nicht.
Moin, was kann man denn als normal sterblicher Mensch der Tagsüber arbeitet tun um an ne Karte zu kommen? Wohl nur Scalper Preise zahlen oder warten oder?
woher weiß man wo es wann neue auf Lager gibt? Oder guckt ihr 100 mal am tag bei allen Shops?
Ich hab meine erste um die Mittagszeit hier über den Verfügbarkeits thread bekommen aber nur weil ich frei hatte und 4-5 Stunden an der Kiste geklebt habe!
Leider ging meine Karte retour und sitze nun ohne hier weil auch keine Zeit habe jagen zu gehen.
Ich könnte mir vorstellen das nach Release der 4080 es etwas einfacher wird !
Ich war einer der Glücklichen der per Nvidia Experience einen Link für eine FE für UVP Preis bekommen hab. Kannst ja auch mal nachschauen :) Vielleicht ist dort ja was.
Ich finde die Preise inzwischen recht human: gestern hätte ich ne FE über EKA für 2.100 haben können. Die Palit kriegt man auch schon im 2.050 - alles versiegelt bzw. ungeöffnet. Warte noch aufs Loki (kein Bock auf die Adapter) und dann gehts los.
Gut dafür kostet das Loki ne halbe niere 😅
Aber ne Karte auf eigenen Namen ist dann halt auch besser denke ich
war klar, ist bei den anderen Inno3d Karten auch so. Dafür gibt es bisher aber ach nicht eine Meldung von Inno3D bzgl. Adapter.
Komisch, meine X3 OC hat keines. Wäre vielleicht interessant welches Modell da als "Basis" dient.
Hm, die Karte liegt bei CK bei 2349€ und CK ist meist teurer als die anderen.
Du kannst dir beim Verfügbarkeitsbot eine Meldung sichern das du benachrichtigt wirst. Ich habe einfach nach der Arbeit mal Abends geschaut und hatte direkt glück. Ist aber aktuell etwas schwerer.
wieso ? Du bist der einzige der überhaupt noch das Thema verfolgt. Die meisten haben davon die faxen Dicke.
Ist das dein Ziel ? Das man nun nicht mehr sagt es gibt kein Problem? Ich glaube nicht das das so funktioniert wie du dir das vorstellst. Denn nach wie vor ist halt überhaupt nichts bestätigt. Und es gibt ja auch gneug Leute die einfach ihre 4090 normal nutzen. Selbst wenn das in 2 bis 3 Tagen 30 Fälle sind, ist es nichts besonderes.
Man könnte auch noch ein paar Tage warten bis die Karten an die Händler zurückgeschickt werden und dort dann direkt mit Rechnung und co. kaufen. Immerhin sind die Karten ja unbenutzt.
Ähnliche Themen
